Windows Vista 6.1
AMD64
Wow64Process
WinAspi: -
NT-SPTI used
Nero Version: 9.4.26.100
Internal Version: 9, 4, 26, 100
Recorder: <HL-DT-ST BDDVDRW GGC-H20L>Version: 1.03 - HA 1 TA 0 - 9.4.26.100
Adapter driver: <Serial ATA> HA 1
Drive buffer : 2048kB
Bus Type : via Inquiry data
CD-ROM: <HL-DT-ST BDDVDRW GGC-H20L>Version: 1.03 - HA 1 TA 0 - 9.4.26.100
=== Scsi-Device-Map ===
DiskPeripheral : Volume0 iaStor Port 0 ID 0 DMA: On
CdRomPeripheral : HL-DT-ST BDDVDRW GGC-H20L iaStor Port 0 ID 1 DMA: Off
=== CDRom-Device-Map ===
HL-DT-ST BDDVDRW GGC-H20L E: CdRom0
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 83886080 (0) Byte
BUFE : 0
Physical memory : 4095MB (4194303kB)
Free physical memory: 4095MB (4194303kB)
Memory in use : 22 %
Uncached PFiles: 0x0
Global Bus Type: default (0)
Check supported media : Disabled (0)
1.12.2009
DVD-Image brennen
10:45:52 #1 Text 0 File SCSIPTICommands.cpp, Line 430
LockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL
10:45:52 #2 Text 0 File Burncd.cpp, Line 3572
Turn on Disc-At-Once, using DVD media
10:45:53 #3 Text 0 File DlgWaitCD.cpp, Line 313
Last possible write address on media: 2295103
Last address to be written: 1558722
10:45:53 #4 Text 0 File DlgWaitCD.cpp, Line 325
Write in overburning mode: NO (enabled: CD)
10:45:53 #5 Text 0 File DlgWaitCD.cpp, Line 2843
Recorder: HL-DT-ST BDDVDRW GGC-H20L, Media type: DVD+R
Disc Manufacturer ID: <MBIPG101>, Media Type ID: <R05>, Product revision number: 1
Disc Application Code: 0, Extended Information Indicators: 7
10:45:53 #6 Text 0 File DlgWaitCD.cpp, Line 500
>>> Protocol of DlgWaitCD activities: <<<
10:45:53 #7 Text 0 File ThreadedTransferInterface.cpp, Line 739
Setup items (after recorder preparation)
0: TRM_DATA_MODE1 (2 - CD-ROM Modus 1, ISO 9660)
2 indices, index0 (150) not provided
original disc pos #0 + 1558723 (1558723) = #1558723/346:22.73
not relocatable, disc pos for caching/writing not required/not required
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 1558723 blocks [E: HL-DT-ST BDDVDRW GGC-H20L]
10:45:53 #8 Text 0 File ThreadedTransferInterface.cpp, Line 941
Prepare [E: HL-DT-ST BDDVDRW GGC-H20L] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
TOCType: 0x00; Session Closed, disc fixated
Tracks 1 to 1: Idx 0 Idx 1 Next Trk
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 3192264704, ISRC ""
DAO layout:
___Start_|____Track_|_Idx_|_CtrlAdr_|_____Size_|______NWA_|_RecDep__________
0 | lead-in | 0 | 0x41 | 0 | 0 | 0x00
0 | 1 | 0 | 0x41 | 0 | 0 | 0x00
0 | 1 | 1 | 0x41 | 1558723 | 1558723 | 0x00
1558723 | lead-out | 1 | 0x41 | 0 | 0 | 0x00
10:45:53 #9 Text 0 File SCSIPTICommands.cpp, Line 217
SPTILockVolume - completed successfully for FSCTL_LOCK_VOLUME
10:45:53 #10 Text 0 File Burncd.cpp, Line 4279
Caching options: cache CDRom or Network-Yes, small files-No (<64KB)
10:45:53 #11 Phase 24 File dlgbrnst.cpp, Line 1767
Caching of files started
10:45:53 #12 Text 0 File Burncd.cpp, Line 4401
Cache writing successful.
10:45:53 #13 Phase 25 File dlgbrnst.cpp, Line 1767
Caching of files completed
10:45:53 #14 Phase 36 File dlgbrnst.cpp, Line 1767
Burn process started at 8x (11.080 KB/s)
10:45:53 #15 Text 0 File ThreadedTransferInterface.cpp, Line 2695
Verifying disc position of item 0 (not relocatable, no disc pos, no patch infos, orig at #0): write at #0
10:45:53 #16 Text 0 File Cdrdrv.cpp, Line 10282
---- Disc Structure: Physical Format Information (00h) ----
Media Type: 0, Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
Book Type: DVD+R (10), Part Version: 1.0x (1)
Disc Size: 120 mm, Maximum Transfer Rate: <not specified> (F h)
Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer Type: recordable
Linear Density: 0,267 um/bit, Track Density: 0,74 um/track
Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW)
End Physical Sector Number of Data Area: 26053F h
Data in Burst Cutting Area (BCA) does not exist
Disc Application Code: 0 / 0 h
Extended Information indicators: 7 h
Disc Manufacturer ID: MBIPG101
Media type ID: R05
Number of Physical format information bytes in use in ADIP up to byte 63: 56
Media Specific [16..783]:
00 00 07 4D 42 49 50 47 - 31 30 31 52 30 35 01 38 ...MBIPG101R05.8
23 54 37 13 02 50 6B 02 - 8C 63 15 15 0B 0B 08 08 #T7..Pk..c......
01 19 1B 0C 0C 0C 0D 01 - 00 00 00 00 00 00 00 00 ................
01 00 38 38 02 28 60 1A - 05 2E 23 10 04 1E 1D 01 ..88.(`...#.....
00 00 02 28 60 1A 05 2E - 23 10 04 1E 1D 01 00 00 ...(`...#.......
02 00 54 70 02 2E 62 3C - 24 14 0C 0C 01 20 00 00 ..Tp..b<$.......
00 00 02 3F 66 42 24 14 - 0C 0C 01 20 00 00 00 2F ...?fB$......../
03 00 54 DF 02 2E 62 3C - 24 14 0C 0C 01 20 00 00 ..T...b<$.......
00 00 02 76 63 58 24 14 - 0C 0C 01 20 00 00 00 66 ...vcX$........f
00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................
00 00 00 00
10:45:53 #17 Text 0 File DVDR.cpp, Line 6007
Drive: HL-DT-ST BDDVDRW GGC-H20L
Book Type request [LG]: DVD-ROM
Changing the Book Type was finished successfully, return code 0
10:45:53 #18 CDR -1207 File DVDR.cpp, Line 5934
Book Type automatically set to: DVD-ROM
10:45:53 #19 Text 0 File DVDPlusRW.cpp, Line 637
Start write address at LBA 0
DVD high compatibility mode: Yes
10:45:53 #20 Text 0 File ThreadedTransfer.cpp, Line 273
Pipe memory size 83836800
10:49:52 #21 SPTI -1061 File SCSIPassThrough.cpp, Line 215
CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1061)
CDB Data: 0x2A 00 00 10 13 A0 00 00 20 00 00 00
Sense Key: 0x04 (KEY_HARDWARE_ERROR)
Sense Code: 0x44
Sense Qual: 0x86
Sense Area: 0x70 00 04 00 00 00 00 0A 35 00 04 0E 44 86
Buffer x1cdaf400: Len x10000
0x24 62 51 A6 49 6C 85 85 47 22 91 14 E6 0B A2 1A
0x0F 62 C3 B7 E3 77 57 C0 8A 34 DB AB A1 B7 E5 8C
0x2E F9 E3 85 E8 F5 80 29 E7 02 6A E7 F1 F5 7E AA
10:49:52 #22 CDR -1061 File Writer.cpp, Line 306
Internal target failure
10:49:52 #23 SPTI -1061 File SCSIPassThrough.cpp, Line 215
CDB Data: 0x35 02 00 00 00 00 00 00 00 00 00 00
Sense Code: 0x44
Sense Qual: 0x86
Sense Area: 0x71 00 04 00 00 00 00 0A 35 00 04 0E 44 86
10:49:54 #24 Text 0 File DVDPlusRW.cpp, Line 904
EndDAO: Last written address 1053600
10:49:54 #25 CDR -1061 File WriterStatus.cpp, Line 292
10:49:54 #26 TRANSFER -24 File WriterStatus.cpp, Line 292
Could not perform end of Disc-at-once
10:49:54 #27 Text 0 File DVDPlusDualLayer.cpp, Line 1452
SetDriveCaps: Set LAST LBA of layer 1 to 0
10:49:54 #28 Phase 38 File dlgbrnst.cpp, Line 1767
Burn process failed at 8x (11.080 KB/s)
10:49:54 #29 Text 0 File SCSIPTICommands.cpp, Line 267
SPTIDismountVolume - completed successfully for FSCTL_DISMOUNT_VOLUME
10:50:02 #30 Text 0 File Cdrdrv.cpp, Line 11592
DriveLocker: UnLockVolume completed
10:50:02 #31 Text 0 File SCSIPTICommands.cpp, Line 430
UnLockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL
Existing drivers:
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon
