LG GSA-H22L Problem
indeli
Dez. 2006
Hi!
Problem: Mein neuer LG GSA-H22L verweigert unter Nero hartnäckig das Brennen von DVD's mit der Meldung "Buffer zu gross". Firmware laut LG-Firmware-Update auf neuestem Stand. "Normale" CD-Roms funktionieren auch problemlos. Kann jemand das Fehler-Log interpretieren???
Gruß indeli
Windows 2000 5.0
IA32
WinAspi: -
ahead WinASPI: File 'C:\Programme\Nero\Nero 7\Core\Wnaspi32.dll': Ver=2.0.1.74, size=164112 bytes, created 02.11.2004 12:54:32
NT-SPTI used
Nero Version: 7.5.9.0
Internal Version: 7, 5, 9, 0
Recorder: <HL-DT-ST DVD-RAM GSA-H22L>Version: 1.00 - HA 1 TA 0 - 7.5.9.0
Adapter driver: <IDE> HA 1
Drive buffer : 2048kB
Bus Type : default (0) -> ATAPI, detected: ?
CD-ROM: <HL-DT-ST DVD-RAM GSA-H22L>Version: 1.00 - HA 1 TA 0 - 7.5.9.0
=== Scsi-Device-Map ===
CdRomPeripheral : HL-DT-STDVD-RAM GSA-H22L1.00 viadsk Port 0 ID 1 DMA: Off
DiskPeripheral : SAMSUNG SP0802N TK10 viadsk Port 1 ID 0 DMA: Off
=== CDRom-Device-Map ===
HL-DT-ST DVD-RAM GSA-H22L E: CDRom0
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 57671680 (0) Byte
BUFE : 0
Physical memory : 383MB (392692kB)
Free physical memory: 132MB (135384kB)
Memory in use : 65 %
Uncached PFiles: 0x0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
10.12.2006
ISO Zusammenstellung
11:32:39 #1 Text 0 File SCSIPTICommands.cpp, Line 411
LockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL
11:32:39 #2 Text 0 File Isodoc.cpp, Line 6509
Iso document burn settings
Determine maximum speed : FALSE
Simulate : FALSE
Write : TRUE
Finalize CD : FALSE
Multisession : TRUE
Multisession type: : Start multisession
Burning mode : DAO
Mode : 1
ISO Level : 1 (Max. of 11 = 8 + 3 char)
Character set : ISO 9660
Joliet : TRUE
Allow pathdepth more than 8 directories : TRUE
Allow more than 255 characters in path : TRUE
Write ISO9660 ;1 file extensions : TRUE
11:32:40 #3 ISO9660GEN -11 File Geniso.cpp, Line 3332
First writeable address = 0 (0x00000000)
11:32:40 #4 Text 0 File Burncd.cpp, Line 3451
Turn on Disc-At-Once, using DVD media
11:32:40 #5 Text 0 File DlgWaitCD.cpp, Line 306
Last possible write address on media: 2295103 (510:01.28, 4482MB)
Last address to be written: 534735 (118:49.60, 1044MB)
11:32:40 #6 Text 0 File DlgWaitCD.cpp, Line 318
Write in overburning mode: NO (enabled: CD)
11:32:40 #7 Text 0 File DlgWaitCD.cpp, Line 2903
Recorder: HL-DT-ST DVD-RAM GSA-H22L, Media type: DVD+R
Disc Manufacturer ID: MCC, Media Type ID: 004, Product revision number: 0
Disc Application Code: 0, Extended Information Indicators: 7
11:32:40 #8 Text 0 File DlgWaitCD.cpp, Line 490
>>> Protocol of DlgWaitCD activities: <<<
11:32:40 #9 Text 0 File ThreadedTransferInterface.cpp, Line 821
Setup items (after recorder preparation)
0: TRM_DATA_MODE1 ()
2 indices, index0 (150) not provided
original disc pos #0 + 534736 (534736) = #534736/118:49.61
relocatable, disc pos for caching/writing not required/ required
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 534736 blocks [E: HL-DT-ST DVD-RAM GSA-H22L]
11:32:40 #10 Text 0 File ThreadedTransferInterface.cpp, Line 1024
Prepare [E: HL-DT-ST DVD-RAM GSA-H22L] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
TOCType: 0x00; Session Closed, disc not fixated
Tracks 1 to 1: Idx 0 Idx 1 Next Trk
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 1095139328, ISRC ""
DAO layout:
___Start_|____Track_|_Idx_|_CtrlAdr_|_____Size_|______NWA_|_RecDep__________
0 | lead-in | 0 | 0x41 | 0 | 0 | 0x00
0 | 1 | 0 | 0x41 | 534736 | 0 | 0x00
0 | 1 | 1 | 0x41 | 534736 | 0 | 0x00
534736 | lead-out | 1 | 0x41 | 0 | 0 | 0x00
11:32:40 #11 Text 0 File SCSIPTICommands.cpp, Line 209
SPTILockVolume - completed successfully for FCTL_LOCK_VOLUME
11:32:40 #12 Phase 36 File dlgbrnst.cpp, Line 1746
Burn process started at 8x (11.080 KB/s)
11:33:44 #13 Text 0 File ThreadedTransferInterface.cpp, Line 2743
Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0
11:33:44 #14 Text 0 File Cdrdrv.cpp, Line 9234
---- DVD Structure: Physical Format Information (00h) ----
Media Type: 0, Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
Book Type: DVD+R (10), Part Version: 1.0x (1)
Disc Size: 120 mm, Maximum Rate: <not specified> (F h)
Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer Type: recordable
Linear Density: 0,267 um/bit, Track Density: 0,74 um/track
Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW)
End Physical Sector Number of Data Area: 26053F h
End Sector Number in Layer 0: 0 h (LBN: FFFD0000 h, 4193920 MB)
Data in Burst Cutting Area (BCA) does not exist
Disc Application Code: 0 / 0 h
Extended Information indicators: 7 h
Disc Manufacturer ID: MCC.....
Media type ID: 004
Number of Physical format information bytes in use in ADIP up to byte 63: 56
Media Specific [16..63]:
00 00 07 4D 43 43 00 00 - 00 00 00 30 30 34 00 38 ...MCC.....004.8
23 54 37 11 02 3C 6E 02 - 84 68 15 15 0B 0B 08 08 #T7..<n..h......
01 19 1B 0C 0C 0C 0D 01 - 00 00 00 00 00 00 00 00 ................
11:33:44 #15 Text 0 File DVDPlusRW.cpp, Line 674
Start write address at LBA 0
DVD high compatibility mode: No
11:33:45 #16 SPTI -31 File SCSIPassThrough.cpp, Line 179
CdRom0: SCSIStatus(x00) WinError(87) NeroError(-31)
Sense Key: 0x00 (KEY_NO_SENSE)
Sense Code: 0x00
Sense Qual: 0x00
CDB Data: 0x2A 00 00 00 00 00 00 00 20 00 00 00
Sense Area: 0x00 00 00 00 00 00 00 00 00 00 00 00 00
Buffer x080a0040: Len x10000
0x00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
11:33:45 #17 SPTI -31 File SCSIPassThrough.cpp, Line 179
Sense Code: 0x00
Sense Qual: 0x00
Buffer x06d69c40: Len x10000
11:33:45 #18 Text 0 File MMC.cpp, Line 19912
Writer-Buffer for E: HL-DT-ST DVD-RAM GSA-H22L reduced to 32768Bytes
11:33:45 #19 SPTI -31 File SCSIPassThrough.cpp, Line 179
Sense Code: 0x00
Sense Qual: 0x00
CDB Data: 0x2A 00 00 00 00 00 00 00 10 00 00 00
Buffer x06d69c40: Len x8000
11:33:45 #20 CDR -31 File Writer.cpp, Line 299
Buffer too large
11:33:45 #21 Phase 38 File dlgbrnst.cpp, Line 1746
Burn process failed at 8x (11.080 KB/s)
11:33:45 #22 Text 0 File SCSIPTICommands.cpp, Line 254
SPTIDismountVolume - completed successfully for FSCTL_DISMOUNT_VOLUME
11:33:45 #23 Text 0 File Cdrdrv.cpp, Line 10467
DriveLocker: UnLockVolume completed
11:33:45 #24 Text 0 File SCSIPTICommands.cpp, Line 411
UnLockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL
Existing drivers:
File 'Drivers\CDR4_2K.SYS': Ver=8.0.0.212 , size=2432 bytes, created 19.05.2006 22:16:24
File 'Drivers\CDRALW2K.SYS': Ver=8.0.0.212 , size=2560 bytes, created 19.05.2006 22:16:24
File 'Drivers\PXHELP20.SYS': Ver=3.00.11B, size=46080 bytes, created 16.05.2006 21:23:54 (Prassi/Veritas driver for win 2K)
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
