Hallo zusammen.
Habe mir parallel zu Win XP Knoppix installiert, will aber dass primär XP gestartet wird.
Da ich von Linux absolut keine Ahnung habe, füge ich den Inhalt der lilo.conf ein:
Wenn ich nix eingebe startet automatisch Linux, muss ansonsten immer auf other=/dev/hdc5 gehe und XP manuell starten. Da ich nix falsch machen will wäre es nett, wenn mir jemand helfen und schreiben könnte, wie ich die lilo.conf ändern muss bzw. was noch zu beachten ist.
Danke + mfg,
BFH
Code:
# /etc/lilo.conf - See: 'lilo(8)' and 'lilo.conf(5)',
# --------------- 'install-mbr(8)', '/usr/share/doc/lilo/',
# and '/usr/share/doc/mbr/'.
# | !! Reminder !! |
# | Don't forget to run 'lilo' after you make changes to this |
# | conffile, '/boot/bootmess.txt', or install a new kernel. The |
# | computer will most likely fail to boot if a kernel-image |
# | post-install script or you don't remember to run 'lilo'. |
# Support LBA for large hard disks.
lba32
# Overrides the default mapping between harddisk names and the BIOS'
# harddisk order. Use with caution.
#disk=/dev/hde
# bios=0x81
#disk=/dev/sda
# bios=0x80
# Specifies the boot device. This is where Lilo installs its boot
# block. It can be either a partition, or the raw device, in which
# case it installs in the MBR, and will overwrite the current MBR.
boot=/dev/hda
# Specifies the device that should be mounted as root. ('/')
root=/dev/hdc1
# Enable map compaction:
# Tries to merge read requests for adjacent sectors into a single
# read request. This drastically reduces load time and keeps the
# map smaller. Using 'compact' is especially recommended when
# booting from a floppy disk. It is disabled here by default
# because it doesn't always work.
# compact
# Default menu for Debian. (Using the images from debian-bootscreen)
# from Philipp Wolfer <phil@newswriter.org>.
bitmap=/usr/share/lilo/debianlilo.bmp
bmp-colors=1,,0,2,,0
bmp-table=120p,173p,1,15,17
bmp-timer=254p,432p,1,0,0
# Install the specified file as the new boot sector.
# LILO supports built in boot sectory, you only need
# to specify the type, choose one from 'text', 'menu' or 'bitmap'.
# new: install=bmp old: install=/boot/boot-bmp.b
# new: install=text old: install=/boot/boot-text.b
# new: install=menu old: install=/boot/boot-menu.b or boot.b
# default: 'menu' is default, unless you have a bitmap= line
# Note: install=bmp must be used to see the bitmap menu.
# install=menu
# install=bmp
install=bmp
# Specifies the number of _tenths_ of a second LILO should
# wait before booting the first image. LILO
# doesn't wait if DELAY is omitted or if DELAY is set to zero.
delay=20
# Prompt to use certaing image. If prompt is specified without timeout,
# boot will not take place unless you hit RETURN
prompt
timeout=50
# Specifies the location of the map file. If MAP is
# omitted, a file /boot/map is used.
map=/boot/map
# Specifies the VGA text mode that should be selected when
# booting. The following values are recognized (case is ignored):
# NORMAL select normal 80x25 text mode.
# EXTENDED select 80x50 text mode. The word EXTENDED can be
# abbreviated to EXT.
# ASK stop and ask for user input (at boot time).
# <number> use the corresponding text mode. A list of available modes
# can be obtained by booting with vga=ask and pressing [Enter].
vga=791
# You can set a password here, and uncomment the 'restricted' lines
# in the image definitions below to make it so that a password must
# be typed to boot anything but a default configuration. If a
# command line is given, other than one specified by an 'append'
# statement in 'lilo.conf', the password will be required, but a
# standard default boot will not require one.
# This will, for instance, prevent anyone with access to the
# console from booting with something like 'Linux init=/bin/sh',
# and thus becoming 'root' without proper authorization.
# Note that if you really need this type of security, you will
# likely also want to use 'install-mbr' to reconfigure the MBR
# program, as well as set up your BIOS to disallow booting from
# removable disk or CD-ROM, then put a password on getting into the
# BIOS configuration as well. Please RTFM 'install-mbr(8)'.
# password=tatercounter2000
# You can put a customized boot message up if you like. If you use
# 'prompt', and this computer may need to reboot unattended, you
# must specify a 'timeout', or it will sit there forever waiting
# for a keypress. 'single-key' goes with the 'alias' lines in the
# 'image' configurations below. eg: You can press '1' to boot
# 'Linux', '2' to boot 'LinuxOLD', if you uncomment the 'alias'.
# message=/boot/bootmess.txt
# prompt
# single-key
# delay=100
# timeout=100
# Kernel command line options that apply to all installed images go
# here. See: The 'boot-prompt-HOWO' and 'kernel-parameters.txt' in
# the Linux kernel 'Documentation' directory.
# append=""
# Boot up Linux by default.
default="Linux"
image=/boot/vmlinuz
label="Linux"
initrd=/boot/initrd.img
append="ramdisk_size=100000 init=/etc/init lang=de apm=power-off nomce quiet splash lang=de knoppix desktop=kde knoppix dma knoppix screen=1024x768"
read-only
image=/boot/vmlinuz-2.4.27
label="Linux(2.4)-1"
initrd=/boot/initrd.img-2.4.27
read-only
image=/boot/vmlinuz-2.6.7
label="Linux(2.6)-2"
initrd=/boot/initrd.img-2.6.7
read-only
# If you have another OS on this machine to boot, you can uncomment the
# following lines, changing the device name on the 'other' line to
# where your other OS' partition is.
# other=/dev/hda4
# label=HURD
# restricted
# alias=3
other=/dev/hdc5
label="WinXP/2K(hdc5)"
other=/dev/hdc6
label="WinXP/2K(hdc6)"
other=/dev/hdc7
label="WinXP/2K(hdc7)"
other=/dev/hda1
label="WinXP/2K(hda1)"
other=/dev/hda5
label="WinXP/2K(hda5)"
other=/dev/hdb1
label="WinXP/2K(hdb1)"
other=/dev/hdb5
label="WinXP/2K(hdb5)"
other=/dev/hdb6
label="WinXP/2K(hdb6)"
Danke + mfg,
BFH
(Codetags eingefügt...)
