[ 285.804157] usb 1-3: new high-speed USB device number 2 using ehci-pci
[ 285.943883] usb 1-3: New USB device found, idVendor=0bda, idProduct=8187
[ 285.943891] usb 1-3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 285.943895] usb 1-3: Product: RTL8187_Wireless_LAN_Adapter
[ 285.943899] usb 1-3: Manufacturer: Manufacturer_Realtek_RTL8187_
[ 285.943903] usb 1-3: SerialNumber: 00C0CA1B30F7
[ 286.457782] cfg80211: Calling CRDA to update world regulatory domain
[ 286.462864] cfg80211: World regulatory domain updated:
[ 286.462873] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[ 286.462877] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
[ 286.462881] cfg80211: (2457000 KHz - 2482000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
[ 286.462884] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (300 mBi, 2000 mBm)
[ 286.462888] cfg80211: (5170000 KHz - 5250000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
[ 286.462891] cfg80211: (5735000 KHz - 5835000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
[ 286.778275] ieee80211 phy0: Selected rate control algorithm 'minstrel_ht'
[ 286.778911] ieee80211 phy0: hwaddr 00:c0:ca:1b:30:f7, RTL8187vB (default) V1 + rtl8225z2, rfkill mask 2
[ 286.795914] rtl8187: Customer ID is 0xFF
[ 286.809282] rtl8187: wireless switch is on
[ 286.809526] usbcore: registered new interface driver rtl8187
[ 289.093368] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 289.094437] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 292.669031] wlan0: authenticate with c8:0e:14:57:6d:ad
[ 292.882328] wlan0: send auth to c8:0e:14:57:6d:ad (try 1/3)
[ 292.886518] wlan0: authenticated
[ 292.888475] wlan0: associate with c8:0e:14:57:6d:ad (try 1/3)
[ 293.092040] wlan0: associate with c8:0e:14:57:6d:ad (try 2/3)
[ 293.296040] wlan0: associate with c8:0e:14:57:6d:ad (try 3/3)
[ 293.500060] wlan0: association with c8:0e:14:57:6d:ad timed out
[ 531.402317] systemd-hostnamed[2141]: Warning: nss-myhostname is not installed. Changing the local hostname might make it unresolveable. Please install nss-myhostname!
[ 680.269235] usb 1-3: USB disconnect, device number 2
[ 682.504159] usb 1-3: new high-speed USB device number 3 using ehci-pci
[ 682.643770] usb 1-3: New USB device found, idVendor=0bda, idProduct=8187
[ 682.643778] usb 1-3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 682.643783] usb 1-3: Product: RTL8187_Wireless_LAN_Adapter
[ 682.643787] usb 1-3: Manufacturer: Manufacturer_Realtek_RTL8187_
[ 682.643790] usb 1-3: SerialNumber: 00C0CA1B30F7
[ 682.866080] ieee80211 phy1: Selected rate control algorithm 'minstrel_ht'
[ 682.866964] ieee80211 phy1: hwaddr 00:c0:ca:1b:30:f7, RTL8187vB (default) V1 + rtl8225z2, rfkill mask 2
[ 682.883278] rtl8187: Customer ID is 0xFF
[ 682.884396] rtl8187: wireless switch is on
[ 685.165383] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 685.166400] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 687.000383] wlan0: authenticate with c8:0e:14:57:6d:ad
[ 687.122399] wlan0: send auth to c8:0e:14:57:6d:ad (try 1/3)
[ 687.126724] wlan0: authenticated
[ 687.128662] wlan0: associate with c8:0e:14:57:6d:ad (try 1/3)
[ 687.332041] wlan0: associate with c8:0e:14:57:6d:ad (try 2/3)
[ 687.536039] wlan0: associate with c8:0e:14:57:6d:ad (try 3/3)
[ 687.740040] wlan0: association with c8:0e:14:57:6d:ad timed out
[ 696.260818] wlan0: authenticate with c8:0e:14:57:6d:ad
[ 696.418419] wlan0: send auth to c8:0e:14:57:6d:ad (try 1/3)
[ 696.422874] wlan0: authenticated
[ 696.424459] wlan0: associate with c8:0e:14:57:6d:ad (try 1/3)
[ 696.452119] wlan0: RX AssocResp from c8:0e:14:57:6d:ad (capab=0x431 status=0 aid=1)
[ 696.453044] wlan0: associated
[ 696.453095] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[ 696.453184] cfg80211: Calling CRDA for country: DE
[ 696.464912] cfg80211: Regulatory domain changed to country: DE
[ 696.464922] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[ 696.464926] cfg80211: (2400000 KHz - 2483500 KHz @ 40000 KHz), (N/A, 2000 mBm)
[ 696.464929] cfg80211: (5150000 KHz - 5250000 KHz @ 40000 KHz), (N/A, 2000 mBm)
[ 696.464932] cfg80211: (5250000 KHz - 5350000 KHz @ 40000 KHz), (N/A, 2000 mBm)
[ 696.464936] cfg80211: (5470000 KHz - 5725000 KHz @ 40000 KHz), (N/A, 2698 mBm)
[ 696.464939] cfg80211: (57240000 KHz - 65880000 KHz @ 2160000 KHz), (N/A, 4000 mBm)
Edit: Sorry da war ich wohl zu faul zum Lesen in beiderlei Hinsicht
![Augen rollen :rolleyes: :rolleyes:](/forum/styles/smilies/rolleyes.gif)
