Minidumps debuggen bzw. Ursache finden
S
Soedy
ich habe seit einiger Zeit alle 2 Tage mal nen Bluescreen, immer direkt nach dem Reboot. Ich habe nun mal den BlueScreenViewer und WinDbg probiert. Beides verweist auf die ntoskrnl.exe als Ursache. Ich vermute ein Treiberproblem. Aber wie kann ich nun sehen, welcher Treiber denn der konkrete ist?
Hier mal der Text von WinDbg:
Code:
Microsoft (R) Windows Debugger Version 6.2.9200.20512 AMD64
Copyright (c) Microsoft Corporation. All rights reserved.
Loading Dump File [C:\Users\Niels\Desktop\102215-10750-01.dmp]
Mini Kernel Dump File: Only registers and stack trace are available
Symbol search path is: *** Invalid ***
* Symbol loading may be unreliable without a symbol search path.           *
* Use .symfix to have the debugger choose a symbol path.                   *
* After setting your symbol path, use .reload to refresh symbol locations. *
Executable search path is:
* Symbols can not be loaded because symbol path is not initialized. *
* The Symbol Path can be set by:                                    *
*   using the _NT_SYMBOL_PATH environment variable.                 *
*   using the -y <symbol_path> argument when starting the debugger. *
*   using .sympath and .sympath+                                    *
Unable to load image \SystemRoot\system32\ntoskrnl.exe, Win32 error 0n2
*** WARNING: Unable to verify timestamp for ntoskrnl.exe
*** ERROR: Module load completed but symbols could not be loaded for ntoskrnl.exe
Windows 8 Kernel Version 10240 MP (4 procs) Free x64
Product: WinNt, suite: TerminalServer SingleUserTS
Built by: 10240.16545.amd64fre.th1.150930-1750
Machine Name:
Kernel base = 0xfffff802`c448b000 PsLoadedModuleList = 0xfffff802`c47b0070
Debug session time: Thu Oct 22 16:06:33.240 2015 (UTC + 2:00)
System Uptime: 0 days 23:42:28.476
Loading Kernel Symbols
Loading User Symbols
*                        Bugcheck Analysis                                    *
Use !analyze -v to get detailed debugging information.
BugCheck 50, {ffffa00288f06ed0, 0, fffff802c44d91a9, 2}
***** Kernel symbols are WRONG. Please fix symbols to do analysis.
***    Either you specified an unqualified symbol, or your debugger   ***
***    doesn't have full symbol information.  Unqualified symbol      ***
***    resolution is turned off by default. Please either specify a   ***
***    fully qualified symbol module!symbolname, or enable resolution ***
***    of unqualified symbols by typing ".symopt- 100". Note that   ***
***    enabling unqualified symbol resolution with network symbol     ***
***    server shares in the symbol path may cause the debugger to     ***
***    appear to hang for long periods of time when an incorrect      ***
***    symbol name is typed or the network symbol server is down.     ***
***    For some commands to work properly, your symbol path           ***
***    must point to .pdb files that have full type information.      ***
***    Certain .pdb files (such as the public OS symbols) do not      ***
***    contain the required information.  Contact the group that      ***
***    provided you with these symbols if you need this command to    ***
***    work.                                                          ***
***    Type referenced: nt!_KPRCB                                     ***
***    work.                                                          ***
***    Type referenced: nt!KPRCB                                      ***
***    work.                                                          ***
***    work.                                                          ***
***    work.                                                          ***
***    work.                                                          ***
***    work.                                                          ***
***    work.                                                          ***
Probably caused by : ntoskrnl.exe ( nt+4e1a9 )
Followup: MachineOwner
Im Anhang auch das .dmp File von heute. Wie kann ich das denn am Besten debuggen um den Fehler zu finden? Weiß nicht wirklich, wo ich da anfangen soll :(
Dir fehlen die Symboldateien zum debuggen.
Alles was ab Zeile 8 kommt,bezieht sich auf die fehlenden Symboldateien.
Edit:Habe die dump-datei mal durch die Msdart Absturzanalyse laufen lassen.
Vermutlich Fehlerhafter Treiber "win32kfull.sys".
Could not read faulting driver name
Probably caused by : win32kfull.sys ( win32kfull!Win32AllocPoolImpl+25 )
sfc /scannow mal laufen lassen.
Okay, danke. SFC läuft grad. Das sollte das Ganze auch reparieren? Ne Ahnung, wo die Win32KFull.sys herkommt?
Windows Systemdatei,Win32k Kernel Treiber.
