cyberpirate
Fleet Admiral Pro
- Jan. 2007
benutze Mint 17 x64 Cinnamon. Comodo File System Filter Driver startet nicht.
laut Programm soll ich diesen Befehl ausführen:
sudo /opt/COMODO/post_setup.sh
Ergebnis ist dann dieses:
Build the RedirFS kernel modules for real-time protection...
make -C /lib/modules/`uname -r`/build M=/tmp/driver/redirfs modules
make[1]: Betrete Verzeichnis '/usr/src/linux-headers-3.13.0-24-generic'
CC [M] /tmp/driver/redirfs/rfs_path.o
CC [M] /tmp/driver/redirfs/rfs_root.o
CC [M] /tmp/driver/redirfs/rfs_info.o
CC [M] /tmp/driver/redirfs/rfs_file.o
/tmp/driver/redirfs/rfs_file.c: In function ‘rfs_readdir’:
/tmp/driver/redirfs/rfs_file.c:259:37: error: ‘const struct file_operations’ has no member named ‘readdir’
if (rfile->op_old && rfile->op_old->readdir)
/tmp/driver/redirfs/rfs_file.c:260:35: error: ‘const struct file_operations’ has no member named ‘readdir’
rargs.rv.rv_int = rfile->op_old->readdir(
/tmp/driver/redirfs/rfs_file.c: In function ‘rfs_file_set_ops_dir’:
/tmp/driver/redirfs/rfs_file.c:313:15: error: ‘struct file_operations’ has no member named ‘readdir’
rfile->op_new.readdir = rfs_readdir;
make[2]: *** [/tmp/driver/redirfs/rfs_file.o] Fehler 1
make[1]: *** [_module_/tmp/driver/redirfs] Fehler 2
make[1]: Verlasse Verzeichnis '/usr/src/linux-headers-3.13.0-24-generic'
make: *** [all] Fehler 2
make -C /lib/modules/`uname -r`/build M=/tmp/driver/redirfs modules_install
DEPMOD 3.13.0-24-generic
make -C /lib/modules/`uname -r`/build M=/tmp/driver/avflt EXTRA_CFLAGS=-I/tmp/driver/redirfs modules_install
modprobe: FATAL: Module redirfs not found.
RedirFS kernel modules installation failed.
$Stopping cmdagent: The cmdagent stopped successfully!
$Starting cmdagent: The cmdagent started successfully!
$Stopping cmgdaemon: The cmgdaemon stopped successfully!
$Starting cmgdaemon: The cmgdaemon started successfully!
COMODO Antivirus is successfully configured, you can start it from Menu or Desktop
______________________________________________________________________________________________
Abschließend noch:
master65@X4 ~ $ sudo /etc/init.d/cmdavd restart
master65@X4 ~ $
Die Fehlermeldung kommt aber immer noch.
Filesytem Filter Driver is not loaded. Run diagnostic.
Was kann ich machen das Comodo richtig funktioniert?
Abschließend noch:
master65@X4 ~ $
