Mit meinem MSI B650-P Wifi mainboard Ram auf 6000mhz gesetzt
However, modern memory is DDR (double data rate), meaning data is transferred on the rising and falling edge of each clock, so advertised frequencies are twice the real clock frequency. That’s why when you set memory to 3200MHz in BIOS, CPU-Z will show 1600MHz.
