monitor not working
poojagite
Jan. 2019
Hii Everyone,
I am new to this forum and do not know if it is relevant to post this.
Still I'm wondering about the problem.
Do not know if it's a hardware or software problem.
Please Do Suggest Some Solution.
Since there is no previous post that you could be referring to, please describe your problem as detailed as possible. Also, provide additional information on the hardware in use, as well as pictures or videos showing the issue.
[QUOTE = "Mar1u5, post: 22212932, member: 648065"] Have you changed anything on your system (new GPU)?
Did you carrie your PC to a friend / somewhere else and now the GPU or other hardware is not in the slot correctly?
Have you tested another cable? [/ QUOTE]
Ya just changed my GPU because it was damaged.
Are all power connectors plugged into the gpu? Is the gpu correctly in the slot? You could update your bios (with onboard gpu if available) and try again after that (Maybe the GPU is not supported by this bios/ mainboard).
