General
Format : Matroska
Format version : Version 4
File size : 15.1 GiB
Duration : 1 h 58 min
Overall bit rate mode : Variable
Overall bit rate : 18.3 Mb/s
Writing application : mkvmerge v80.0 ('Roundabout') 64-bit
Writing library : libebml v1.4.4 + libmatroska v1.7.1
Cover : Yes
Attachments : cover.jpg
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile :
High@L4.1
Format settings : CABAC / 4 Ref Frames
Format settings, CABAC : Yes
Format settings, Reference frames : 4 frames
Codec ID : V_MPEG4/ISO/AVC
Bit rate : 12.5 Mb/s
Width : 1 920 pixels
Height : 1 036 pixels
Display aspect ratio : 1.85:1
Frame rate mode : Constant
Frame rate : 23.976 (24000/1001) FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.262
Stream size : 10.3 GiB (68%)
Writing library : x264 core 164 r3156 d46938d
Language : English
Default : Yes
Forced : No
Audio #1
Format : AC-3
Format/Info : Audio Coding 3
Commercial name : Dolby Digital
Codec ID : A_AC3
Bit rate mode : Constant
Bit rate : 384 kb/s
Channel(s) : 2 channels
Channel layout : L R
Sampling rate : 48.0 kHz
Frame rate : 31.250 FPS (1536 SPF)
Compression mode : Lossy
Stream size : 325 MiB (2%)
Title : 2.0
Language : German
Service kind : Complete Main
Default : Yes
Forced : No
Audio #2
Format : AC-3
Codec ID : A_AC3
Bit rate : 640 kb/s
Channel(s) : 6 channels
Channel layout : L R C LFE Ls Rs
Stream size : 542 MiB (3%)
Title : 5.1
Language : German
Default : No
Forced : No
Audio #3
ID in the original source medium : 4352 (0x1100)
Format : MLP FBA 16-ch
Format/Info : Meridian Lossless Packing FBA with 16-channel presentation
Commercial name : Dolby TrueHD with Dolby Atmos
Codec ID : A_TRUEHD
Bit rate mode : Variable
Bit rate : 4 028 kb/s
Maximum bit rate : 7 605 kb/s
Channel(s) : 8 channels
Channel layout : L R C LFE Ls Rs Lb Rb
Frame rate : 1 200.000 FPS (40 SPF)
Compression mode : Lossless
Stream size : 3.33 GiB (22%)
Language : English
Default : No
Forced : No
Original source medium : Blu-ray
Number of dynamic objects : 11
Bed channel count : 1 channel
Bed channel configuration : LFE
Audio #4
Format : AC-3
Codec ID : A_AC3
Bit rate : 640 kb/s
Language : English
Default : No
Forced : No
Text #1
Format : PGS
Muxing mode : zlib
Codec ID : S_HDMV/PGS
Codec ID/Info : Picture based subtitle format used on BDs/HD-DVDs
Duration : 1 h 53 min
Bit rate : 33.5 kb/s
Count of elements : 2862
Stream size : 27.1 MiB (0%)
Language : English
Default : No
Forced : No
Text #2
Format : PGS
Muxing mode : zlib
Duration : 1 h 51 min
Bit rate : 23.6 kb/s
Count of elements : 2064
Stream size : 18.9 MiB (0%)
Language : Spanish
Default : No
Forced : No
Text #3
Format : PGS
Muxing mode : zlib
Duration : 1 h 52 min
Bit rate : 25.6 kb/s
Count of elements : 2076
Stream size : 20.5 MiB (0%)
Language : English
Default : No
Forced : No
Text #4
Format : PGS
Muxing mode : zlib
Bit rate : 27.3 kb/s
Count of elements : 2078
Stream size : 21.9 MiB (0%)
Language : French
Default : No
Forced : No
Menu
00:00:00.000 : en:Chapter 01
00:06:52.996 : en:Chapter 02
00:14:30.244 : en:Chapter 03
00:22:08.327 : en:Chapter 04
00:29:06.620 : en:Chapter 05
00:33:44.856 : en:Chapter 06
00:41:30.196 : en:Chapter 07
00:48:43.129 : en:Chapter 08
00:57:07.090 : en:Chapter 09
01:02:52.102 : en:Chapter 10
01:09:43.262 : en:Chapter 11
01:14:50.403 : en:Chapter 12
01:23:50.901 : en:Chapter 13
01:30:04.858 : en:Chapter 14
01:43:06.097 : en:Chapter 15
01:49:50.459 : en:Chapter 16
