allinonemovie
- Jan. 2015
Ich bin hier gerade etwas am verzweifeln. Wenn ich versuche den mysql-server zu installieren tritt immer folgender Fehler auf:
ich installiere ganz normal per apt-get install mysql-server. Auch wenn ich versuche das ganze nochmal zu deinstallieren kommt die gleiche Fehlermeldung. Hat irgendjemand eine Idee? Wahrscheinlich ist es mal wieder ein Anfängerfehler...
Vielen Dank!
Code:
Reading package lists... Done
Building dependency tree
Reading state information... Done
The following NEW packages will be installed:
mysql-server
0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
1 not fully installed or removed.
Need to get 0 B/71.7 kB of archives.
After this operation, 119 kB of additional disk space will be used.
debconf: unable to initialize frontend: Dialog
debconf: (No usable dialog-like program is installed, so the dialog based frontend cannot be used. at /usr/share/perl5/Debconf/FrontEnd/Dialog.pm line 76, <> line 1.)
debconf: falling back to frontend: Readline
Selecting previously unselected package mysql-server.
(Reading database ... 22900 files and directories currently installed.)
Unpacking mysql-server (from .../mysql-server_5.5.43-0+deb7u1_all.deb) ...
Setting up mysql-server-5.5 (5.5.43-0+deb7u1) ...
debconf: (No usable dialog-like program is installed, so the dialog based frontend cannot be used. at /usr/share/perl5/Debconf/FrontEnd/Dialog.pm line 76.)
[ ok ] Stopping MySQL database server: mysqld.
/var/lib/dpkg/info/mysql-server-5.5.postinst: line 146: logger: command not found
ATTENTION: An error has occured. More info is in the syslog!
/var/lib/dpkg/info/mysql-server-5.5.postinst: line 236: logger: command not found
dpkg: error processing mysql-server-5.5 (--configure):
subprocess installed post-installation script returned error exit status 127
dpkg: dependency problems prevent configuration of mysql-server:
mysql-server depends on mysql-server-5.5; however:
Package mysql-server-5.5 is not configured yet.
dpkg: error processing mysql-server (--configure):
dependency problems - leaving unconfigured
Errors were encountered while processing:
mysql-server-5.5
mysql-server
E: Sub-process /usr/bin/dpkg returned an error code (1)
Vielen Dank!
