ich habe eben routinemäßig nach Updates gesucht und bin dabei auf die neue Firmware 2030 für die Supertalent Ultradrives GX und GX2 gestoßen. (release 24.06.2010)
http://www.supertalent.com/support/driver_download.php#
War das schon bekannt? Ich habe hier noch nichts gefunden.
Hat schon wer Erfahrungen damit gemacht?
Hier mal die Releasenotes:
1.0 FIRMWARE VERSION 2030 (AFTER 1916)
Release Date: 6/24/10
Serial Numbers: xxxxxxx‐xJBx/xJCx/xJDx/xJDx‐xxxxxxx
Change Log:
‐ Feature Add: User data scrambling capability was added. Original 1916 release did not have it.
Later, it was applied as hot fix to 1916 firmware.
‐ Feature Add: Vendor command (0xFE) was added to support LBA to NAND bank mapping
capability.
‐ Bug Fix: End user updater failure problem was fixed.
‐ Bug Fix: More read fail scenarios were added to firmware bad block management.
‐ Bug Fix: ATA Security bug fixes. Following improvements were made.
• Ignoring user password at SEC1
• IDENTIFY will reflect current ATA security status more correctly.
• Changed master password revision code to FFFE
‐ Bug Fix: SMART self test progress status nibble value was wrong when completed. It should
remain at 0, not going back to 9.
‐ Bug Fix: In some rare situation, SSD power cycling may not be accompanied with IDENTIFY. In
such case, SMART power cycle count was not increased.
‐ Bug Fix: The status for SMART Enable/Disable and SMART attribute autosave were changed by
power cycling. It should retain the last change status permanently.
‐ Other: For SATA Gen 1 setting, Gen 2 support bit is better to be cleared.
‐ Other: For sleep/standby command, idle time garbage collection is better to be not started.
‐ Other: When DIPM is disabled by FW build option, IDENTIFY word 78 bit 3 is better to be
cleared.
‐ Other: Changed word 60 bit 14 to 0, meaning trim is not deterministic for smaller size than
16KB trim request.
‐ Other: Update Maximum PE cycles value as following. Samsung 5x nm NAND : 10k ‐> 5k,
Samsung 4x nm NAND : 10k ‐> 3k, Intel/Micron 3x nm NAND : 10k ‐> 5k, Hynix 41nm : 10k ‐>
5k, Hynix 32nm : 5k ‐> 3k
UPDATE vom 03.07.:
Habe die FW heute aufgespielt, als ISO gebrannt, Im BIOS AHCI deaktivert, CD booten lassen, FW drauf, AHCI wie aktiviert. Fertig.
WIN7 läuft weiterhin, vorher sollte dennoch ein Backup gemacht werden.
Ergebnis: Die SSD ist wieder so frisch wie am ersten Tag mit Lesegeschwindigkeiten von 220MB/Sek.
Vor dem FW-Updaten war der Speed trotz TRIM auf 170MB/sek runter.
Mein Fazit: UPDATEN!
UPDATE 2 vom 05.07.:
Zufällig mache ich eben mein CrystalDiskInfo auf und plötzlich ist der GEsamtzustand der SSD von 91% auf 80% gesunken....
Kann mir das jemand erklären?
Change Log:
capability.
cleared.
16KB trim request.
UPDATE vom 03.07.:
