U
Unregistered
http://people.opera.com/windows/snapshot/o602_1078.exe
Opera changelog between build 1066 and 1078:
[core]
* Fixed bug #66302 printing of comboboxes
* Method added for supressing js-alerts, active just for current page.
Should fix problems like seen on
http://mindstorms.lego.com/products/vc/index.asp
* improved unescaping of save file names and mail attachments
* Fixed another problem with deleting keys from INI files; the deleted
keys would be revived if flush was called before commit.
* Fixed conversion of '\' into '/' in query part of URL on nasdaq.com
* prevent recursive search calls if type 0(SEARCH_TYPE_GOOGLE) or
1(SEARCH_TYPE_FAST) is defined as 2(SEARCH_TYPE_SUPERSEARCH). Search
entry one and two cannot
be defined as supersearch. "Supersearch" is a doublesearch of entry
one and two.
* added simple sanechecking on search-url's. Does not perform search
if the string doesn't contain %s
* korean language handled in WindowsOpFontManager::GetFontInfo; should
fix some display problems on korean systems
* added /KioskResetStation, only works in kiosk mode. Timer settings
is set via opera.ini [Special] Go Home Time Out=xx where xx>30 &
xx<6000
* Bug#62821: Never decode non-ASCII %xx-escapes when in "do not use
UTF-8 in URLs" mode, as it messes up the display of many URLs.
* Bug#72633: Mismatch in space handling in layout and actual display.
* Force reload when doing 'reload image' from right-click menu
* Attempt to fix problem with broken images when working through some
adbuster proxies. PLEASE NOTE: Broken images WILL appear just before
the new handling
activates.
* url filtering is now functional; exclude list has precedence over
include example under will block loading of , jpg, gif and png
pictures. ====example====
[include] http://*.*/ [exclude] http://*.gif/ http://*.jpg/ http://*.png/
url-filter file is defined in opera.ini [Adv User Prefs] URL Filter
File= which is a standard ini-file with [exclude] and [include],
supports * and ? as
wildcards
* Only add whitespace between lines in GetInlineElementText if there
already is text on previous lines. Will fix problems with
<a><br>text</a> in "Links in
Frame"-dialog
* Fix for broken uploads
[script]
* Fix for bug 66351: "" converted to number yielded NaN, not 0.
* Fix for bug 55852: failure sound was played on many javascript: URLs
because HandleLoadingFailed is called for such URLs but a 'failure
handled' error code was
not honored.
[ui]
* fixed bug 70733; js/url-pass warning did not have parent
* added /NoMenu commandline option
* added /NoHotlist commandline option
* fixed a crasher in the prefs dialog (Browser Look->Fonts And
Colors): crash if a previously selected font is missing from the
system
* fixed size of control in COOKIEDOMAINERR, cropped text reported on
norwegian translation
* fix for bug #71772: "[602_ASIAN]Title can't display" - will display
URL instead of question marks in window title
* fix for bug #71703: "cannot copy Chinese text from opera window" -
removed win9x check; text is now copied to clipboard as CF_TEXT and
CF_UNICODETEXT on all
Windows versions
* register Opera as an startmenu internet application on XP systems
when setting as default browser
* added new commandline functionality /FullscreenToolbar will show
main toolbar in fullscreen, handy in kioskmode. And removed ability to
press Esc to exit
fullscreen in kioskmode
* attempt to fix crash bug 70383, crash on startup
* block 'Windows-keys' and applicationkey when in kioskmode
* bug 55767 revisited - if the first item in a submenu were grayed,
navigating using right arrow key did not work
* added /FullscreenWindowbar and /NoContextMenu menuline commands;
/FullscreenWindowbar displays windowbar in fullscreen.
/NoContextMenu disables all contextmenues, except editfield menues
* added /ClearHistoryOnExit commandline option, will clear private
data on exit
[news]
* Make absolutely sure ecmascript is disabled in news-windows
[mail]
* fixed crash when right-clicking mail in list
* mails with attachments would sometimes be much bigger than necessary
due to appended redundancy
* fixes crasher and unicode problems with mail signatures
* added new mail setting to favour plain text display over HTML when
possible: ACCOUNT.INI, [SETTINGS], PreferPlaintext=1
* pressing SHIFT + DELETE now deletes a mail without moving it to
trash
* pressing c in the mail list now places the raw unparsed mail on the
clipboard, e.g. for spam reporting
* big speed improvement when deleting/moving mails in large folders,
fixed shrinking of MBS file when last mail is deleted
[core]
one and two.
xx<6000
the new handling
activates.
supports * and ? as
wildcards
Frame"-dialog
[script]
not honored.
[ui]
system
Windows versions
press Esc to exit
data on exit
[news]
[mail]
trash
