nextcloud startet nach debian buster upgrade nicht mehr
lordg2009
Apr. 2009
habe heute mein Linux Server auf debian buaster geupgraded. Hat auch alles ganz gut geklappt, aber nextcloud startet jetzt nicht mehr. Es kommt folgende Fehlermeldung:
Internal Server Error
The server encountered an internal error and was unable to complete your request.
Please contact the server administrator if this error reappears multiple times, please include the technical details below in your report.
More details can be found in the server log.
Folgende sind die letzte Zeile meiner nextcloudlogfile
{"reqId":"bXqeOA9G5mF5txn5hkKx","level":3,"time":"2019-08-12T20:14:14+00:00","remoteAddr":"141.30.247.131","user":"--","app":"remote","method":"GET","url":"\/status.php","message":{"Exception":"OC\\HintException","Message":"Memcache \\OC\\Memcache\\APCu not available for local cache","Code":0,"Trace":[{"file":"\/var\/www\/nextcloud\/lib\/private\/Server.php","line":511,"function":"construct","class":"OC\\Memcache\\Factory","type":"->","args":["0888680d76e9e91b0384fa8ee9a21021",{"__class":"OC\\Log"},"\\OC\\Memcache\\APCu","\\OC\\Memcache\\APCu",null]},{"file":"\/var\/www\/nextcloud\/3rdparty\/pimple\/pimple\/src\/Pimple\/Container.php","line":118,"function":"OC\\{closure}","class":"OC\\Server","type":"->","args":["* sensitive parameters replaced *"]},{"file":"\/var\/www\/nextcloud\/lib\/private\/AppFramework\/Utility\/SimpleContainer.php","line":117,"function":"offsetGet","class":"Pimple\\Container","type":"->","args":["OC\\Memcache\\Factory"]},{"file":"\/var\/www\/nextcloud\/lib\/private\/ServerContainer.php","line":132,"function":"query","class":"OC\\AppFramework\\Utility\\SimpleContainer","type":"->","args":["OC\\Memcache\\Factory"]},{"file":"\/var\/www\/nextcloud\/lib\/private\/AppFramework\/Utility\/SimpleContainer.php","line":165,"function":"query","class":"OC\\ServerContainer","type":"->","args":["OC\\Memcache\\Factory"]},{"file":"\/var\/www\/nextcloud\/3rdparty\/pimple\/pimple\/src\/Pimple\/Container.php","line":114,"function":"OC\\AppFramework\\Utility\\{closure}","class":"OC\\AppFramework\\Utility\\SimpleContainer","type":"->","args":["* sensitive parameters replaced *"]},{"file":"\/var\/www\/nextcloud\/lib\/private\/AppFramework\/Utility\/SimpleContainer.php","line":117,"function":"offsetGet","class":"Pimple\\Container","type":"->","args":["MemCacheFactory"]},{"file":"\/var\/www\/nextcloud\/lib\/private\/ServerContainer.php","line":132,"function":"query","class":"OC\\AppFramework\\Utility\\SimpleContainer","type":"->","args":["MemCacheFactory"]},{"file":"\/var\/www\/nextcloud\/lib\/private\/Server.php","line":1533,"function":"query","class":"OC\\ServerContainer","type":"->","args":["MemCacheFactory"]},{"file":"\/var\/www\/nextcloud\/lib\/private\/Server.php","line":697,"function":"getMemCacheFactory","class":"OC\\Server","type":"->","args":[]},{"file":"\/var\/www\/nextcloud\/3rdparty\/pimple\/pimple\/src\/Pimple\/Container.php","line":118,"function":"OC\\{closure}","class":"OC\\Server","type":"->","args":["* sensitive parameters replaced *"]},{"file":"\/var\/www\/nextcloud\/lib\/private\/AppFramework\/Utility\/SimpleContainer.php","line":117,"function":"offsetGet","class":"Pimple\\Container","type":"->","args":["OC\\App\\AppManager"]},{"file":"\/var\/www\/nextcloud\/lib\/private\/ServerContainer.php","line":132,"function":"query","class":"OC\\AppFramework\\Utility\\SimpleContainer","type":"->","args":["OC\\App\\AppManager"]},{"file":"\/var\/www\/nextcloud\/lib\/private\/AppFramework\/Utility\/SimpleContainer.php","line":165,"function":"query","class":"OC\\ServerContainer","type":"->","args":["OC\\App\\AppManager"]},{"file":"\/var\/www\/nextcloud\/3rdparty\/pimple\/pimple\/src\/Pimple\/Container.php","line":114,"function":"OC\\AppFramework\\Utility\\{closure}","class":"OC\\AppFramework\\Utility\\SimpleContainer","type":"->","args":["* sensitive parameters replaced *"]},{"file":"\/var\/www\/nextcloud\/lib\/private\/AppFramework\/Utility\/SimpleContainer.php","line":117,"function":"offsetGet","class":"Pimple\\Container","type":"->","args":["AppManager"]},{"file":"\/var\/www\/nextcloud\/lib\/private\/ServerContainer.php","line":132,"function":"query","class":"OC\\AppFramework\\Utility\\SimpleContainer","type":"->","args":["AppManager"]},{"file":"\/var\/www\/nextcloud\/lib\/private\/Server.php","line":1723,"function":"query","class":"OC\\ServerContainer","type":"->","args":["AppManager"]},{"file":"\/var\/www\/nextcloud\/lib\/private\/legacy\/app.php","line":342,"function":"getAppManager","class":"OC\\Server","type":"->","args":[]},{"file":"\/var\/www\/nextcloud\/lib\/private\/legacy\/app.php","line":113,"function":"getEnabledApps","class":"OC_App","type":"::","args":[]},{"file":"\/var\/www\/nextcloud\/lib\/base.php","line":654,"function":"loadApps","class":"OC_App","type":"::","args":[["session"]]},{"file":"\/var\/www\/nextcloud\/lib\/base.php","line":1068,"function":"init","class":"OC","type":"::","args":[]},{"file":"\/var\/www\/nextcloud\/status.php","line":36,"args":["\/var\/www\/nextcloud\/lib\/base.php"],"function":"require_once"}],"File":"\/var\/www\/nextcloud\/lib\/private\/Memcache\/Factory.php","Line":99,"Hint":"Is the matching PHP module installed and enabled?","CustomMessage":"--"},"userAgent":"Mozilla\/5.0 (Windows) mirall\/2.3.3 (build 1) (Nextcloud)","version":"15.0.10.0"}
Hat da jemand eine Idee?
Jep, merkwürdigerweise get es immer noch nicht. Aber in der Fehlermeldung steht weiterhin memcache, dabei habe ich die Option in der config php ausgeklammert
Habs lösten können. Nach Upgrade war php mit php7.3 verlinkt, gleichzeitig aber auch php 7.0 installiert und apache2 hat noch das php 7.0module genutzt. php-Module nachgeladen und aktiviert und jetzt geht es.
Reaktionen: FranzvonAssisi
