Notebook Bluescreen beim "Standby"
Apr. 2018
Hallo Leute
Seit einer Woche oder so krieg ich beim zuklappen oder wen der Notebook in Ruhezustand will enen Bluescreen und er schaltet ab...
Im Anhand noch die dmp File
Hier ein Paar infos die ich zusammen sammeln konnte:
Code:
Microsoft (R) Windows Debugger Version 6.12.0002.633 AMD64
Copyright (c) Microsoft Corporation. All rights reserved.
Loading Dump File [C:\Windows\Minidump\052218-26629-01.dmp]
Mini Kernel Dump File: Only registers and stack trace are available
DbsSplayTreeRangeMap::Add: ignoring zero-sized range at ?fffff8a0`02443322?
DbsSplayTreeRangeMap::Add: ignoring zero-sized range at ?fffff8a0`0022f022?
DbsSplayTreeRangeMap::Add: ignoring zero-sized range at ?fffff800`00b9c550?
Symbol search path is: SRV*C:\symbols*http://msdl.microsoft.com/download/symbols
Executable search path is:
Windows 7 Kernel Version 7601 (Service Pack 1) MP (8 procs) Free x64
Product: WinNt, suite: TerminalServer SingleUserTS
Built by: 7601.24093.amd64fre.win7sp1_ldr_escrow.180327-2230
Machine Name:
Kernel base = 0xfffff800`02e0b000 PsLoadedModuleList = 0xfffff800`0304ac90
Debug session time: Tue May 22 14:46:30.807 2018 (UTC + 2:00)
System Uptime: 15 days 3:53:29.261
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
*                        Bugcheck Analysis                                    *
Use !analyze -v to get detailed debugging information.
BugCheck 9F, {3, fffffa80063cba10, fffff80000b9c568, fffffa8009236bb0}
Probably caused by : pci.sys
Followup: MachineOwner
0: kd> !analyze -v
DRIVER_POWER_STATE_FAILURE (9f)
A driver is causing an inconsistent power state.
Arguments:
Arg1: 0000000000000003, A device object has been blocking an Irp for too long a time
Arg2: fffffa80063cba10, Physical Device Object of the stack
Arg3: fffff80000b9c568, Functional Device Object of the stack
Arg4: fffffa8009236bb0, The blocked IRP
Debugging Details:
DRVPOWERSTATE_SUBCODE:  3
IMAGE_NAME:  pci.sys
DEBUG_FLR_IMAGE_TIMESTAMP:  4ce7928f
MODULE_NAME: pci
FAULTING_MODULE: fffff88000f82000 pci
CUSTOMER_CRASH_COUNT:  1
DEFAULT_BUCKET_ID:  VISTA_DRIVER_FAULT
BUGCHECK_STR:  0x9F
PROCESS_NAME:  System
CURRENT_IRQL:  2
STACK_TEXT:
fffff800`00b9c518 fffff800`02ee1880 : 00000000`0000009f 00000000`00000003 fffffa80`063cba10 fffff800`00b9c568 : nt!KeBugCheckEx
fffff800`00b9c520 fffff800`02e6a305 : fffff800`00b9c678 fffff800`00b9c678 fffffa80`0ad35c58 00000000`00000000 : nt! ?? ::FNODOBFM::`string'+0x1db00
fffff800`00b9c5c0 fffff800`02e6be8e : 00000bea`1a5def5f fffff800`00b9cc58 00000000`0501590e fffff800`02ff7f48 : nt!KiProcessExpiredTimerList+0x105
fffff800`00b9cc30 fffff800`02e6c157 : fffff800`02ff51c7 fffff800`0501590e 000001db`6512cf88 00000000`0000000e : nt!KiTimerExpiration+0x1be
fffff800`00b9ccd0 fffff800`02eb2b4a : fffff800`02ff5180 fffff800`030051c0 00000000`00000001 fffff880`00000000 : nt!KiRetireDpcList+0x277
fffff800`00b9cd80 00000000`00000000 : fffff800`00b9d000 fffff800`00b97000 fffff800`00b9cd40 00000000`00000000 : nt!KiIdleLoop+0x5a
STACK_COMMAND:  kb
FOLLOWUP_NAME:  MachineOwner
FAILURE_BUCKET_ID:  X64_0x9F_3_NETw5s64_IMAGE_pci.sys
Klingt ziemlich nach Grafikkarten Treiberfehler.
Und ab und vllt auch mal Neustarten bei einer System Uptime von 15 Tagen.
Komisch das sowas steht.... der macht es ja von alleine :evillol:
So.... Das Problem scheint behoben zu sein... hab einen aktuellen Nvidia Treiber installiert...
Scheint so als ob er es vorhin nur aus dem Windows Update gezogen hatte.
Danke für die Hilfe
