linux-blv7:/home/johannes # lspci -v
00:00.0 Host bridge: nVidia Corporation nForce2 AGP (different version?) (rev c1)
Flags: bus master, 66MHz, fast devsel, latency 0
Memory at d0000000 (32-bit, prefetchable) [size=128M]
Capabilities: [40] AGP version 2.0
Capabilities: [60] HyperTransport: Host or Secondary Interface
00:00.1 RAM memory: nVidia Corporation nForce2 Memory Controller 1 (rev c1)
Subsystem: EPoX Computer Co., Ltd. Unknown device 100f
Flags: 66MHz, fast devsel
00:00.2 RAM memory: nVidia Corporation nForce2 Memory Controller 4 (rev c1)
00:00.3 RAM memory: nVidia Corporation nForce2 Memory Controller 3 (rev c1)
00:00.4 RAM memory: nVidia Corporation nForce2 Memory Controller 2 (rev c1)
00:00.5 RAM memory: nVidia Corporation nForce2 Memory Controller 5 (rev c1)
00:01.0 ISA bridge: nVidia Corporation MCP2A ISA bridge (rev a3)
Capabilities: [48] HyperTransport: Slave or Primary Interface
00:01.1 SMBus: nVidia Corporation MCP2A SMBus (rev a1)
Flags: 66MHz, fast devsel, IRQ 9
I/O ports at e000 [size=32]
Capabilities: [44] Power Management version 2
00:02.0 USB Controller: nVidia Corporation MCP2A USB Controller (rev a1) (prog-if 10 [OHCI])
Flags: bus master, 66MHz, fast devsel, latency 0, IRQ 185
Memory at eb003000 (32-bit, non-prefetchable) [size=4K]
00:02.1 USB Controller: nVidia Corporation MCP2A USB Controller (rev a1) (prog-if 10 [OHCI])
Flags: bus master, 66MHz, fast devsel, latency 0, IRQ 193
Memory at eb004000 (32-bit, non-prefetchable) [size=4K]
00:02.2 USB Controller: nVidia Corporation MCP2A USB Controller (rev a2) (prog-if 20 [EHCI])
Memory at eb005000 (32-bit, non-prefetchable) [size=256]
Capabilities: [44] Debug port
Capabilities: [80] Power Management version 2
00:04.0 Bridge: nVidia Corporation MCP2A Ethernet Controller (rev a3)
Memory at eb000000 (32-bit, non-prefetchable) [size=4K]
I/O ports at e100 [size=8]
00:06.0 Multimedia audio controller: nVidia Corporation MCP2S AC'97 Audio Controller (rev a1)
Subsystem: EPoX Computer Co., Ltd. Unknown device 100e
I/O ports at e200 [size=256]
I/O ports at e300 [size=128]
Memory at eb001000 (32-bit, non-prefetchable) [size=4K]
00:08.0 PCI bridge: nVidia Corporation MCP2A PCI Bridge (rev a3) (prog-if 00 [Normal decode])
Bus: primary=00, secondary=01, subordinate=01, sec-latency=32
Memory behind bridge: ea000000-eaffffff
00:09.0 IDE interface: nVidia Corporation MCP2A IDE (rev a3) (prog-if 8a [Master SecP PriP])
I/O ports at f000 [size=16]
00:0b.0 IDE interface: nVidia Corporation nForce2 Serial ATA Controller (rev a3) (prog-if 85 [Master SecO PriO])
Flags: bus master, 66MHz, fast devsel, latency 0, IRQ 177
I/O ports at 09f0 [size=8]
I/O ports at 0bf0 [size=5]
I/O ports at 0970 [size=8]
I/O ports at 0b70 [size=5]
I/O ports at ea00 [size=16]
I/O ports at eb00 [size=128]
00:1e.0 PCI bridge: nVidia Corporation nForce2 AGP (rev c1) (prog-if 00 [Normal decode])
Flags: bus master, 66MHz, medium devsel, latency 32
Bus: primary=00, secondary=02, subordinate=02, sec-latency=32
Memory behind bridge: e8000000-e9ffffff
Prefetchable memory behind bridge: d8000000-e7ffffff
01:0b.0 Network controller: RaLink RT2500 802.11g Cardbus/mini-PCI (rev 01)
Subsystem: Micro-Star International Co., Ltd. Unknown device 6834
Flags: bus master, slow devsel, latency 32, IRQ 5
Memory at ea000000 (32-bit, non-prefetchable) [size=8K]
Capabilities: [40] Power Management version 2
02:00.0 VGA compatible controller: nVidia Corporation NV25 [GeForce4 Ti 4200] (rev a3) (prog-if 00 [VGA])
Flags: bus master, 66MHz, medium devsel, latency 32, IRQ 5
Memory at e8000000 (32-bit, non-prefetchable) [size=16M]
Memory at d8000000 (32-bit, prefetchable) [size=128M]
Memory at e0000000 (32-bit, prefetchable) [size=512K]
[virtual] Expansion ROM at e0080000 [disabled] [size=128K]
Capabilities: [60] Power Management version 2
Capabilities: [44] AGP version 2.0
