login as: pi
pi@192.168.188.16's password:
Linux openhabian 5.10.63-v7l+ #1488 SMP Thu Nov 18 16:15:28 GMT 2021 armv7l
The programs included with the Debian GNU/Linux system are free software;
the exact distribution terms for each program are described in the
individual files in /usr/share/doc/*/copyright.
Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
permitted by applicable law.
Last login: Sun Jan 2 16:01:44 2022 from 192.168.188.6
pi@openhabian:~ $ sudo systemctl status openhab.service
● openhab.service - openHAB instance, reachable at http://openhabian:8080
Loaded: loaded (/lib/systemd/system/openhab.service; enabled; vendor prese>
Drop-In: /etc/systemd/system/openhab.service.d
└─override.conf
Active: active (running) since Sun 2022-01-02 15:23:19 CET; 44min ago
Docs: https://www.openhab.org/docs/
https://community.openhab.org
Main PID: 1259 (java)
Tasks: 41 (limit: 4915)
CPU: 48.619s
CGroup: /system.slice/openhab.service
└─1259 /usr/bin/java -XX:-UsePerfData -Dopenhab.home=/usr/share/op>
Jan 02 15:24:35 openhabian karaf[1259]: at java.base/java.lang.Thread.r>
Jan 02 15:24:35 openhabian karaf[1259]: Caused by: org.apache.felix.resolver.re>
Jan 02 15:24:35 openhabian karaf[1259]: at org.apache.felix.resolver.Ca>
Jan 02 15:24:35 openhabian karaf[1259]: ... 12 more
Jan 02 15:24:35 openhabian karaf[1259]: ... 13 more
Jan 02 15:24:35 openhabian karaf[1259]: ... 14 more
lines 1-23...skipping...
Loaded: loaded (/lib/systemd/system/openhab.service; enabled; vendor preset: enabled)
└─override.conf
CPU: 48.619s
└─1259 /usr/bin/java -XX:-UsePerfData -Dopenhab.home=/usr/share/openhab -Dopenhab.conf=/etc/openhab -Dopenhab.runtime=/usr/share/openhab/runtime -Dopenhab.userdata=/var/lib/op>
Jan 02 15:24:35 openhabian karaf[1259]: at java.base/java.lang.Thread.run(Thread.java:844)
Jan 02 15:24:35 openhabian karaf[1259]: Caused by: org.apache.felix.resolver.reason.ReasonException: Unable to resolve openhab-runtime-ui/3.2.0: missing requirement [openhab-runtime-ui/3.2>
Jan 02 15:24:35 openhabian karaf[1259]: at org.apache.felix.resolver.Candidates$MissingRequirementError.toException(Candidates.java:1341)
Jan 02 15:24:35 openhabian karaf[1259]: Caused by: org.apache.felix.resolver.reason.ReasonException: Unable to resolve org.openhab.ui/3.2.0: missing requirement [org.openhab.ui/3.2.0] osgi>
Jan 02 15:24:35 openhabian karaf[1259]: Caused by: org.apache.felix.resolver.reason.ReasonException: Unable to resolve org.openhab.core/3.2.0: missing requirement [org.openhab.core/3.2.0] >
