firebal
- Dez. 2007
habe win 7 x64 mit java 32 bit drauf
aber egal welche Datei ich von dem Ps3 Media Server aus dem x64 Ordner starte, startet die pms.exe nicht als 64 bit .exe es passiert garnichts
und irgendiwie findet er den Samsung TV nicht obwohl ich ihn sogar neustarte und er manchmal da ist:
eben konnt ich 30 min was gucken per DLNA dann hat er aufeinmal die Verbindung zum server getrennt, in der LOG steht dazu aber nur stopped playing blabla
INFO 2014-06-19 17:05:12.758 [main] Starting PS3 Media Server 1.90.1
INFO 2014-06-19 17:05:12.759 [main] by shagrath / 2008-2013
INFO 2014-06-19 17:05:12.759 [main] http://ps3mediaserver.org
INFO 2014-06-19 17:05:12.759 [main] https://github.com/ps3mediaserver/ps3mediaserver
INFO 2014-06-19 17:05:12.760 [main]
INFO 2014-06-19 17:05:12.760 [main] Build: 3a4304c72 (2013-08-17)
INFO 2014-06-19 17:05:12.760 [main] Java: Java HotSpot(TM) 64-Bit Server VM 1.7.0_25 by Oracle Corporation
INFO 2014-06-19 17:05:12.760 [main] OS: Windows 7 amd64 6.1
INFO 2014-06-19 17:05:12.760 [main] Encoding: UTF-8
INFO 2014-06-19 17:05:12.775 [main] Memory: 682 MB
INFO 2014-06-19 17:05:12.775 [main] Working directory: C:\Program Files (x86)\PS3 Media Server
INFO 2014-06-19 17:05:12.782 [main] Temp directory: C:\Users\admin\AppData\Local\Temp\ps3mediaserver
INFO 2014-06-19 17:05:12.783 [main] Logging config file: C:\Program Files (x86)\PS3 Media Server\logback.xml
INFO 2014-06-19 17:05:12.784 [main] debug.log: C:\ProgramData\PMS\debug.log
INFO 2014-06-19 17:05:12.784 [main] Profile directory: C:\ProgramData\PMS
INFO 2014-06-19 17:05:12.785 [main] Profile directory permissions: rw
INFO 2014-06-19 17:05:12.786 [main] Profile path: C:\ProgramData\PMS\PMS.conf
INFO 2014-06-19 17:05:12.786 [main] Profile permissions: rw
INFO 2014-06-19 17:05:12.786 [main] Profile name: admin-PC
INFO 2014-06-19 17:05:12.787 [main]
INFO 2014-06-19 17:05:12.787 [main] Web conf path: C:\ProgramData\PMS\WEB.conf
INFO 2014-06-19 17:05:12.787 [main] Web conf permissions: file not found
INFO 2014-06-19 17:05:13.454 [main] Checking shared folder: D:\backup 1tb\Prison.Break
INFO 2014-06-19 17:05:13.725 [main] Loading MediaInfo library
INFO 2014-06-19 17:05:13.798 [main] Loaded MediaInfoLib - v0.7.62
INFO 2014-06-19 17:05:13.803 [main] Loading renderer configurations from C:\Program Files (x86)\PS3 Media Server\renderers
INFO 2014-06-19 17:05:13.804 [main] Loading configuration file: AirPlayer.conf
INFO 2014-06-19 17:05:13.809 [main] Loading configuration file: Android.conf
INFO 2014-06-19 17:05:13.811 [main] Loading configuration file: BlackBerryPlayBook-KalemSoftMP.conf
INFO 2014-06-19 17:05:13.817 [main] Loading configuration file: Bravia4500.conf
INFO 2014-06-19 17:05:13.821 [main] Loading configuration file: Bravia5500.conf
INFO 2014-06-19 17:05:13.824 [main] Loading configuration file: BraviaEX.conf
INFO 2014-06-19 17:05:13.830 [main] Loading configuration file: BraviaEX620.conf
INFO 2014-06-19 17:05:13.835 [main] Loading configuration file: BraviaHX.conf
INFO 2014-06-19 17:05:13.841 [main] Loading configuration file: BraviaW.conf
INFO 2014-06-19 17:05:13.846 [main] Loading configuration file: DirecTVHR.conf
INFO 2014-06-19 17:05:13.851 [main] Loading configuration file: DLinkDSM510.conf
INFO 2014-06-19 17:05:13.854 [main] Loading configuration file: FreeboxHD.conf
INFO 2014-06-19 17:05:13.856 [main] Loading configuration file: FreecomMusicPal.conf
INFO 2014-06-19 17:05:13.859 [main] Loading configuration file: iPad-iPhone.conf
INFO 2014-06-19 17:05:13.862 [main] Loading configuration file: Kuro.conf
INFO 2014-06-19 17:05:13.865 [main] Loading configuration file: LGST600.conf
INFO 2014-06-19 17:05:13.869 [main] Loading configuration file: N900.conf
INFO 2014-06-19 17:05:13.871 [main] Loading configuration file: NetgearNeoTV.conf
INFO 2014-06-19 17:05:13.874 [main] Loading configuration file: OnkyoTX-NR717.conf
INFO 2014-06-19 17:05:13.876 [main] Loading configuration file: OPPOBDP83.conf
INFO 2014-06-19 17:05:13.878 [main] Loading configuration file: OPPOBDP93.conf
INFO 2014-06-19 17:05:13.880 [main] Loading configuration file: Panasonic.conf
INFO 2014-06-19 17:05:13.884 [main] Loading configuration file: Philips.conf
INFO 2014-06-19 17:05:13.887 [main] Loading configuration file: PhilipsPFL.conf
INFO 2014-06-19 17:05:13.892 [main] Loading configuration file: PopcornHour.conf
INFO 2014-06-19 17:05:13.894 [main] Loading configuration file: PS3.conf
INFO 2014-06-19 17:05:13.898 [main] Loading configuration file: Realtek.conf
INFO 2014-06-19 17:05:13.900 [main] Loading configuration file: Samsung-SMT-G7400.conf
INFO 2014-06-19 17:05:13.904 [main] Loading configuration file: SamsungAllShare.conf
INFO 2014-06-19 17:05:13.907 [main] Loading configuration file: SamsungWiseLink.conf
INFO 2014-06-19 17:05:13.908 [main] Loading configuration file: SharpAquos.conf
INFO 2014-06-19 17:05:13.911 [main] Loading configuration file: Showtime3.conf
INFO 2014-06-19 17:05:13.914 [main] Loading configuration file: Showtime4.conf
INFO 2014-06-19 17:05:13.917 [main] Loading configuration file: SMP-N100.conf
INFO 2014-06-19 17:05:13.920 [main] Loading configuration file: SonyBluray.conf
INFO 2014-06-19 17:05:13.923 [main] Loading configuration file: SonyHomeTheatreSystem.conf
INFO 2014-06-19 17:05:13.926 [main] Loading configuration file: Streamium.conf
INFO 2014-06-19 17:05:13.928 [main] Loading configuration file: TelstraTbox.conf
INFO 2014-06-19 17:05:13.929 [main] Loading configuration file: VideoWebTV.conf
INFO 2014-06-19 17:05:13.931 [main] Loading configuration file: VizioSmartTV.conf
INFO 2014-06-19 17:05:13.934 [main] Loading configuration file: WDTVLive.conf
INFO 2014-06-19 17:05:13.937 [main] Loading configuration file: WMP.conf
INFO 2014-06-19 17:05:13.939 [main] Loading configuration file: XBMC.conf
INFO 2014-06-19 17:05:13.940 [main] Loading configuration file: XBOX360.conf
INFO 2014-06-19 17:05:13.943 [main] Loading configuration file: YamahaRXA1010.conf
INFO 2014-06-19 17:05:13.944 [main] Loading configuration file: YamahaRXV3900.conf
INFO 2014-06-19 17:05:13.946 [main] Loading configuration file: YamahaRXV671.conf
INFO 2014-06-19 17:05:13.947 [main] Checking MPlayer font cache. It can take a minute or so.
INFO 2014-06-19 17:05:14.108 [main] Done!
INFO 2014-06-19 17:05:14.109 [main] Found VLC version 2.1.4 at: C:\Program Files\VideoLAN\VLC\vlc.exe
INFO 2014-06-19 17:05:14.113 [main] Searching for plugins in C:\Program Files (x86)\PS3 Media Server\plugins
INFO 2014-06-19 17:05:14.115 [main] No plugins found
INFO 2014-06-19 17:05:14.131 [main] Transcoder profile AviSynth/FFmpeg will not be used because AviSynth was not found
INFO 2014-06-19 17:05:14.132 [main] Registering transcoding engine: FFmpeg Audio
INFO 2014-06-19 17:05:14.136 [main] Registering transcoding engine: MEncoder Video
INFO 2014-06-19 17:05:14.137 [main] Transcoder profile AviSynth/MEncoder will not be used because AviSynth was not found
INFO 2014-06-19 17:05:14.137 [main] Registering transcoding engine: FFmpeg
INFO 2014-06-19 17:05:14.139 [main] Registering transcoding engine: VLC Video
INFO 2014-06-19 17:05:14.177 [main] Registering transcoding engine: FFmpeg Web Video
INFO 2014-06-19 17:05:14.178 [main] Registering transcoding engine: FFmpeg Web Audio
INFO 2014-06-19 17:05:14.179 [main] Registering transcoding engine: MEncoder Web Video
INFO 2014-06-19 17:05:14.179 [main] Registering transcoding engine: VLC Web Video
INFO 2014-06-19 17:05:14.181 [main] Registering transcoding engine: tsMuxeR
INFO 2014-06-19 17:05:14.182 [main] Registering transcoding engine: Audio High Fidelity
INFO 2014-06-19 17:05:14.183 [main] Registering transcoding engine: VLC Web Audio (Legacy)
INFO 2014-06-19 17:05:14.184 [main] Registering transcoding engine: VLC Web Video (Legacy)
INFO 2014-06-19 17:05:14.185 [main] Registering transcoding engine: FFmpeg DVR-MS Remux
INFO 2014-06-19 17:05:14.185 [main] Registering transcoding engine: dcraw Thumbnailer
INFO 2014-06-19 17:05:14.288 [main] Using forced address 192.168.0.191
INFO 2014-06-19 17:05:14.288 [main] Created socket: /192.168.0.191:5001
ERROR 2014-06-19 17:05:14.356 [main] A serious error occurred during PMS init
org.jboss.netty.channel.ChannelException: Failed to bind to: /192.168.0.191:5001
at org.jboss.netty.bootstrap.ServerBootstrap.bind(ServerBootstrap.java:303) ~[pms.jar:1.90.1]
at net.pms.network.HTTPServer.start(HTTPServer.java:125) ~[pms.jar:1.90.1]
at net.pms.PMS.init(PMS.java:548) [pms.jar:1.90.1]
at net.pms.PMS.createInstance(PMS.java:872) [pms.jar:1.90.1]
at net.pms.PMS.main(PMS.java:949) [pms.jar:1.90.1]
Caused by: java.net.BindException: Cannot assign requested address: bind
at sun.nio.ch.Net.bind0(Native Method) ~[na:1.7.0_25]
at sun.nio.ch.Net.bind(Unknown Source) ~[na:1.7.0_25]
at sun.nio.ch.ServerSocketChannelImpl.bind(Unknown Source) ~[na:1.7.0_25]
at sun.nio.ch.ServerSocketAdaptor.bind(Unknown Source) ~[na:1.7.0_25]
at org.jboss.netty.channel.socket.nio.NioServerSocketPipelineSink.bind(NioServerSocketPipelineSink.java:148) ~[pms.jar:1.90.1]
at org.jboss.netty.channel.socket.nio.NioServerSocketPipelineSink.handleServerSocket(NioServerSocketPipelineSink.java:100) ~[pms.jar:1.90.1]
at org.jboss.netty.channel.socket.nio.NioServerSocketPipelineSink.eventSunk(NioServerSocketPipelineSink.java:74) ~[pms.jar:1.90.1]
at org.jboss.netty.channel.Channels.bind(Channels.java:468) ~[pms.jar:1.90.1]
at org.jboss.netty.channel.AbstractChannel.bind(AbstractChannel.java:192) ~[pms.jar:1.90.1]
at org.jboss.netty.bootstrap.ServerBootstrap$Binder.channelOpen(ServerBootstrap.java:348) ~[pms.jar:1.90.1]
at org.jboss.netty.channel.Channels.fireChannelOpen(Channels.java:176) ~[pms.jar:1.90.1]
at org.jboss.netty.channel.socket.nio.NioServerSocketChannel.<init>(NioServerSocketChannel.java:85) ~[pms.jar:1.90.1]
at org.jboss.netty.channel.socket.nio.NioServerSocketChannelFactory.newChannel(NioServerSocketChannelFactory.java:142) ~[pms.jar:1.90.1]
at org.jboss.netty.channel.socket.nio.NioServerSocketChannelFactory.newChannel(NioServerSocketChannelFactory.java:90) ~[pms.jar:1.90.1]
at org.jboss.netty.bootstrap.ServerBootstrap.bind(ServerBootstrap.java:282) ~[pms.jar:1.90.1]
... 4 common frames omitted
INFO 2014-06-19 17:06:04.801 [AWT-EventQueue-0] Configuration saved to: C:\ProgramData\PMS\PMS.conf
