CORSAIR Marcus
Corsair Support
- Okt. 2021
Hier könnt ihr die aktuellen Release Notes von iCUE einsehen, inkl. einem Link zum download.
iCUE 5.17.104 Issues Resolved
Known Issue: We are aware of reports related to the Gigabyte Plugin not properly detecting motherboards in iCUE and we are investigating this issue with Gigabyte.
Software Enhancements
Resolved an issue that caused Cooling and Alert tabs to be missing on NVIDIA RTX devicesDue to the changes implemented in iCUE’s backend support, users will need to update their Stream Deck plugin – updates for the plugin will also resolve various issues including action assignments and iCUE LINK device detectionResolved an issue with Govee that prevented right-clicking to change the name in the Device Settings tabRemoved aspect ratio selection for Murals to improve the Murals setup experienceResolved an issue that prevented any “Press Dial” features from triggering on pressResolved issues that caused the download progress bar to disappear while updating new modulesResolved an issue that may prevent notifications from appearing after clicking on an info buttonDeleting the Govee plugin will no longer cause issues with the Device Settings tab
We have expanded the customization of our LCD screens for Hydro Coolers by allowing our users to overlay sensor data over any custom backgroundResolved an issue with 5000T RGB that caused lighting effects selected on a 4-pin channel to also play on the 3-pin channelHydroX cooling presets are now available in Device Memory ModeResolved an issue that prevented preset fan curves from saving in iCUE after a software restartResolved an issue that prevented the “Set LCD Frame Rate” slider from appearing properlyArc lighting effect now properly plays on SP120 PRO and SP120 ELITE series fansResolved an issue with all cooling devices that prevented drag and drop from the cooling libraryResolved an issue that caused software-enabled lighting effects to appear under Device Memory ModeUsers will no longer be able to accidentally quit iCUE during any Setup Wizard processResolved an issue with COMMANDER CORE not importing and exporting profiles properly
Assignment buttons will no longer be disabled when unplugging a separate HID deviceResolved an issue that caused problems with key assignments after a firmware updateiCUE will no longer crash after changing lift height in Device Memory ModeResolved an issue that prevented K95 RGB PLATINUM from displaying indicators if the brightness was set to 0%Resolved an issue with switching DPI stages on wireless mice after completing a new pairing processResolved an issue with K70 MAX when using tournament mode with Device Memory ModeResolved an issue with VIRTUOXO XT that caused mic boom LED issues when leaving the connectivity range of the receiver
