[2024-01-10 06:07:41,756] [INFO] [paperless.consumer] Consuming 43660494_2017_Nr.003_Kontoauszug_vom_30.12.2017_13.01.2018.pdf
[2024-01-10 06:07:41,761] [DEBUG] [paperless.consumer] Detected mime type: application/pdf
[2024-01-10 06:07:41,764] [DEBUG] [paperless.consumer] Parser: RasterisedDocumentParser
[2024-01-10 06:07:41,769] [DEBUG] [paperless.consumer] Parsing 43660494_2017_Nr.003_Kontoauszug_vom_30.12.2017_13.01.2018.pdf...
[2024-01-10 06:07:42,040] [DEBUG] [paperless.parsing.tesseract] Calling OCRmyPDF with args: {'input_file': PosixPath('/tmp/paperless/paperless-ngxgwkulbmd/43660494_2017_Nr.003_Kontoauszug_vom_30.12.2017_13.01.2018.pdf'), 'output_file': PosixPath('/tmp/paperless/paperless-0yx85c1l/archive.pdf'), 'use_threads': True, 'jobs': 4, 'language': 'eng', 'output_type': 'pdfa', 'progress_bar': False, 'color_conversion_strategy': 'RGB', 'skip_text': True, 'clean': True, 'deskew': True, 'rotate_pages': True, 'rotate_pages_threshold': 12.0, 'sidecar': PosixPath('/tmp/paperless/paperless-0yx85c1l/sidecar.txt')}
[2024-01-10 06:07:42,305] [WARNING] [paperless.parsing.tesseract] This file is encrypted, OCR is impossible. Using any text present in the original file.
[2024-01-10 06:07:42,306] [DEBUG] [paperless.consumer] Generating thumbnail for 43660494_2017_Nr.003_Kontoauszug_vom_30.12.2017_13.01.2018.pdf...
[2024-01-10 06:07:42,309] [DEBUG] [paperless.parsing] Execute: convert -density 300 -scale 500x5000> -alpha remove -strip -auto-orient /tmp/paperless/paperless-ngxgwkulbmd/43660494_2017_Nr.003_Kontoauszug_vom_30.12.2017_13.01.2018.pdf[0] /tmp/paperless/paperless-0yx85c1l/convert.webp
[2024-01-10 06:07:43,653] [DEBUG] [paperless.consumer] Saving record to database
[2024-01-10 06:07:43,653] [DEBUG] [paperless.consumer] Creation date from parse_date: 2017-12-30 00:00:00+00:00
[2024-01-10 06:07:44,185] [INFO] [paperless.handlers] Assigning correspondent VR Bank Würzburg to 2017-12-30 43660494_2017_Nr.003_Kontoauszug_vom_30.12.2017_13.01.2018
[2024-01-10 06:07:44,197] [INFO] [paperless.handlers] Assigning document type Kontoauszug to 2017-12-30 VR Bank Würzburg 43660494_2017_Nr.003_Kontoauszug_vom_30.12.2017_13.01.2018
[2024-01-10 06:07:44,222] [INFO] [paperless.handlers] Assigning storage path Archiv to 2017-12-30 VR Bank Würzburg 43660494_2017_Nr.003_Kontoauszug_vom_30.12.2017_13.01.2018
[2024-01-10 06:07:44,371] [DEBUG] [paperless.filehandling] Document has storage_path 2 (Archiv/{correspondent}/{created_year}{title}{document_type}) set
[2024-01-10 06:07:44,401] [DEBUG] [paperless.filehandling] Document has storage_path 2 (Archiv/{correspondent}/{created_year}{title}{document_type}) set
[2024-01-10 06:07:44,407] [DEBUG] [paperless.consumer] Deleting file /tmp/paperless/paperless-ngxgwkulbmd/43660494_2017_Nr.003_Kontoauszug_vom_30.12.2017_13.01.2018.pdf
[2024-01-10 06:07:44,433] [DEBUG] [paperless.parsing.tesseract] Deleting directory /tmp/paperless/paperless-0yx85c1l
[2024-01-10 06:07:44,435] [INFO] [paperless.consumer] Document 2017-12-30 VR Bank Würzburg 43660494_2017_Nr.003_Kontoauszug_vom_30.12.2017_13.01.2018 consumption finished
