Linux version (ext2fs lib: 1.39, ntfs lib: 9:0:0, reiserfs lib: 0.3.1-rc8, ewf lib: none)
Failed to set locale, using default 'C'.
disk_get_geometry BLKGETSIZE64 /dev/hda number of cylinders 16383 != 13665 (calculated)
Hard disk list
Disk /dev/hda - 112 GB / 104 GiB - CHS 13665 255 63, sector size=512
Disk /dev/hdc - 733 MB / 699 MiB - CHS 23 255 63 (RO), sector size=2048
Partition table type: Intel
Analyse Disk /dev/hda - 112 GB / 104 GiB - CHS 13665 255 63
Geometry from i386 MBR: head=255 sector=63
NTFS at 0/1/1
Info: size boot_sector 219528161, partition 219528162
get_geometry_from_list_part_aux head=255 nbr=2
get_geometry_from_list_part_aux head=8 nbr=1
get_geometry_from_list_part_aux head=16 nbr=1
get_geometry_from_list_part_aux head=32 nbr=1
get_geometry_from_list_part_aux head=64 nbr=1
get_geometry_from_list_part_aux head=128 nbr=1
get_geometry_from_list_part_aux head=240 nbr=1
Current partition structure:
1 * HPFS - NTFS 0 1 1 13664 254 63 219528162
Ask the user for vista mode
Allow partial last cylinder : No
search_vista_part: 0
search_part()
NTFS at 0/1/1
filesystem size 219528161
sectors_per_cluster 8
mft_lcn 786432
mftmirr_lcn 16
clusters_per_mft_record -10
clusters_per_index_record 1
D HPFS - NTFS 0 1 1 13664 254 62 219528161
NTFS, 112 GB / 104 GiB
NTFS at 13664/254/63
mft_lcn 786432
mftmirr_lcn 16
NTFS: Can't read MFT
D HPFS - NTFS 13664 254 63 27329 253 61 219528161
This partition ends after the disk limits. (start=219528224, size=219528161, end=439056384, disk end=219528225)
Check the harddisk size: HD jumpers settings, BIOS detection...
The harddisk (112 GB / 104 GiB) seems too small! (< 224 GB / 209 GiB)
The following partition can't be recovered:
Results
interface_write()
No partition found or selected for recovery
search_part()
NTFS at 0/1/1
mft_lcn 786432
mftmirr_lcn 16
mft_lcn 786432
mftmirr_lcn 16
D HPFS - NTFS 0 1 2 13664 254 63 219528161
NTFS found using backup sector!, 112 GB / 104 GiB
mft_lcn 786432
mftmirr_lcn 16
NTFS at 0/1/1
mft_lcn 786432
mftmirr_lcn 16
Results
D HPFS - NTFS 0 1 1 13664 254 63 219528162
interface_write()
simulate write!
