Hello,
I built my system about 2 months ago. Everything worked fine.
I had it connected via the remote coming with the fans, because i thought my motherboard had no 5V ARGB connector. I realised that it had one on the bottom and wanted to change the connections that I am able to control the RGB via Software. So i removed the remote, I disconnected the fans cable from the remote and the SATA connection of the remote. I connected the fan cables to the 3-Pin connector Splitter and connected that with the motherboards 5V 3-PIN connector.
Now the motherboard lights turn on when i connect the PC to Power but it doesn't boot. I tried reconnecting the Front panel connections because i thought i might moved them, but that didn't change anything.
I connected the old remote like it was connected before but it didn't change anyting.
Does anyone have an idea what the problem could be?
Specs:
Motherboard: Asus B550-F
Processor: AMD Ryzen 7 5800X
Graphics Card: AMD RX 6800
RAM: 32GB Corsair Vengeance 3200mhz
PSU: Corsair RM 850X
M.2 SSD: Samsung 980 Pro and Crucial P3 Plus
AIO: Lian Li Galahad
Fans: Lian Li BR Digital-3R
Specs:
