Ich brauche dringends hilfe ! weil mein pc seit 3-4 tagen einfach ohne grund abschmiert. ich habe beim bluescreen nachgeguckt und da steht :
Microsoft (R) Windows Debugger Version 6.4.0007.2
Copyright (c) Microsoft Corporation. All rights reserved.
Loading Dump File [C:\Users\JayJoeHoe\Desktop\MEMORY.DMP]
Kernel Summary Dump File: Only kernel address space is available
Symbol search path is: *** Invalid ***
* Symbol loading may be unreliable without a symbol search path. *
* Use .symfix to have the debugger choose a symbol path. *
* After setting your symbol path, use .reload to refresh symbol locations. *
Executable search path is:
* Symbols can not be loaded because symbol path is not initialized. *
* The Symbol Path can be set by: *
* using the _NT_SYMBOL_PATH environment variable. *
* using the -y <symbol_path> argument when starting the debugger. *
* using .sympath and .sympath+ *
*** ERROR: Symbol file could not be found. Defaulted to export symbols for ntkrnlmp.exe -
Windows Longhorn Kernel Version 7600 MP (2 procs) Free x64
Product: WinNt, suite: TerminalServer SingleUserTS Personal
Built by: 7600.17118.amd64fre.win7_gdr.
Kernel base = 0xfffff800`02a54000 PsLoadedModuleList = 0xfffff800`02c90e70
Debug session time: Sun Dec 23 18:53:12.377 2012 (GMT+1)
System Uptime: 0 days 0:00:29.250
Loading Kernel Symbols
Loading unloaded module list
Loading User Symbols
PEB is paged out (Peb.Ldr = 000007ff`fffdf018). Type ".hh dbgerr001" for details
* Bugcheck Analysis *
Use !analyze -v to get detailed debugging information.
BugCheck F4, {3, fffffa80089e2b30, fffffa80089e2e10, fffff80002dcad50}
***** Kernel symbols are WRONG. Please fix symbols to do analysis.
*** Your debugger is not using the correct symbols ***
*** In order for this command to work properly, your symbol path ***
*** must point to .pdb files that have full type information. ***
*** Certain .pdb files (such as the public OS symbols) do not ***
*** contain the required information. Contact the group that ***
*** provided you with these symbols if you need this command to ***
*** work. ***
*** Type referenced: nt!_KPRCB ***
Probably caused by : wininit.exe
Followup: MachineOwner
Pc Daten: Ram: 4gb
grafikkarte : amd radeon 4570
prozessor :AMD Athlon dual core 2ghz
windows 7 home premium 64bit
*** work. ***
Pc Daten: Ram: 4gb
