Renovatio
- März 2008
ich habe den PCTV DVB-S2-Stick und möchte die HD Funktion (H.264) nun aktivieren, aber es funktioniert nicht. Weiß jemand eine Lösung?
Es kommt immer folgende Fehlermeldung, wenn ich die Funktion aktivieren möchte:
Server Error in '/' Application.
empty eMail and no member id b memberid:-1238398
Description: An unhandled exception occurred during the execution of the current web request. Please review the stack trace for more information about the error and where it originated in the code.
Exception Details: System.Exception: empty eMail and no member id b memberid:-1238398
Source Error:
An unhandled exception was generated during the execution of the current web request. Information regarding the origin and location of the exception can be identified using the exception stack trace below.
Stack Trace:
[Exception: empty eMail and no member id b memberid:-1238398]
BC.Common.PixieStudioUser.load() +710
BC.Common.PixieStudioUser..ctor(Int32 memberID) +130
BC.Common.Web.GenericPage.writeMemberInfoCookie(Int32 MemberID) +56
upsell._default.transferToSuccessURL() in E:\Projects\Upsell\Default.aspx.cs:1014
upsell._default.Page_Load(Object sender, EventArgs e) in E:\Projects\Upsell\Default.aspx.cs:403
System.Web.Util.CalliHelper.EventArgFunctionCaller(IntPtr fp, Object o, Object t, EventArgs e) +14
System.Web.Util.CalliEventHandlerDelegateProxy.Callback(Object sender, EventArgs e) +35
System.Web.UI.Control.OnLoad(EventArgs e) +99
System.Web.UI.Control.LoadRecursive() +50
System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +627
Version Information: Microsoft .NET Framework Version:2.0.50727.3625; ASP.NET Version:2.0.50727.3618
Source Error:
Stack Trace:
