GlockMane88
- Aug. 2008
Hi Leute,
habe ein Perl Script gefunden, welches in einer PDF Datei Text ersetzt (ähnlich dem öffnen der PDF mit einem Texteditor und manuellem Ersetzen eines bestimmten Textes).
Leider ist der Output eine leere PDF Datei.. Kann man anhand vom Code sagen, warum das passiert? Habe Perl Strawberry installiert..
Perl:
#!/usr/bin/env perl
$/ = "\n";
open(FH_IN, "<in.pdf");
open(FH_OUT, ">out.pdf");
binmode(FH_IN);
binmode(FH_OUT);
my $buffer = '';
my $pattern_start = qr/^\d+\s+\d+\s+obj/;
my $pattern_end = qr/endobj\b/;
my $pattern_filter = qr/(?:\/C\s+\/Windows)/;
my $try_to_decompress = ($ARGV[0] eq '--unzip') ? 1 : 0;
my $can_decompress = 0;
my $pattern_compressed;
if ($try_to_decompress) {
eval "use zlib;";
$can_decompress = ($@) ? 0 : 1;
if ($can_decompress) {
$pattern_compressed = qr/\/FlateDecode[\w\W]*>>[\w\W]*stream[\r\n]*([\w\W]*?)[\r\n]*endstream/;
else {
print 'WARNING: --unzip is not supported' . "\n" . 'perl module not found: "Compress::Raw::Zlib"' . "\n\n";
my $debug = 0;
my $data;
while (my $line = <FH_IN>) {
if ($buffer){
$buffer = $buffer . $line;
if ($line =~ m/$pattern_end/){
if ($can_decompress && $buffer =~ m/$pattern_compressed/) {
$data = $1;
$data = zlib::decompress(\$data); # pass data by reference
if ( $data =~ m/$pattern_filter/ ){
$buffer = '';
if ($debug) {
$buffer = '-'x40 . '<data>' . "\n" . ($buffer ? $data : 'matching pattern removed') . "\n" . '-'x40 . '</data>' . "\n";
if ( $buffer =~ m/$pattern_filter/ ){
$buffer = '';
} else {
print FH_OUT $buffer;
$buffer = '';
else {
if ( $line =~ m/$pattern_start/ ){
$buffer = $line;
} else {
print FH_OUT $line;
if ($buffer){
$buffer = '';
close (FH_IN);
close (FH_OUT);
