folgende Platte wurde in 2005 neu gekauft. Da Linux manchmal beim booten bei fsck hängen blieb habe ich mal die smartmontools angeworfen um einige Infos/Fehlermeldungen zu erhalten. Wie würdet ihr die Ausgaben deuten?
Code:
smartctl version 5.37 [i686-pc-linux-gnu] Copyright (C) 2002-6 Bruce Allen
Home page is http://smartmontools.sourceforge.net/
=== START OF INFORMATION SECTION ===
Device Model: SAMSUNG SP0411N
Serial Number: xxxxxxxxxxxxxx
Firmware Version: TW100-08
User Capacity: 40.060.403.712 bytes
Device is: In smartctl database [for details use: -P show]
ATA Version is: 7
ATA Standard is: ATA/ATAPI-7 T13 1532D revision 0
Local Time is: Thu Nov 22 16:26:54 2007 CET
==> WARNING: May need -F samsung or -F samsung2 enabled; see manual for details.
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
=== START OF READ SMART DATA SECTION ===
SMART overall-health self-assessment test result: FAILED!
Drive failure expected in less than 24 hours. SAVE ALL DATA.
Failed Attributes:
ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE
198 Offline_Uncorrectable 0x0031 001 001 010 Pre-fail Offline FAILING_NOW 484
SMART Attributes Data Structure revision number: 16
Vendor Specific SMART Attributes with Thresholds:
1 Raw_Read_Error_Rate 0x000b 100 100 051 Pre-fail Always - 778
3 Spin_Up_Time 0x0007 075 074 000 Pre-fail Always - 4672
4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 92
5 Reallocated_Sector_Ct 0x0033 253 253 010 Pre-fail Always - 0
7 Seek_Error_Rate 0x000b 253 253 051 Pre-fail Always - 0
8 Seek_Time_Performance 0x0024 090 089 000 Old_age Offline - 9757
9 Power_On_Hours 0x0032 100 100 000 Old_age Always - 91930
10 Spin_Retry_Count 0x0013 253 253 049 Pre-fail Always - 0
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 46
194 Temperature_Celsius 0x0022 154 142 000 Old_age Always - 28
195 Hardware_ECC_Recovered 0x000a 100 100 000 Old_age Always - 112655550
196 Reallocated_Event_Count 0x0012 001 001 000 Old_age Always - 484
197 Current_Pending_Sector 0x0033 253 253 010 Pre-fail Always - 0
199 UDMA_CRC_Error_Count 0x000b 100 100 051 Pre-fail Always - 0
200 Multi_Zone_Error_Rate 0x000b 100 100 051 Pre-fail Always - 0
201 Soft_Read_Error_Rate 0x000b 099 097 051 Pre-fail Always - 454
SMART Self-test log structure revision number 1
Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error
# 1 Extended offline Completed: read failure 00% 765 27005325
# 2 Extended offline Completed: read failure 00% 762 27005325
# 3 Extended offline Completed: read failure 00% 569 27005325
# 4 Short offline Completed without error 00% 565 -
SMART Error Log Version: 1
Warning: ATA error count 256 inconsistent with error log pointer 5
ATA Error Count: 256 (device log contains only the most recent five errors)
CR = Command Register [HEX]
FR = Features Register [HEX]
SC = Sector Count Register [HEX]
SN = Sector Number Register [HEX]
CL = Cylinder Low Register [HEX]
CH = Cylinder High Register [HEX]
DH = Device/Head Register [HEX]
DC = Device Command Register [HEX]
ER = Error register [HEX]
ST = Status register [HEX]
Powered_Up_Time is measured from power on, and printed as
DDd+hh:mm:SS.sss where DD=days, hh=hours, mm=minutes,
SS=sec, and sss=millisec. It "wraps" after 49.710 days.
Error 256 occurred at disk power-on lifetime: 521 hours (21 days + 17 hours)
When the command that caused the error occurred, the device was active or idle.
After command completion occurred, registers were:
ER ST SC SN CL CH DH
04 51 00 00 c2 4f e0 Error: ABRT
Commands leading to the command that caused the error were:
CR FR SC SN CL CH DH DC Powered_Up_Time Command/Feature_Name
b0 da 00 00 c2 4f e0 00 10:47:19.063 SMART RETURN STATUS
ec 00 00 f6 6f 8d e0 00 10:47:18.938 IDENTIFY DEVICE
ec 00 00 6e a7 40 e0 00 00:01:11.313 IDENTIFY DEVICE
ef 42 fe 00 00 00 e0 00 00:01:11.250 SET FEATURES [Enable AAM]
ec 00 01 00 00 00 e0 00 00:01:11.250 IDENTIFY DEVICE
