NAS
Problem beim Audio CD brennen
the_puma
Sep. 2004
Mein Nec brenner brennt Audio CD`s bis 9% und dann bricht er ab.
in der Log Datei steht DMA driver error crc????
Windows XP 5.1
IA32
WinAspi: -
ahead WinASPI: File 'C:\Programme\Nero\Nero 7\Core\Wnaspi32.dll': Ver=2.0.1.74, size=164112 bytes, created 02.11.2004 12:54:32
NT-SPTI used
Nero Version: 7.0.1.4
Internal Version: 7, 0, 1, 4
(Nero Express)
Recorder: <_NEC DVD_RW ND-2510A> Version: 2.15 - HA 1 TA 0 - 7.0.1.4
Adapter driver: <IDE> HA 1
Drive buffer : 2048kB
Bus Type : default (0) -> ATAPI, detected: ?
CD-ROM: <SCSIVAX DVD/CD-ROM >Version: 2.7a - HA 1 TA 1 - 7.0.1.4
Adapter driver: <SCSI> HA 1
=== Scsi-Device-Map ===
DiskPeripheral : SiI RAID 0 Set 0 si3112r Port 0 ID 0 DMA: Off
CdRomPeripheral : _NEC DVD_RW ND-2510A nvatabus Port 1 ID 0 DMA: Off
CdRomPeripheral : SCSIVAX DVD/CD-ROM 2.7a Vax347s Port 2 ID 0 DMA: Off
=== CDRom-Device-Map ===
SCSIVAX DVD/CD-ROM D: CDRom1
_NEC DVD_RW ND-2510A H: CDRom0
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 83886080 (0) Byte
ShowDrvBufStat : 0
BUFE : 0
Physical memory : 2047MB (2096624kB)
Free physical memory: 1582MB (1620768kB)
Memory in use : 22 %
Uncached PFiles: 0x0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
5.2.2006
Audio-CD
13:30:16 #1 CDADOC -1 File Cdadoc.cpp, Line 1507
Audio item log info:
Audio document burn settings:
Burn mode: DAO,
CD Text: On,
Cache disk or network files: No,
Cache small files: No,
Cache files smaller than 65536 bytes.
Audio Multisession: No
List of audio tracks:
Track 01: Length: 05:04.41, Pause frames: 150, Filters: 0, Name: '17_Groove_Coverage_-_On_The_Radio.mp3'.
Track 02: Length: 03:32.10, Pause frames: 150, Filters: 0, Name: '18- Filterfunk- S.O.S. (Message In A Bottle)(Sander Van Doorm Mix).mp3'.
Track 03: Length: 04:47.71, Pause frames: 150, Filters: 0, Name: '19_DHT - Listen to your heart (Original edit).mp3'.
Track 04: Length: 05:33.65, Pause frames: 150, Filters: 0, Name: '20_ Acues & Elitist - Zonderland.mp3'.
Track 05: Length: 03:40.05, Pause frames: 150, Filters: 0, Name: '01_dj_shog_-_jealousy_(edit).mp3'.
Track 06: Length: 03:18.65, Pause frames: 150, Filters: 0, Name: '02_rocco_-_street_knowledge.mp3'.
Track 07: Length: 03:40.50, Pause frames: 150, Filters: 0, Name: '04_The Real Booty Babes - Since You Been Gone.mp3'.
Track 08: Length: 07:47.74, Pause frames: 150, Filters: 0, Name: '05_dream_dance_alliance_-_ayers_rock-ministry.mp3'.
Track 09: Length: 03:53.15, Pause frames: 150, Filters: 0, Name: '06_C-Bool - House Babe (Rmx).mp3'.
Track 10: Length: 06:32.07, Pause frames: 150, Filters: 0, Name: '08_masterblaster_-_since_youve_been_gone_(discoblaster_remix)-cmp.mp3'.
Track 11: Length: 03:14.73, Pause frames: 150, Filters: 0, Name: '09_The Discoboys - Hello st.peter (radio version).mp3'.
Track 12: Length: 03:51.59, Pause frames: 150, Filters: 0, Name: '10_Dogzilla - Without You.mp3'.
Track 13: Length: 03:36.68, Pause frames: 150, Filters: 0, Name: '11_Yves_Deruyter_-_Infinity.mp3'.
Track 14: Length: 04:36.67, Pause frames: 150, Filters: 0, Name: '12_Dickheadz - Pimp My Stereo (Radio Set Cut).mp3'.
Track 15: Length: 05:43.15, Pause frames: 150, Filters: 0, Name: '14_Alex_Megane_-_Little_Lies.mp3'.
Track 16: Length: 05:29.52, Pause frames: 150, Filters: 0, Name: '15_666 vs. Dj Bonito - Atencion (Project Tone Remix).mp3'.
Track 17: Length: 03:33.59, Pause frames: 150, Filters: 0, Name: '16_megara_vs._dj_lee_-_outside_world.mp3'.
Total size: 78:32.46
13:30:16 #2 Text 0 File Burncd.cpp, Line 3048
Schutz vor Pufferleerlauf aktiviert
13:30:16 #3 Text 0 File ThreadedTransfer.cpp, Line 525
ReadBuffer-Pipe got 81920KB of Memory
13:30:16 #4 Text 0 File Reader.cpp, Line 124
Reader running
13:30:16 #5 Text 0 File Writer.cpp, Line 113
Writer H: _NEC DVD_RW ND-2510A running
13:30:16 #6 Text 0 File AudioCompilationImpl.cpp, Line 842
DRM: StartDrmRecording(RealRec:1, ImageRec:0, Copies:1)
DRM: Beginning burn process.
13:30:16 #7 Text 0 File Burncd.cpp, Line 3342
Turn on Disc-At-Once, using CD-R/RW media
13:30:17 #8 Text 0 File DlgWaitCD.cpp, Line 279
Last possible write address on media: 359844 ( 79:59.69)
Last address to be written: 353295 ( 78:32.45)
13:30:17 #9 Text 0 File DlgWaitCD.cpp, Line 291
Write in overburning mode: NO (enabled: CD)
13:30:17 #10 Text 0 File DlgWaitCD.cpp, Line 2578
Recorder: _NEC DVD_RW ND-2510A
13:30:17 #11 Text 0 File DlgWaitCD.cpp, Line 458
>>> Protocol of DlgWaitCD activities: <<<
13:30:17 #12 Text 0 File ThreadedTransferInterface.cpp, Line 847
Setup items (after recorder preparation)
0: TRM_AUDIO_NOPRE (17_Groove_Coverage_-_On_The_Radio.mp3)
2 indices, index0 (150) not provided
original disc pos #0 + 22841 (22841) = #22841/5:4.41
relocatable, disc pos for caching/writing not required/not required, no patch infos
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 22841 blocks [H: _NEC DVD_RW ND-2510A]
1: TRM_AUDIO_NOPRE (18- Filterfunk- S.O.S. (Message In A Bottle)(Sander Van Doorm Mix).mp3)
original disc pos #0 + 15910 (15910) = #15910/3:32.10
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 15910 blocks [H: _NEC DVD_RW ND-2510A]
2: TRM_AUDIO_NOPRE (19_DHT - Listen to your heart (Original edit).mp3)
original disc pos #0 + 21596 (21596) = #21596/4:47.71
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 21596 blocks [H: _NEC DVD_RW ND-2510A]
3: TRM_AUDIO_NOPRE (20_ Acues & Elitist - Zonderland.mp3)
original disc pos #0 + 25040 (25040) = #25040/5:33.65
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 25040 blocks [H: _NEC DVD_RW ND-2510A]
4: TRM_AUDIO_NOPRE (01_dj_shog_-_jealousy_(edit).mp3)
original disc pos #0 + 16505 (16505) = #16505/3:40.5
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 16505 blocks [H: _NEC DVD_RW ND-2510A]
5: TRM_AUDIO_NOPRE (02_rocco_-_street_knowledge.mp3)
original disc pos #0 + 14915 (14915) = #14915/3:18.65
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 14915 blocks [H: _NEC DVD_RW ND-2510A]
6: TRM_AUDIO_NOPRE (04_The Real Booty Babes - Since You Been Gone.mp3)
original disc pos #0 + 16550 (16550) = #16550/3:40.50
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 16550 blocks [H: _NEC DVD_RW ND-2510A]
7: TRM_AUDIO_NOPRE (05_dream_dance_alliance_-_ayers_rock-ministry.mp3)
original disc pos #0 + 35099 (35099) = #35099/7:47.74
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 35099 blocks [H: _NEC DVD_RW ND-2510A]
8: TRM_AUDIO_NOPRE (06_C-Bool - House Babe (Rmx).mp3)
original disc pos #0 + 17490 (17490) = #17490/3:53.15
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 17490 blocks [H: _NEC DVD_RW ND-2510A]
9: TRM_AUDIO_NOPRE (08_masterblaster_-_since_youve_been_gone_(discoblaster_remix)-cmp.mp3)
original disc pos #0 + 29407 (29407) = #29407/6:32.7
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 29407 blocks [H: _NEC DVD_RW ND-2510A]
10: TRM_AUDIO_NOPRE (09_The Discoboys - Hello st.peter (radio version).mp3)
original disc pos #0 + 14623 (14623) = #14623/3:14.73
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 14623 blocks [H: _NEC DVD_RW ND-2510A]
11: TRM_AUDIO_NOPRE (10_Dogzilla - Without You.mp3)
original disc pos #0 + 17384 (17384) = #17384/3:51.59
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 17384 blocks [H: _NEC DVD_RW ND-2510A]
12: TRM_AUDIO_NOPRE (11_Yves_Deruyter_-_Infinity.mp3)
original disc pos #0 + 16268 (16268) = #16268/3:36.68
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 16268 blocks [H: _NEC DVD_RW ND-2510A]
13: TRM_AUDIO_NOPRE (12_Dickheadz - Pimp My Stereo (Radio Set Cut).mp3)
original disc pos #0 + 20767 (20767) = #20767/4:36.67
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 20767 blocks [H: _NEC DVD_RW ND-2510A]
14: TRM_AUDIO_NOPRE (14_Alex_Megane_-_Little_Lies.mp3)
original disc pos #0 + 25740 (25740) = #25740/5:43.15
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 25740 blocks [H: _NEC DVD_RW ND-2510A]
15: TRM_AUDIO_NOPRE (15_666 vs. Dj Bonito - Atencion (Project Tone Remix).mp3)
original disc pos #0 + 24727 (24727) = #24727/5:29.52
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 24727 blocks [H: _NEC DVD_RW ND-2510A]
16: TRM_AUDIO_NOPRE (16_megara_vs._dj_lee_-_outside_world.mp3)
original disc pos #0 + 16034 (16034) = #16034/3:33.59
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 16034 blocks [H: _NEC DVD_RW ND-2510A]
13:30:17 #13 Text 0 File ThreadedTransferInterface.cpp, Line 1059
Prepare recorder [H: _NEC DVD_RW ND-2510A] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
TOCType: 0x00; Session Closed, disc fixated
Tracks 1 to 17:
1: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 0 352800 54074832, ISRC ""
2: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 54074832 54427632 91847952, ISRC ""
3: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 91847952 92200752 142994544, ISRC ""
4: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 142994544 143347344 202241424, ISRC ""
5: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 202241424 202594224 241413984, ISRC ""
6: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 241413984 241766784 276846864, ISRC ""
7: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 276846864 277199664 316125264, ISRC ""
8: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 316125264 316478064 399030912, ISRC ""
9: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 399030912 399383712 440520192, ISRC ""
10: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 440520192 440872992 510038256, ISRC ""
11: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 510038256 510391056 544784352, ISRC ""
12: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 544784352 545137152 586024320, ISRC ""
13: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 586024320 586377120 624639456, ISRC ""
14: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 624639456 624992256 673836240, ISRC ""
15: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 673836240 674189040 734729520, ISRC ""
16: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 734729520 735082320 793240224, ISRC ""
17: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 793240224 793593024 831304992, ISRC ""
DAO layout:
__Start_|____Track_|_Idx_|_CtrlAdr_|_RecDep__________
-150 | lead-in | 0 | 0x01 | 0x00
-150 | 1 | 0 | 0x21 | 0x00
0 | 1 | 1 | 0x21 | 0x00
22841 | 2 | 0 | 0x21 | 0x00
22991 | 2 | 1 | 0x21 | 0x00
38901 | 3 | 0 | 0x21 | 0x00
39051 | 3 | 1 | 0x21 | 0x00
60647 | 4 | 0 | 0x21 | 0x00
60797 | 4 | 1 | 0x21 | 0x00
85837 | 5 | 0 | 0x21 | 0x00
85987 | 5 | 1 | 0x21 | 0x00
102492 | 6 | 0 | 0x21 | 0x00
102642 | 6 | 1 | 0x21 | 0x00
117557 | 7 | 0 | 0x21 | 0x00
117707 | 7 | 1 | 0x21 | 0x00
134257 | 8 | 0 | 0x21 | 0x00
134407 | 8 | 1 | 0x21 | 0x00
169506 | 9 | 0 | 0x21 | 0x00
169656 | 9 | 1 | 0x21 | 0x00
187146 | 10 | 0 | 0x21 | 0x00
187296 | 10 | 1 | 0x21 | 0x00
216703 | 11 | 0 | 0x21 | 0x00
216853 | 11 | 1 | 0x21 | 0x00
231476 | 12 | 0 | 0x21 | 0x00
231626 | 12 | 1 | 0x21 | 0x00
249010 | 13 | 0 | 0x21 | 0x00
249160 | 13 | 1 | 0x21 | 0x00
265428 | 14 | 0 | 0x21 | 0x00
265578 | 14 | 1 | 0x21 | 0x00
286345 | 15 | 0 | 0x21 | 0x00
286495 | 15 | 1 | 0x21 | 0x00
312235 | 16 | 0 | 0x21 | 0x00
312385 | 16 | 1 | 0x21 | 0x00
337112 | 17 | 0 | 0x21 | 0x00
337262 | 17 | 1 | 0x21 | 0x00
353296 | lead-out | 1 | 0x01 | 0x00
13:30:17 #14 Text 0 File SCSIPassThrough.cpp, Line 36
SPTILockVolume - completed successfully for FCTL_LOCK_VOLUME
13:30:17 #15 Phase 36 File dlgbrnst.cpp, Line 1725
Burn process started at 32x (4.800 KB/s)
13:30:17 #16 SPTI -1189 File SCSIPassThrough.cpp, Line 323
H: CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1189)
Sense Key: 0x05 (KEY_ILLEGAL_REQUEST)
Sense Code: 0x30
Sense Qual: 0x02
CDB Data: 0xAD 00 00 00 00 00 00 FF 40 00 00 00
Sense Area: 0x70 00 05 00 00 00 00 0A 00 00 00 00 30 02
Buffer x07b58200: Len x4000
13:30:17 #17 Text 0 File ThreadedTransferInterface.cpp, Line 2685
Verifying disc position of item 0 (relocatable, no disc pos, no patch infos, orig at #0): write at #0
13:30:17 #18 Text 0 File ThreadedTransferInterface.cpp, Line 2685
Verifying disc position of item 1 (relocatable, no disc pos, no patch infos, orig at #0): write at #22991
13:30:17 #19 Text 0 File ThreadedTransferInterface.cpp, Line 2685
Verifying disc position of item 2 (relocatable, no disc pos, no patch infos, orig at #0): write at #39051
13:30:17 #20 Text 0 File ThreadedTransferInterface.cpp, Line 2685
Verifying disc position of item 3 (relocatable, no disc pos, no patch infos, orig at #0): write at #60797
13:30:17 #21 Text 0 File ThreadedTransferInterface.cpp, Line 2685
Verifying disc position of item 4 (relocatable, no disc pos, no patch infos, orig at #0): write at #85987
13:30:17 #22 Text 0 File ThreadedTransferInterface.cpp, Line 2685
Verifying disc position of item 5 (relocatable, no disc pos, no patch infos, orig at #0): write at #102642
13:30:17 #23 Text 0 File ThreadedTransferInterface.cpp, Line 2685
Verifying disc position of item 6 (relocatable, no disc pos, no patch infos, orig at #0): write at #117707
13:30:17 #24 Text 0 File ThreadedTransferInterface.cpp, Line 2685
Verifying disc position of item 7 (relocatable, no disc pos, no patch infos, orig at #0): write at #134407
13:30:17 #25 Text 0 File ThreadedTransferInterface.cpp, Line 2685
Verifying disc position of item 8 (relocatable, no disc pos, no patch infos, orig at #0): write at #169656
13:30:17 #26 Text 0 File ThreadedTransferInterface.cpp, Line 2685
Verifying disc position of item 9 (relocatable, no disc pos, no patch infos, orig at #0): write at #187296
13:30:17 #27 Text 0 File ThreadedTransferInterface.cpp, Line 2685
Verifying disc position of item 10 (relocatable, no disc pos, no patch infos, orig at #0): write at #216853
13:30:17 #28 Text 0 File ThreadedTransferInterface.cpp, Line 2685
Verifying disc position of item 11 (relocatable, no disc pos, no patch infos, orig at #0): write at #231626
13:30:17 #29 Text 0 File ThreadedTransferInterface.cpp, Line 2685
Verifying disc position of item 12 (relocatable, no disc pos, no patch infos, orig at #0): write at #249160
13:30:17 #30 Text 0 File ThreadedTransferInterface.cpp, Line 2685
Verifying disc position of item 13 (relocatable, no disc pos, no patch infos, orig at #0): write at #265578
13:30:17 #31 Text 0 File ThreadedTransferInterface.cpp, Line 2685
Verifying disc position of item 14 (relocatable, no disc pos, no patch infos, orig at #0): write at #286495
13:30:17 #32 Text 0 File ThreadedTransferInterface.cpp, Line 2685
Verifying disc position of item 15 (relocatable, no disc pos, no patch infos, orig at #0): write at #312385
13:30:17 #33 Text 0 File ThreadedTransferInterface.cpp, Line 2685
Verifying disc position of item 16 (relocatable, no disc pos, no patch infos, orig at #0): write at #337262
13:30:17 #34 Text 0 File MMC.cpp, Line 16932
StartDAO : CD-Text - On
13:30:17 #35 Text 0 File MMC.cpp, Line 17165
CueData, Len=288
21 00 00 41 00 00 00 00
21 01 00 00 00 00 00 00
21 01 01 00 00 00 02 00
21 02 00 00 00 05 06 29
21 02 01 00 00 05 08 29
21 03 00 00 00 08 28 33
21 03 01 00 00 08 2a 33
21 04 00 00 00 0d 1e 2f
21 04 01 00 00 0d 20 2f
21 05 00 00 00 13 06 25
21 05 01 00 00 13 08 25
21 06 00 00 00 16 30 2a
21 06 01 00 00 16 32 2a
21 07 00 00 00 1a 09 20
21 07 01 00 00 1a 0b 20
21 08 00 00 00 1d 34 07
21 08 01 00 00 1d 36 07
21 09 00 00 00 25 2a 06
21 09 01 00 00 25 2c 06
21 0a 00 00 00 29 25 15
21 0a 01 00 00 29 27 15
21 0b 00 00 00 30 0b 1c
21 0b 01 00 00 30 0d 1c
21 0c 00 00 00 33 1c 1a
21 0c 01 00 00 33 1e 1a
21 0d 00 00 00 37 16 0a
21 0d 01 00 00 37 18 0a
21 0e 00 00 00 3b 01 03
21 0e 01 00 00 3b 03 03
21 0f 00 00 00 3f 27 46
21 0f 01 00 00 3f 29 46
21 10 00 00 00 45 19 0a
21 10 01 00 00 45 1b 0a
21 11 00 00 00 4a 38 3e
21 11 01 00 00 4a 3a 3e
01 aa 01 01 00 4e 20 2e
13:30:38 #36 SPTI -1502 File SCSIPassThrough.cpp, Line 323
H: CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1502)
Sense Key: 0x04 (KEY_HARDWARE_ERROR)
Sense Code: 0x08
Sense Qual: 0x03
CDB Data: 0x2A 00 00 00 02 88 00 00 1B 00 00 00
Sense Area: 0x70 00 04 00 00 00 00 0A 00 00 00 00 08 03
Buffer x039f0000: Len xf810
0x6A D9 7E CF FE D8 78 CF 7A D8 3E CF DC D7 CC CE
0x38 D7 3F CE A6 D6 C2 CD 32 D6 6B CD D3 D5 35 CD
0x7B D5 0B CD 33 D5 EA CC 1B D5 ED CC 4D D5 3C CD
13:30:38 #37 CDR -1502 File Writer.cpp, Line 302
DMA-driver error, CRC error
13:30:38 #38 Text 0 File ThreadedTransfer.cpp, Line 228
all writers idle, stopping conversion
13:30:38 #39 Text 0 File ThreadedTransfer.cpp, Line 222
conversion idle, stopping reader
13:30:39 #40 SPTI -1135 File SCSIPassThrough.cpp, Line 323
H: CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1135)
Sense Key: 0x03 (KEY_MEDIUM_ERROR)
Sense Code: 0x0C
Sense Qual: 0x00
CDB Data: 0x00 00 00 00 00 00 00 00 00 00 00 00
Sense Area: 0x70 00 03 00 00 02 89 0A 00 00 00 00 0C
13:30:39 #41 CDR -1135 File WriterStatus.cpp, Line 167
Write error
13:30:39 #42 TRANSFER -24 File WriterStatus.cpp, Line 167
Could not perform end of Disc-at-once
13:30:39 #43 Phase 38 File dlgbrnst.cpp, Line 1725
Burn process failed at 32x (4.800 KB/s)
13:30:39 #44 Text 0 File AudioCompilationImpl.cpp, Line 867
DRM: DRM burn session terminated.
13:30:39 #45 Text 0 File AudioCompilationImpl.cpp, Line 896
DRM: Closing entire DRM handling. Bye.
Existing drivers:
File 'Drivers\PXHELP20.SYS': Ver=2.02.62a, size=20016 bytes, created 28.10.2003 11:02:00 (Prassi/Veritas driver for win 2K)
File 'Drivers\scsiport.sys': Ver=5.1.2600.2180 (xpsp_sp2_rtm.040803-2158), size=96256 bytes, created 03.08.2004 23:59:42 (Adapter driver for src)
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
Sieht ja nett aus ^^
Läuft der Brenner denn im DMA-Modus? Sind ansonsten die aktuellen IDE-Treiber deines MoBos drauf?
Wie kann ich herausfinden ob er im DMA Modus läuft?
DVD`s brennt er ja und Daten CD`s.
Bei der Musikauswahl würde ich auch streiken, wenn ich Dein Brenner währe... :evillol:
Nee, ernsthaft. ASPI Treiber installiert? Läuft eine andere NERO Version oder ein anderes Brennprogramm? Besteht das Problem nur bei Audio CDs oder generell bei allen CDs?
Alternate 2
