Hallo ,
habe mein Laptop mit meiner Playstation 3 per PS3 Media Server verbunden (was früher auch immer gut geklappt hat) jetzt hab ich nach einer Windows neuinstallation das Problem das der Server meine Playstation 3 nicht mehr findet über Wlan ist alles ok nur per Lan verbindung erkennt er sie nich hier mal der log :
[main] INFO 11:45:55.339 Starting PS3 Media Server 1.40.0
[main] INFO 11:45:55.343 by shagrath / 2008-2011
[main] INFO 11:45:55.353 http://ps3mediaserver.org
[main] INFO 11:45:55.353 http://code.google.com/p/ps3mediaserver
[main] INFO 11:45:55.354 http://ps3mediaserver.blogspot.com
[main] INFO 11:45:55.354 Java: 1.6.0_27-Sun Microsystems Inc.
[main] INFO 11:45:55.355 OS: Windows 7 x86 6.1
[main] INFO 11:45:55.356 Encoding: UTF-8
[main] INFO 11:45:55.356 Working directory: C:\Program Files\PS3 Media Server
[main] INFO 11:45:55.366 Temp folder: C:\Users\SCARFA~1\AppData\Local\Temp\ps3mediaserver
[main] INFO 11:45:55.367 Logging config file: C:\Program Files\PS3 Media Server\logback.xml
[main] INFO 11:45:55.368 debug.log: C:\Users\SCARFA~1\AppData\Local\Temp\\debug.log
[main] INFO 11:45:55.369 Profile directory: C:\ProgramData\PMS
[main] INFO 11:45:55.369 Profile path: C:\ProgramData\PMS\PMS.conf
[main] INFO 11:45:55.370 Profile status: rw
[main] INFO 11:45:55.372 Profile name: Scarface8910-PC
[main] INFO 11:45:55.373
[main] INFO 11:45:55.384 Loading MediaInfo library
[main] INFO 11:45:55.744 Loaded MediaInfoLib - v0.7.47
[main] INFO 11:45:55.751 Loading renderer configurations from C:\Program Files\PS3 Media Server\renderers
[main] INFO 11:45:55.752 Loading configuration file: AirPlayer.conf
[main] INFO 11:45:55.755 Loading configuration file: Android.conf
[main] INFO 11:45:55.757 Loading configuration file: Bravia4500.conf
[main] INFO 11:45:55.760 Loading configuration file: Bravia5500.conf
[main] INFO 11:45:55.762 Loading configuration file: BraviaEX.conf
[main] INFO 11:45:55.766 Loading configuration file: FreeboxHD.conf
[main] INFO 11:45:55.768 Loading configuration file: FreecomMusicPal.conf
[main] INFO 11:45:55.770 Loading configuration file: iPad-iPhone.conf
[main] INFO 11:45:55.772 Loading configuration file: Kuro.conf
[main] INFO 11:45:55.775 Loading configuration file: N900.conf
[main] INFO 11:45:55.777 Loading configuration file: Panasonic.conf
[main] INFO 11:45:55.780 Loading configuration file: Philips.conf
[main] INFO 11:45:55.782 Loading configuration file: PopcornHour.conf
[main] INFO 11:45:55.784 Loading configuration file: PS3.conf
[main] INFO 11:45:55.787 Loading configuration file: Realtek.conf
[main] INFO 11:45:55.790 Loading configuration file: Samsung.conf
[main] INFO 11:45:55.792 Loading configuration file: Showtime3.conf
[main] INFO 11:45:55.796 Loading configuration file: SonyBluray.conf
[main] INFO 11:45:55.798 Loading configuration file: Streamium.conf
[main] INFO 11:45:55.800 Loading configuration file: WDTVLive.conf
[main] INFO 11:45:55.802 Loading configuration file: WMP.conf
[main] INFO 11:45:55.804 Loading configuration file: XBMC.conf
[main] INFO 11:45:55.806 Loading configuration file: XBOX360.conf
[main] INFO 11:45:55.808 Checking MPlayer font cache. It can take a minute or so.
[main] INFO 11:45:56.089 Done!
[main] INFO 11:45:56.089 Found VideoLAN version 1.1.11 at: C:\Program Files\VideoLAN\VLC\vlc.exe
[main] INFO 11:45:56.099 Loading plugins from C:\Program Files\PS3 Media Server\plugins
[main] INFO 11:45:56.099 No plugins found
[main] INFO 11:45:56.109 Transcoder profile AviSynth/FFmpeg will not be used because AviSynth was not found
[main] INFO 11:45:56.109 Registering transcoding engine: FFmpeg Audio
[main] INFO 11:45:56.119 Registering transcoding engine: MEncoder
[main] INFO 11:45:56.119 Transcoder profile Avisynth/MEncoder will not be used because AviSynth was not found
[main] INFO 11:45:56.119 Registering transcoding engine: MPlayer Audio
[main] INFO 11:45:56.119 Registering transcoding engine: MEncoder Web
[main] INFO 11:45:56.119 Registering transcoding engine: MPlayer Video Dump
[main] INFO 11:45:56.119 Registering transcoding engine: MPlayer Web
[main] INFO 11:45:56.119 Registering transcoding engine: TsMuxer
[main] INFO 11:45:56.119 Registering transcoding engine: Audio High Fidelity
[main] INFO 11:45:56.119 Registering transcoding engine: VLC Audio Streaming
[main] INFO 11:45:56.129 Registering transcoding engine: VLC Video Streaming
[main] INFO 11:45:56.129 Registering transcoding engine: FFmpeg DVR-MS Remux
[main] INFO 11:45:56.129 Registering transcoding engine: Raws Thumbnailer
[main] INFO 11:45:56.129 AviSynth is not installed. You cannot use avsmencoder as a transcoding engine.
[main] INFO 11:45:56.349 Scanning network interface eth3 / Marvell Yukon 88E8040-PCI-E-Fast-Ethernet-Controller
[main] INFO 11:45:56.349 Using address /169.254.59.131 found on network interface: name:eth3 (Marvell Yukon 88E8040-PCI-E-Fast-Ethernet-Controller)
[main] INFO 11:45:56.349 Created socket: /169.254.59.131:5001
[main] INFO 11:45:56.499 Using the following UUID configured in PMS.conf: fcc47444-aa56-3c58-b26a-8659752d134c
[main] INFO 11:46:02.568 The server should now appear on your renderer
Hat jemand eine Idee was es sein könnte ?
mfg
mfg
