Java Probleme mit Minecraft mods
Xyased
Jan. 2011
Ich bin grad dabei mein FTB Minecraft um eine Mod zu erweitern.
Immibis's Microblocks
Mit biegen und brechen bin ich schon bei 113 Mods aber diese Mod stellt sich quer und ich find keine Lösung für das Problem.
Ich hoffe der eine oder andere sieht eine Lösung im Crashreport:
---- Minecraft Crash Report ----
// I let you down. Sorry :(
Time: 14.10.13 21:35
Description: Failed to start game
java.lang.RuntimeException: Tried to recreate an item id (13526 / shifted:13782) for an item which already exists as mods.immibis.microblocks.ItemSaw@43231cc8. Check your config and resolve the conflict.
at forestry.core.config.Config.getOrCreateItemIdProperty(Config.java:396)
at forestry.plugins.PluginCore.registerCrates(PluginCore.java:492)
at forestry.plugins.NativePlugin.doInit(NativePlugin.java:26)
at forestry.plugins.PluginCore.doInit(PluginCore.java:153)
at forestry.core.ForestryCore.postInit(ForestryCore.java:137)
at forestry.core.ForestryClient.postInit(ForestryClient.java:25)
at forestry.Forestry.postInit(Forestry.java:48)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Unknown Source)
at cpw.mods.fml.common.FMLModContainer.handleModStateEvent(FMLModContainer.java:494)
at sun.reflect.GeneratedMethodAccessor3.invoke(Unknown Source)
at com.google.common.eventbus.EventHandler.handleEvent(EventHandler.java:74)
at com.google.common.eventbus.SynchronizedEventHandler.handleEvent(SynchronizedEventHandler.java:45)
at com.google.common.eventbus.EventBus.dispatch(EventBus.java:314)
at com.google.common.eventbus.EventBus.dispatchQueuedEvents(EventBus.java:296)
at com.google.common.eventbus.EventBus.post(EventBus.java:267)
at cpw.mods.fml.common.LoadController.sendEventToModContainer(LoadController.java:192)
at cpw.mods.fml.common.LoadController.propogateStateMessage(LoadController.java:172)
at cpw.mods.fml.common.LoadController.distributeStateMessage(LoadController.java:103)
at cpw.mods.fml.common.Loader.initializeMods(Loader.java:696)
at cpw.mods.fml.client.FMLClientHandler.finishMinecraftLoading(FMLClientHandler.java:213)
at net.minecraft.client.Minecraft.func_71384_a(Minecraft.java:448)
at net.minecraft.client.MinecraftAppletImpl.func_71384_a(SourceFile:56)
at net.minecraft.client.Minecraft.run(Minecraft.java:733)
at java.lang.Thread.run(Unknown Source)
A detailed walkthrough of the error, its code path and all known details is as follows:
-- System Details --
Details:
Minecraft Version: 1.5.2
Operating System: Windows 7 (amd64) version 6.1
Java Version: 1.7.0_21, Oracle Corporation
Java VM Version: Java HotSpot(TM) 64-Bit Server VM (mixed mode), Oracle Corporation
Memory: 717938672 bytes (684 MB) / 992116736 bytes (946 MB) up to 17089167360 bytes (16297 MB)
JVM Flags: 7 total; -Xms256M -Xmx16363M -XX:+UseConcMarkSweepGC -XX:+CMSIncrementalMode -XX:+AggressiveOpts -XX:+CMSClassUnloadingEnabled -XX:PermSize=128m
AABB Pool Size: 0 (0 bytes; 0 MB) allocated, 0 (0 bytes; 0 MB) used
Suspicious classes: FML and Forge are installed
IntCache: cache: 0, tcache: 0, allocated: 0, tallocated: 0
FML: MCP v7.51 FML v5.2.23.737 Minecraft Forge 7.8.1.737 Optifine OptiFine_1.5.2_HD_U_D5 Feed The Beast Mod Pack 114 mods loaded, 114 mods active
mcp{7.51} [Minecraft Coder Pack] (minecraft.jar) Unloaded->Constructed->Pre-initialized->Initialized->Post-initialized
FML{5.2.23.737} [Forge Mod Loader] (coremods) Unloaded->Constructed->Pre-initialized->Initialized->Post-initialized
Forge{7.8.1.737} [Minecraft Forge] (coremods) Unloaded->Constructed->Pre-initialized->Initialized->Post-initialized
CodeChickenCore{0.8.7} [CodeChicken Core] (coremods) Unloaded->Constructed->Pre-initialized->Initialized->Post-initialized
CoFHFramework{1.5.2.5} [CoFH Framework] (coremods) Unloaded->Constructed->Pre-initialized->Initialized->Post-initialized
ImmibisMicroblocks{55.0.1} [Immibis's Microblocks] (coremods) Unloaded->Constructed->Pre-initialized->Initialized->Post-initialized
InfiniBows{1.0.0 build 10} [Infinity Bow Fix] (coremods) Unloaded->Constructed->Pre-initialized->Initialized->Post-initialized
NotEnoughItems{1.5.2.28} [Not Enough Items] (coremods) Unloaded->Constructed->Pre-initialized->Initialized->Post-initialized
OmniumCore{Beta-73} [CCM Core] (coremods) Unloaded->Constructed->Pre-initialized->Initialized->Post-initialized
PowerCrystalsCore{1.1.6} [PowerCrystals Core] (coremods) Unloaded->Constructed->Pre-initialized->Initialized->Post-initialized
CoFHCore{1.5.2.5} [CoFHCore] (CoFHCore-1.5.2.5.jar) Unloaded->Constructed->Pre-initialized->Initialized->Post-initialized
CoFHWorld{1.5.2.5} [CoFHWorld] (CoFHCore-1.5.2.5.jar) Unloaded->Constructed->Pre-initialized->Initialized->Post-initialized
denLib{3.0.14} [denLib] (denLib-1.5.2-3.0.14.jar) Unloaded->Constructed->Pre-initialized->Initialized->Post-initialized
ImmibisMicroblocksInstallCheck{55.0.1} [Immibis's Microblocks (Check for incorrect installation)] (Immibiss-Microblocks-Mod-1.5.2.jar) Unloaded->Constructed->Pre-initialized->Initialized->Post-initialized
inventorytweaks{1.55-dev} [Inventory Tweaks] (InventoryTweaks-MC1.5.2-1.55-dev-b37.jar) Unloaded->Constructed->Pre-initialized->Initialized->Post-initialized
nucleum_omnium{Beta-73} [Nucleum Omnium] (Nucleum-Omnium-Beta-73.jar) Unloaded->Constructed->Pre-initialized->Initialized->Post-initialized
nucleum_world{Beta-73} [Nucleum World] (Nucleum-Omnium-Beta-73.jar) Unloaded->Constructed->Pre-initialized->Initialized->Post-initialized
ThermalExpansion{2.4.5.0} [Thermal Expansion] (ThermalExpansion-2.4.5.0.jar) Unloaded->Constructed->Pre-initialized->Initialized->Post-initialized
IC2{1.116.369-lf} [IndustrialCraft 2] (IndustrialCraft2-1.116.369-lf.jar) Unloaded->Constructed->Pre-initialized->Initialized->Post-initialized
AdvancedMachines{4.9} [IC2 Advanced Machines Addon] (Advanced-Machines-Addon-1.5.2.zip) Unloaded->Constructed->Pre-initialized->Initialized->Post-initialized
AdvancedPowerManagement{1.2.68-IC2-1.115} [Advanced Power Management] (AdvancedPowerManagement-1.2.68.jar) Unloaded->Constructed->Pre-initialized->Initialized->Post-initialized
AdvancedSolarPanel{3.3.7} [Advanced Solar Panels] (AdvancedSolarPanels-3.3.7.zip) Unloaded->Constructed->Pre-initialized->Initialized->Post-initialized
BuildCraft|Core{3.7.1} [BuildCraft] (BuildCraft-3.7.1.jar) Unloaded->Constructed->Pre-initialized->Initialized->Post-initialized
BuildCraft|Transport{3.7.1} [BC Transport] (BuildCraft-3.7.1.jar) Unloaded->Constructed->Pre-initialized->Initialized->Post-initialized
BuildCraft|Silicon{3.7.1} [BC Silicon] (BuildCraft-3.7.1.jar) Unloaded->Constructed->Pre-initialized->Initialized->Post-initialized
BuildCraft|Builders{3.7.1} [BC Builders] (BuildCraft-3.7.1.jar) Unloaded->Constructed->Pre-initialized->Initialized->Post-initialized
BuildCraft|Energy{3.7.1} [BC Energy] (BuildCraft-3.7.1.jar) Unloaded->Constructed->Pre-initialized->Initialized->Post-initialized
BuildCraft|Factory{3.7.1} [BC Factory] (BuildCraft-3.7.1.jar) Unloaded->Constructed->Pre-initialized->Initialized->Post-initialized
MineFactoryReloaded{1.5.1R2.6.4} [MineFactory Reloaded] (MineFactoryReloaded-2.6.4-975.jar) Unloaded->Constructed->Pre-initialized->Initialized->Post-initialized
AppliedEnergistics{rv11.b} [Applied Energistics] (AppliedEnergistics-rv11.b.zip) Unloaded->Constructed->Pre-initialized->Initialized->Post-initialized
BiblioCraft{1.3.1} [BiblioCraft] (BiblioCraft-1.3.1.zip) Unloaded->Constructed->Pre-initialized->Initialized->Post-initialized
ChargePads{2.7.0} [Charge Pads] (ChargePads-2.7.0.86.jar) Unloaded->Constructed->Pre-initialized->Initialized->Post-initialized
ChickenChunks{1.3.2.12} [ChickenChunks] (ChickenChunks-1.3.2.12.jar) Unloaded->Constructed->Pre-initialized->Initialized->Post-initialized
Chisel{1.4.8} [Chisel] (chisel-1.5.2-1.4.8fix2.jar.zip) Unloaded->Constructed->Pre-initialized->Initialized->Post-initialized
CompactSolars{4.2.0.50} [Compact Solar Arrays] (CompactSolars-4.2.0.50.zip) Unloaded->Constructed->Pre-initialized->Initialized->Post-initialized
ComputerCraft{1.53} [ComputerCraft] (ComputerCraft-1.53.zip) Unloaded->Constructed->Pre-initialized->Initialized->Post-initialized
CCTurtle{1.53} [ComputerCraft Turtles] (ComputerCraft-1.53.zip) Unloaded->Constructed->Pre-initialized->Initialized->Post-initialized
DamageIndicatorsMod{2.7.0.1} [Damage Indicators] (DamageIndicators-2.7.0.1.zip) Unloaded->Constructed->Pre-initialized->Initialized->Post-initialized
EnderStorage{1.4.2.12} [EnderStorage] (EnderStorage-1.4.2.12.jar) Unloaded->Constructed->Pre-initialized->Initialized->Post-initialized
MineFactoryReloaded|CompatForestryPre{1.5.1R2.6.4} [MFR Compat: Forestry (2)] (MineFactoryReloaded-2.6.4-975.jar) Unloaded->Constructed->Pre-initialized->Initialized->Post-initialized
Forestry{2.2.8.2} [Forestry for Minecraft] (Forestry-2.2.8.2_1.jar) Unloaded->Constructed->Pre-initialized->Initialized->Errored
BinnieCore{1.6-pre17} [Binnie Core] (ExtraBees-1.6-pre17.jar) Unloaded->Constructed->Pre-initialized->Initialized->Post-initialized
ExtraBees{1.6-pre17} [Extra Bees] (ExtraBees-1.6-pre17.jar) Unloaded->Constructed->Pre-initialized->Initialized->Post-initialized
factorization{0.7.37} [Factorization] (Factorization-0.7.37.jar) Unloaded->Constructed->Pre-initialized->Initialized->Post-initialized
IronChest{5.2.8.433} [Iron Chest] (IronChest-5.2.8.433.zip) Unloaded->Constructed->Pre-initialized->Initialized->Post-initialized
mmmPowersuits{0.7.0-547} [MachineMuse's Modular Powersuits] (ModularPowersuits-0.7.0-547.jar) Unloaded->Constructed->Pre-initialized->Initialized->Post-initialized
Natura{1.5.1_2.1} [Natura] (Natura_2.1.jar) Unloaded->Constructed->Pre-initialized->Initialized->Post-initialized
Railcraft{7.2.3.0} [Railcraft] (Railcraft_1.5.2-7.2.3.0.jar) Unloaded->Constructed->Pre-initialized->Initialized->Post-initialized
TConstruct{1.5.1_1.3.6.3} [Tinkers' Construct] (TConstruct_1.3.6.3.jar) Unloaded->Constructed->Pre-initialized->Initialized->Post-initialized
Thaumcraft{3.0.5f} [Thaumcraft] (Thaumcraft3.0.5f.zip) Unloaded->Constructed->Pre-initialized->Initialized->Post-initialized
TwilightForest{1.18.1} [The Twilight Forest] (TwilightForest-1.18.1.zip) Unloaded->Constructed->Pre-initialized->Initialized->Post-initialized
DartCraft{Beta 0.1.17} [DartCraft] (DartCraft-0.1.17.jar) Unloaded->Constructed->Pre-initialized->Initialized->Post-initialized
deathTimer{1.0-Build.10} [Death Timer] (DeathTimer-Beta.10.jar) Unloaded->Constructed->Pre-initialized->Initialized->Post-initialized
xreliquary{1.5.2} [Xeno's Reliquary] (Reliquary1.0.6d.zip) Unloaded->Constructed->Pre-initialized->Initialized->Post-initialized
DenPipes{2.0.7} [DenPipes] (DenPipes-2.0.7.jar) Unloaded->Constructed->Pre-initialized->Initialized->Post-initialized
EnhancedCore{1.1} [EnhancedCore] (EnhancedCore-1.1.jar) Unloaded->Constructed->Pre-initialized->Initialized->Post-initialized
EP2{1.0.2 (Build: 9)} [EnhancedPortals 2] (EnhancedPortals2-1.0.2.jar) Unloaded->Constructed->Pre-initialized->Initialized->Post-initialized
EP2_CC{1.0} [EP2 ComputerCraft] (EnhancedPortals2-ComputerCraft_1.0.jar) Unloaded->Constructed->Pre-initialized->Initialized->Post-initialized
EE3{pre1h (build 16)} [Equivalent Exchange 3] (EquivalentExchange3-pre1h-16.jar) Unloaded->Constructed->Pre-initialized->Initialized->Post-initialized
ExtraUtilities{0.2.4b} [Extra Utilities] (ExtraUtils-0.2.4b.zip) Unloaded->Constructed->Pre-initialized->Initialized->Post-initialized
factorization.misc{0.7.37} [Factorization Miscellaneous Nonsense] (Factorization-0.7.37.jar) Unloaded->Constructed->Pre-initialized->Initialized->Post-initialized
factorization.dimensionalSlice{0.7.37} [Factorization Dimensional Slices] (Factorization-0.7.37.jar) Unloaded->Constructed->Pre-initialized->Initialized->Post-initialized
flatsigns{1.3.1} [Flat Signs] (FlatSigns-1.3.1.13.jar) Unloaded->Constructed->Pre-initialized->Initialized->Post-initialized
GateCopy{3.0.2} [GateCopy] (GateCopy-3.0.2.jar) Unloaded->Constructed->Pre-initialized->Initialized->Post-initialized
GraviSuite{1.9.3} [Gravitation Suite] (GraviSuite-1.9.3.zip) Unloaded->Constructed->Pre-initialized->Initialized->Post-initialized
iChunUtil{1.0.1} [iChunUtil] (iChunUtil-1.0.1.zip) Unloaded->Constructed->Pre-initialized->Initialized->Post-initialized
GraviGun{1.5.1} [GraviGun] (GravityGun-1.5.1.zip) Unloaded->Constructed->Pre-initialized->Initialized->Post-initialized
ImmibisCore{55.1.3} [Immibis Core] (Immibis-Core-1.5.2.jar) Unloaded->Constructed->Pre-initialized->Initialized->Post-initialized
Tubestuff{55.0.5} [Tubestuff] (tubestuff-55.0.5.jar) Unloaded->Constructed->Pre-initialized->Initialized->Post-initialized
GregTech_Addon{MC151} [GregTech-Addon] (gregtechmod.zip) Unloaded->Constructed->Pre-initialized->Initialized->Post-initialized
MagicBees{2.0.2} [Magic Bees] (MagicBees-2.0.2.jar) Unloaded->Constructed->Pre-initialized->Initialized->Errored
MineFactoryReloaded|CompatAppliedEnergistics{1.5.1R2.6.4} [MFR Compat: Applied Energistics] (MineFactoryReloaded-2.6.4-975.jar) Unloaded->Constructed->Pre-initialized->Initialized->Post-initialized
MineFactoryReloaded|CompatAtum{1.5.1R2.6.4} [MFR Compat: Atum] (MineFactoryReloaded-2.6.4-975.jar) Unloaded->Constructed->Pre-initialized->Initialized->Post-initialized
MineFactoryReloaded|CompatBackTools{1.5.1R2.6.4} [MFR Compat: BackTools] (MineFactoryReloaded-2.6.4-975.jar) Unloaded->Constructed->Pre-initialized->Initialized->Post-initialized
MineFactoryReloaded|CompatBiomesOPlenty{1.5.1R2.6.4} [MFR Compat: Biomes O' Plenty] (MineFactoryReloaded-2.6.4-975.jar) Unloaded->Constructed->Pre-initialized->Initialized->Post-initialized
MineFactoryReloaded|CompatChococraft{1.5.1R2.6.4} [MFR Compat: Chococraft] (MineFactoryReloaded-2.6.4-975.jar) Unloaded->Constructed->Pre-initialized->Initialized->Post-initialized
MineFactoryReloaded|CompatExtraBiomes{1.5.1R2.6.4} [MFR Compat: ExtraBiomes] (MineFactoryReloaded-2.6.4-975.jar) Unloaded->Constructed->Pre-initialized->Initialized->Post-initialized
MineFactoryReloaded|CompatForestry{1.5.1R2.6.4} [MFR Compat: Forestry] (MineFactoryReloaded-2.6.4-975.jar) Unloaded->Constructed->Pre-initialized->Initialized->Post-initialized
MineFactoryReloaded|CompatIC2{1.5.1R2.6.4} [MFR Compat: IC2] (MineFactoryReloaded-2.6.4-975.jar) Unloaded->Constructed->Pre-initialized->Initialized->Post-initialized
MineFactoryReloaded|CompatMagicalCrops{1.5.1R2.6.4} [MFR Compat: Magical Crops] (MineFactoryReloaded-2.6.4-975.jar) Unloaded->Constructed->Pre-initialized->Initialized->Post-initialized
Mystcraft{0.10.4.00} [Mystcraft] (mystcraft-uni-1.5.2-0.10.4.00.zip) Unloaded->Constructed->Pre-initialized->Initialized->Post-initialized
MineFactoryReloaded|CompatMystcraft{1.5.1R2.6.4} [MFR Compat: Mystcraft] (MineFactoryReloaded-2.6.4-975.jar) Unloaded->Constructed->Pre-initialized->Initialized->Post-initialized
MineFactoryReloaded|CompatPams{1.5.1R2.6.4} [MFR Compat: Pam's Mods] (MineFactoryReloaded-2.6.4-975.jar) Unloaded->Constructed->Pre-initialized->Initialized->Post-initialized
MineFactoryReloaded|CompatRP2{1.5.1R2.6.4} [MFR Compat: RP2] (MineFactoryReloaded-2.6.4-975.jar) Unloaded->Constructed->Pre-initialized->Initialized->Post-initialized
SoulShards{1.0.16} [Soul Shards] (SoulShards-1.0.36-universal-srg.jar) Unloaded->Constructed->Pre-initialized->Initialized->Post-initialized
MineFactoryReloaded|CompatSoulShards{1.5.1R2.6.4} [MFR Compat: SoulShards] (MineFactoryReloaded-2.6.4-975.jar) Unloaded->Constructed->Pre-initialized->Initialized->Post-initialized
MineFactoryReloaded|CompatSufficientBiomes{1.5.1R2.6.4} [MFR Compat: Sufficient Biomes] (MineFactoryReloaded-2.6.4-975.jar) Unloaded->Constructed->Pre-initialized->Initialized->Post-initialized
MFReloaded|CompatThaumcraft{1.5.1R2.6.4} [MFR Compat: Thaumcraft] (MineFactoryReloaded-2.6.4-975.jar) Unloaded->Constructed->Pre-initialized->Initialized->Post-initialized
MineFactoryReloaded|CompatThermalExpansion{1.5.1R2.6.4} [MFR Compat: Thermal Expansion] (MineFactoryReloaded-2.6.4-975.jar) Unloaded->Constructed->Pre-initialized->Initialized->Post-initialized
MineFactoryReloaded|CompatTwilightForest{1.5.1R2.6.4} [MFR Compat: TwilightForest] (MineFactoryReloaded-2.6.4-975.jar) Unloaded->Constructed->Pre-initialized->Initialized->Post-initialized
MineFactoryReloaded|CompatVanilla{1.5.1R2.6.4} [MFR Compat: Vanilla] (MineFactoryReloaded-2.6.4-975.jar) Unloaded->Constructed->Pre-initialized->Initialized->Post-initialized
MineFactoryReloaded|CompatXyCraft{1.5.1R2.6.4} [MFR Compat: XyCraft] (MineFactoryReloaded-2.6.4-975.jar) Unloaded->Constructed->Pre-initialized->Initialized->Post-initialized
MiscPeripherals{3.3} [MiscPeripherals] (MiscPeripherals-3.3c.jar) Unloaded->Constructed->Pre-initialized->Initialized->Post-initialized
ModularForceFieldSystem{2.3.0.1.28} [Modular ForceField System V2] (ModularForceFieldSystem-2.3.0.1.28.jar) Unloaded->Constructed->Pre-initialized->Initialized->Post-initialized
Natura|CompatMineFactoryReloaded{0.1} [Natura compat: MFR] (Natura_2.1.jar) Unloaded->Constructed->Pre-initialized->Initialized->Post-initialized
NEIAddons{1.7.2.r21} [NEI Addons] (neiaddons-1.5.2-1.7.2.r21.jar) Unloaded->Constructed->Pre-initialized->Initialized->Post-initialized
NEIAddons|AE{1.7.2.r21} [NEI Addons: Applied Energistics] (neiaddons-1.5.2-1.7.2.r21.jar) Unloaded->Constructed->Pre-initialized->Initialized->Post-initialized
NEIAddons|CraftingTables{1.7.2.r21} [NEI Addons: Crafting Tables] (neiaddons-1.5.2-1.7.2.r21.jar) Unloaded->Constructed->Pre-initialized->Initialized->Post-initialized
NEIAddons|ExtraBees{1.7.2.r21} [NEI Addons: Extra Bees] (neiaddons-1.5.2-1.7.2.r21.jar) Unloaded->Constructed->Pre-initialized->Initialized->Post-initialized
NEIAddons|Forestry{1.7.2.r21} [NEI Addons: Forestry] (neiaddons-1.5.2-1.7.2.r21.jar) Unloaded->Constructed->Pre-initialized->Initialized->Post-initialized
NEIAddons|MiscPeripherals{1.7.2.r21} [NEI Addons: Misc Peripherals] (neiaddons-1.5.2-1.7.2.r21.jar) Unloaded->Constructed->Pre-initialized->Initialized->Post-initialized
NEIPlugins{1.0.9.3} [NEI Plugins] (NEIPlugins-1.0.9.3.jar) Unloaded->Constructed->Pre-initialized->Initialized->Post-initialized
ObsidiPlates{1.5.0} [Obsidian Pressure Plates] (obsidiplates-1.5.2-universal-1.5.0.13.jar) Unloaded->Constructed->Pre-initialized->Initialized->Post-initialized
OCS{1.5.2.0} [OpenCCSensors] (OpenCCSensors-1.5.2.0.jar) Unloaded->Constructed->Pre-initialized->Initialized->Post-initialized
OpenPeripheral{0.1.9} [OpenPeripheral] (OpenPeripheral-0.1.9.jar) Unloaded->Constructed->Pre-initialized->Initialized->Post-initialized
PluginsforForestry{3.0.17} [PluginsforForestry] (PluginsforForestry-1.5.2-3.0.17.jar) Unloaded->Constructed->Pre-initialized->Initialized->Post-initialized
PortalGun{1.5.2} [PortalGun] (PortalGun1.5.2.zip) Unloaded->Constructed->Pre-initialized->Initialized->Post-initialized
PowerConverters{1.5.1R2.3.1} [Power Converters] (PowerConverters-2.3.1-58.jar) Unloaded->Constructed->Pre-initialized->Initialized->Post-initialized
Stackie{1.4.1.12} [Stackie] (Stackie-universal-1.3.1.12.jar) Unloaded->Constructed->Pre-initialized->Initialized->Post-initialized
StevesCarts{2.0.0.a122} [Steve's Carts] (StevesCarts2.0.0.a122.zip) Unloaded->Constructed->Pre-initialized->Initialized->Post-initialized
TConstruct|CompatMineFactoryReloaded{0.1} [TConstruct Compat: MFR] (TConstruct_1.3.6.3.jar) Unloaded->Constructed->Pre-initialized->Initialized->Post-initialized
ThaumicTinkerer{1.0.5} [Thaumic Tinkerer] (Thaumic Tinkerer [1.0.5].zip) Unloaded->Constructed->Pre-initialized->Initialized->Post-initialized
Vending{1.0.8} [Vending] (vending-1.5.2-1.0.8.jar) Unloaded->Constructed->Pre-initialized->Initialized->Post-initialized
OmniTools{3.1.6.0} [OmniTools] (OmniTools-3.1.6.0.jar) Unloaded->Constructed->Pre-initialized->Initialized->Post-initialized
LWJGL: 2.4.2
OpenGL: AMD Radeon HD 7900 Series GL version 4.3.12458 Compatibility Profile Context 13.200.16.0, ATI Technologies Inc.
Is Modded: Definitely; Client brand changed to 'fml,forge'
Type: Client (map_client.txt)
Texture Pack: KoP 1.5 V2 Photo Realism 256.zip
Profiler Position: N/A (disabled)
Vec3 Pool Size: ~~ERROR~~ NullPointerException: null
Ich bin ja jetzt weder ein Experte in Minecraft, noch habe ich einen Schimmer von Ahnung von Java, noch finde ich, dass die Frage hier irgendwas zu suchen hat, aber:
Und dann wundert dich
Gesichtspalme.
Wenn du FTB um einen Mod erweitern willst, ist's fast klar dass du auf solche Probleme stößt.
Frag im FTB-Forum nach, da kann man dir wohl eher helfen da dort viele "Experten" sitzen im Gegensatz zu hier.
Die FTB Foren sind leider auf Englich und mit mein paar Brocken Englich komm ich da nicht weit.
Vielleicht kann man mir hier auch helfen.
Der Grund des Fehlers steht schon in der ersten Zeile des Crash-Reports und ist nicht gerade selten bei der Menge an Mods. In Minecraft wird jedem Item und Block eine bestimmte Nummer (ID) zugeordnet, um sie identifizieren zu könne.
In deinem Fall will die Mod "Forestry" eine ID (13526 laut Crash-Report) nutzen, die schon von der Mod "Immibis Microblocks" belegt ist. Zur Lösung einfach mal in der Config von einem der beiden Mods die Nummer auf eine noch nicht belegte ändern.
Falls du "Not Enough Items" installiert hast, kannst du dir damit ingame eine Liste der freien Nummer erstellen lassen. Damit Minecraft dafür startet einfach Forestry oder Microblocks vorübergehend wieder rausnehmen.
Hatte solche ID Konflickte auch mehr als genug gehabt, als ich meinen Server mit einer ähnlichen Menge Mods eingerichtet habe. Mich wundert es sogar fast, dass es bei dir erst bei der 113. Mod auftritt.
Bin auch kein Experte in Sachen MC und in Java. Aber selbst mit ein bisschen englisch kann man weit kommen. Des Weiteren kannst auch du so was lernen. Ist jetzt nicht persönlich gemeint. Die Fehlermeldung vielleicht auch in einen Code-Tag/Spoiler-Tag packen, damit es den Thread nicht so lang zieht.
Laut der Meldung die asdfman zitiert hat, ist es ein Config-Problem. Vllt. vertragen sich 2 Mods nicht miteinander. Hatte ich auch schon als ich noch MC gespielt hatte.
Vielen Dank​
Ich habe die Datei gefunden, Nummer geändert und es funktioniert!!!
Das Problem hatte ich schon einpaarmal aber ich konnte es immer irgendwie umgehen.
Wenn das mit der Nummer immer so einfach geht sind es bald über 200 Mods:freaky:
Und der Server läuft auch schon ohne Probleme.
