Xetoxyc
- Nov. 2010
hab mir gerade eben einen FTP Server eingerichtet und ohne TLS funktioniert auch alles nur mit wirt er mit den fehler
Hier meine mod_tls_c configuration:
Code:
GnuTLS error -9: A TLS packet with unexpected length was received
Code:
# Proftpd sample configuration for FTPS connections.
# Note that FTPS impose some limitations in NAT traversing.
# See http://www.castaglia.org/proftpd/doc/contrib/ProFTPD-mini-HOWTO-TLS.html
# for more information.
<IfModule mod_tls.c>
TLSEngine on
TLSLog /var/log/proftpd/tls.log
TLSProtocol SSLv23
# Server SSL certificate. You can generate a self-signed certificate using
# a command like:
# openssl req -x509 -newkey rsa:1024 \
# -keyout /etc/ssl/private/proftpd.key -out /etc/ssl/certs/proftpd.crt \
# -nodes -days 365
# The proftpd.key file must be readable by root only. The other file can be
# readable by anyone.
# chmod 0600 /etc/ssl/private/proftpd.key
# chmod 0640 /etc/ssl/private/proftpd.key
TLSRSACertificateFile /etc/ssl/certs/proftpd.crt
TLSRSACertificateKeyFile /etc/ssl/private/proftpd.key
# CA the server trusts
#TLSCACertificateFile /etc/ssl/certs/CA.pem
# or avoid CA cert and be verbose
TLSOptions NoCertRequest
# Per default drop connection if client tries to start a renegotiate
# This is a fix for CVE-2009-3555 but could break some clients.
#TLSOptions AllowClientRenegotiations
# Authenticate clients that want to use FTP over TLS?
TLSVerifyClient off
# Are clients required to use FTP over TLS when talking to this server?
TLSRequired off
# Allow SSL/TLS renegotiations when the client requests them, but
# do not force the renegotations. Some clients do not support
# SSL/TLS renegotiations; when mod_tls forces a renegotiation, these
# clients will close the data connection, or there will be a timeout
# on an idle data connection.
TLSRenegotiate none
</IfModule>
