CORSAIR Marcus
Corsair Support
- Okt. 2021
Hallo zusammen!
Hier könnt ihr die aktuellen Release Notes von iCUE einsehen, inkl. einem Link zum download.
iCUE 5.12.97 Issues Resolved
Software Enhancements
DIY Product Enhancements
- Resolved an issue that caused iCUE to unexpectedly quit when importing a profile on a system with a NVIDIA Founder’s Card GPU installed
- Battery Status sensor widgets on the Dashboard will now properly show a graph in the background
- Certain widgets will no longer be missing their context menus when added to the Dashboard
- Lighting Effects will no longer be duplicated when dragging and dropping layers in the list
- Resolved various issues with naming in Murals
- HARPOON PRO will now properly show up as a device in Murals
- Resolved an issue that causes KATAR PRO WIRELESS to stop responding if the polling rate is changed to 2000 Hz
- Resolved an issue that prevented Imitate Holding Key from working properly with Hardware Key Assignments
- Resolved various issues that may cause iCUE to unexpectedly quit when changing polling rates across various devices
- Resolved various issues that caused keypress combinations from working properly with Japanese layouts on certain keyboards
- The Brightness Control icon will no longer be missing for the K100 Control Wheel
- Resolved an issue that caused K70 CORE RGB to show up as a CRP_DISABLED device after a firmware update
- Resolved the following issues with iCUE NEXUS:
- Background image will now display properly when using the 640x48 px window size
- Image rescaling logic was improved
- Profile switching issues were fixed so that all profiles will properly appear on the rotation list
- Changing Lighting Link will no longer cause the name of the effect to disappear
- Renaming an EQ preset will properly update the device screen
- GIPHY support has been added to all LCD devices – users can now browse, download, and add animated GIFs to their devices. To find this feature select 'Images/GIF' then click the 'GIPHY' tab:
- Resolved an issue that caused a delay in DDR5 detection when creating a new user profile
- Resolved an issue with VOYAGER Gaming Laptops battery widgets not updating their status properly after the charger is removed – the widget for this sensor can also now be properly added to the Home Screen
- The brightness between the keyboard and the touch bar for VOYAGER Gaming Laptops will now be properly adjusted together when using the hotkey
- An additional prompt has been added to the Performance Manager tab for DDR5
- Resolved various issues with the customization of Alerts
- Resolved a display issue when using custom fan curve names when a QX fan is connected
