Release Notes for iCUE 5.15.117
CORSAIR Marcus
Corsair Support
Okt. 2021
Hallo zusammen!
Hier könnt ihr die aktuellen Release Notes von iCUE einsehen, inkl. einem Link zum download.
Software Enhancements​
  • Resolved an issue that prevented firmware updates from starting during the prompt for a USB cable to be connected
  • Resolved an issue that prevents the border around the Macro Recording area from blinking during a macro recording session
  • Voicemod SDK is updated to the latest version – however, “Instant Censor Beep” and “Mute for Me On/Off” are temporarily disabled until they are re-implemented in the SDK
  • iCUE will no longer fully quit while there is an active window prompt
  • Improved the design for progress bars and their associated buttons
  • Modules can no longer be deleted for devices that are still connected to the system
  • Resolved an issue that caused temperature units to be displayed in Fahrenheit instead of Celsius by default
  • iCUE will no longer crash while switching profiles during a pointer hover on an icon in Key Assignments
  • Profile names will no longer be allowed to exceed 255 characters
  • Info panels in Device Memory Mode will no longer have a text cut-off
  • Resolved some user interface issues that caused improper scaling in some of the device panels
  • Resolved an issue that causes iCUE to hang during the saving process of a hardware profile
  • The following devices have been added for Govee Support:
    1. H610A Light Strips
    2. H61E1 Light Strips
    3. H61D3 Light Strips
    4. H6065 Y Light Bars
    5. H6047 Light Bars
HID Product Enhancements​
  • Additional notifications were added when saving multiple hardware profiles to a device
  • A notification has been added for devices that are out of space while saving a hardware profile
  • Added some improvements to Device Memory Mode to help with discarding changes
  • Improved the notification(s) shown in iCUE macOS for a headset’s first detection in iCUE
  • Pointer Speed and Enhance Pointer Precision have been removed for mice – users should enable/disable these features now through Windows Control Panel for pointer devices
  • Resolved a rare issue that caused Lighting Layers and/or Key Assignments to disappear after changing DPI settings and saving the hardware profile
DIY Product Enhancements​
  • Various issues were resolved with Device Memory Mode while saving images to LCD-supported devices
  • Switching profiles will no longer cause a lighting effect to be stuck for iCUE LINK ecosystem devices
  • Updated the HX1200i image to properly reflect the actual device
Zudem füge ich euch unseren neusten CORSAIR Explorer Artikel zum Thema iCUE 5.14+ hinzu:
Reaktionen: AthlonXP, Arizona66, Tycoon187 und 3 andere
Hallo @CORSAIR Marcus,
Auch mit der neuen Version funktionieren noch immer nicht alle Beleuchtungseffekte. Auch stürzt noch immer ICue ab geht dann in den Geräte Modus und wenn man dann nicht aufpasst überhitzt die Hardware vom PC und wird schön mit Roten Warnungen preisgegeben. Man hockt echt vor dem System und wartet auf den nächsten ICue Absturz und das sollte beim Zocken erstmal gar nicht passieren. Wenn ich den Absturz bemerke zeigt mir eure Hardware auch 70 Grad plus an und alle Lüfter sind dann gut 1 Minute drann das System herunterzukühlen. Das ist echt nervig!
Schwierig zu sagen woran es liegt.
Am besten wäre mal das System neu aufzusetzen. Inkl Bios Update Check, Power Limits für den CPU eingestellt. Aktuelle Mainboards bieten teilweise sogar schon Baseline Einstellungen für Intel CPUs an.
Anschließend von der Intel Website die Chipsatz Treiber downloaden, Windows Updates durchführen und dann ein Windows Wiederherstellungspunkt erstellen. Danach iCUE installieren und testen.
Reaktionen: RedBaron_DE
Corsair hats scheinbar mit den Makros verkackt...
Hab immer mittels G-Taste von Edge/Firefox einzelne geöffnete Fenster geschlossen (Strg+F4 ausgelöst)
Geht nu heut nicht mehr.
Profil für Edge/Firefox wird richtig aktiviert, wenn ich auf das Fenster gehe, Tastendruck ist eingestellt... machts aber nicht. Stelle ich ein er soll z.b. ein Programm öffnen funktioniert das. Nur reagiert der nicht auf Tastendruck. Drücke ich normal Strg+F4 schliesst der den geöffneten Tab.
mir geht der müll inzwischen so auf die nerven das ich mein headset und alle anderen corsair geräte wieder verkaufe...
Edit: Nach Intensiver Fehlersuche habe ich den Fehler ausgemacht, es lag an euren 140er Standard Lüfter der den 7000D Airflow beiliegt. Schliesse ich diesen an meinen Mainboard an zerschiesst man sich sein ICUE! Verstehe nur nicht wie das eine mit den ICUE Link System zusammen spielt. Aber das ist der nächste Fehler den du bitte mal den ICUE Team mitteilen solltest.
Reaktionen: CORSAIR Marcus
Heute nach Tagen Abstinenz PC hochgefahren mit der aktuellen ICUE Software Version hier empfangen worden.
ALLE Profile zerschossen, keine angepassten Lüfterkurven mehr, Lüfter drehen alle zu 100% egal was man einstellt...
Super! Daumen hoch!
ja das Problem mit den Makros habe ich auch.
Muss die Software komplett löschen und neu installieren da auch eine Reparatur hier fehlschlägt.
