Flatsteff
- Nov. 2005
Hab hier einen Rock64 mit Armbian ( Desktopversion ) und kann leider über remotedesktop von win 10 nur auf den Root Account zugreifen, warum? Log von xrdp und sesman findet ihr unten. Was läuft da falsch?
LOG XRDP:
[20230522-20:23:02] [INFO ] Socket 12: AF_INET6 connection received from ::ffff:192.168.1.145 port 61417
[20230522-20:23:02] [INFO ] Using default X.509 certificate: /etc/xrdp/cert.pem
[20230522-20:23:02] [INFO ] Using default X.509 key file: /etc/xrdp/key.pem
[20230522-20:23:02] [ERROR] Cannot read private key file /etc/xrdp/key.pem: Permission denied
[20230522-20:23:02] [ERROR] libxrdp_force_read: header read error
[20230522-20:23:02] [ERROR] Processing [ITU-T T.125] Connect-Initial failed
[20230522-20:23:02] [ERROR] [MCS Connection Sequence] receive connection request failed
[20230522-20:23:02] [ERROR] xrdp_sec_incoming: xrdp_mcs_incoming failed
[20230522-20:23:02] [ERROR] xrdp_rdp_incoming: xrdp_sec_incoming failed
[20230522-20:23:02] [ERROR] xrdp_process_main_loop: libxrdp_process_incoming failed
[20230522-20:23:02] [ERROR] xrdp_iso_send: trans_write_copy_s failed
[20230522-20:23:02] [ERROR] Sending [ITU T.125] DisconnectProviderUltimatum failed
[20230522-20:23:02] [INFO ] Socket 12: AF_INET6 connection received from ::ffff:192.168.1.145 port 61418
[20230522-20:23:02] [INFO ] Connected client computer name: DELLG515SE
[20230522-20:23:02] [WARN ] Received [MS-RDPBCGR] TS_UD_HEADER type 0xc006 is unknown (ignored)
[20230522-20:23:02] [WARN ] Received [MS-RDPBCGR] TS_UD_HEADER type 0xc00a is unknown (ignored)
[20230522-20:23:02] [INFO ] xrdp_load_keyboard_layout: Keyboard information sent by the RDP client, keyboard_type:[0x04], keyboard_subtype:[0x00], keylayout:[0x00000407]
[20230522-20:23:02] [INFO ] xrdp_load_keyboard_layout: model [] variant [] layout [de] options []
[20230522-20:23:02] [INFO ] Non-TLS connection established from ::ffff:192.168.1.145 port 61418: encrypted with standard RDP security
[20230522-20:23:04] [INFO ] xrdp_caps_process_pointer: client supports new(color) cursor
[20230522-20:23:04] [INFO ] xrdp_process_offscreen_bmpcache: support level 1 cache size 10485760 MB cache entries 100
[20230522-20:23:04] [INFO ] xrdp_caps_process_codecs: nscodec, codec id 1, properties len 3
[20230522-20:23:04] [WARN ] xrdp_caps_process_codecs: unknown codec id 5
[20230522-20:23:04] [INFO ] xrdp_caps_process_codecs: RemoteFX, codec id 3, properties len 49
[20230522-20:23:04] [INFO ] Loading keymap file /etc/xrdp/km-00000407.ini
[20230522-20:23:04] [WARN ] local keymap file for 0x00000407 found and doesn't match built in keymap, using local keymap file
[20230522-20:23:14] [INFO ] connecting to sesman ip 127.0.0.1 port 3350
[20230522-20:23:14] [INFO ] xrdp_wm_log_msg: sesman connect ok
[20230522-20:23:14] [INFO ] sesman connect ok
[20230522-20:23:14] [INFO ] sending login info to session manager, please wait...
[20230522-20:23:14] [INFO ] xrdp_wm_log_msg: login successful for display 10
[20230522-20:23:14] [INFO ] login successful for display 10
[20230522-20:23:14] [INFO ] loaded module 'libxup.so' ok, interface size 10296, version 4
[20230522-20:23:14] [INFO ] started connecting
[20230522-20:23:14] [INFO ] lib_mod_connect: connecting via UNIX socket
[20230522-20:23:16] [INFO ] lib_mod_log_peer: xrdp_pid=2256 connected to X11rdp_pid=2273 X11rdp_uid=0 X11rdp_gid=0 client_ip=::ffff:192.168.1.145 client_port=61418
[20230522-20:23:16] [INFO ] connected ok
[20230522-20:26:51] [INFO ] Received termination signal, stopping the server accept new connections thread
[20230522-20:27:21] [INFO ] address [0.0.0.0] port [3389] mode 1
[20230522-20:27:21] [INFO ] listening to port 3389 on 0.0.0.0
[20230522-20:27:21] [INFO ] xrdp_listen_pp done
[20230522-20:27:23] [INFO ] starting xrdp with pid 1195
[20230522-20:27:23] [INFO ] address [0.0.0.0] port [3389] mode 1
[20230522-20:27:23] [INFO ] listening to port 3389 on 0.0.0.0
[20230522-20:27:23] [INFO ] xrdp_listen_pp done
[20230522-20:27:33] [INFO ] Socket 12: AF_INET6 connection received from ::ffff:192.168.1.145 port 61829
[20230522-20:27:33] [INFO ] Using default X.509 certificate: /etc/xrdp/cert.pem
[20230522-20:27:33] [INFO ] Using default X.509 key file: /etc/xrdp/key.pem
[20230522-20:27:33] [ERROR] Cannot read private key file /etc/xrdp/key.pem: Permission denied
[20230522-20:27:33] [ERROR] libxrdp_force_read: header read error
[20230522-20:27:33] [ERROR] Processing [ITU-T T.125] Connect-Initial failed
[20230522-20:27:33] [ERROR] [MCS Connection Sequence] receive connection request failed
[20230522-20:27:33] [ERROR] xrdp_sec_incoming: xrdp_mcs_incoming failed
[20230522-20:27:33] [ERROR] xrdp_rdp_incoming: xrdp_sec_incoming failed
[20230522-20:27:33] [ERROR] xrdp_process_main_loop: libxrdp_process_incoming failed
[20230522-20:27:33] [ERROR] xrdp_iso_send: trans_write_copy_s failed
[20230522-20:27:33] [ERROR] Sending [ITU T.125] DisconnectProviderUltimatum failed
[20230522-20:27:33] [INFO ] Socket 12: AF_INET6 connection received from ::ffff:192.168.1.145 port 61830
[20230522-20:27:33] [INFO ] Connected client computer name: DELLG515SE
[20230522-20:27:33] [WARN ] Received [MS-RDPBCGR] TS_UD_HEADER type 0xc006 is unknown (ignored)
[20230522-20:27:33] [WARN ] Received [MS-RDPBCGR] TS_UD_HEADER type 0xc00a is unknown (ignored)
[20230522-20:27:33] [INFO ] xrdp_load_keyboard_layout: Keyboard information sent by the RDP client, keyboard_type:[0x04], keyboard_subtype:[0x00], keylayout:[0x00000407]
[20230522-20:27:33] [INFO ] xrdp_load_keyboard_layout: model [] variant [] layout [de] options []
[20230522-20:27:33] [INFO ] Non-TLS connection established from ::ffff:192.168.1.145 port 61830: encrypted with standard RDP security
[20230522-20:27:33] [INFO ] xrdp_caps_process_pointer: client supports new(color) cursor
[20230522-20:27:33] [INFO ] xrdp_process_offscreen_bmpcache: support level 1 cache size 10485760 MB cache entries 100
[20230522-20:27:33] [INFO ] xrdp_caps_process_codecs: nscodec, codec id 1, properties len 3
[20230522-20:27:33] [WARN ] xrdp_caps_process_codecs: unknown codec id 5
[20230522-20:27:33] [INFO ] xrdp_caps_process_codecs: RemoteFX, codec id 3, properties len 49
[20230522-20:27:33] [INFO ] Loading keymap file /etc/xrdp/km-00000407.ini
[20230522-20:27:33] [WARN ] local keymap file for 0x00000407 found and doesn't match built in keymap, using local keymap file
[20230522-20:27:44] [INFO ] connecting to sesman ip 127.0.0.1 port 3350
[20230522-20:27:44] [INFO ] xrdp_wm_log_msg: sesman connect ok
[20230522-20:27:44] [INFO ] sesman connect ok
[20230522-20:27:44] [INFO ] sending login info to session manager, please wait...
[20230522-20:27:44] [INFO ] xrdp_wm_log_msg: login successful for display 10
[20230522-20:27:44] [INFO ] login successful for display 10
[20230522-20:27:44] [INFO ] loaded module 'libxup.so' ok, interface size 10296, version 4
[20230522-20:27:44] [INFO ] started connecting
[20230522-20:27:44] [INFO ] lib_mod_connect: connecting via UNIX socket
[20230522-20:28:36] [INFO ] Socket 12: AF_INET6 connection received from ::ffff:192.168.1.145 port 61915
[20230522-20:28:36] [INFO ] Using default X.509 certificate: /etc/xrdp/cert.pem
[20230522-20:28:36] [INFO ] Using default X.509 key file: /etc/xrdp/key.pem
[20230522-20:28:36] [ERROR] Cannot read private key file /etc/xrdp/key.pem: Permission denied
[20230522-20:28:36] [ERROR] libxrdp_force_read: header read error
[20230522-20:28:36] [ERROR] Processing [ITU-T T.125] Connect-Initial failed
[20230522-20:28:36] [ERROR] [MCS Connection Sequence] receive connection request failed
[20230522-20:28:36] [ERROR] xrdp_sec_incoming: xrdp_mcs_incoming failed
[20230522-20:28:36] [ERROR] xrdp_rdp_incoming: xrdp_sec_incoming failed
[20230522-20:28:36] [ERROR] xrdp_process_main_loop: libxrdp_process_incoming failed
[20230522-20:28:36] [ERROR] xrdp_iso_send: trans_write_copy_s failed
[20230522-20:28:36] [ERROR] Sending [ITU T.125] DisconnectProviderUltimatum failed
[20230522-20:28:36] [INFO ] Socket 12: AF_INET6 connection received from ::ffff:192.168.1.145 port 61916
[20230522-20:28:36] [INFO ] Connected client computer name: DELLG515SE
[20230522-20:28:36] [WARN ] Received [MS-RDPBCGR] TS_UD_HEADER type 0xc006 is unknown (ignored)
[20230522-20:28:36] [WARN ] Received [MS-RDPBCGR] TS_UD_HEADER type 0xc00a is unknown (ignored)
[20230522-20:28:36] [INFO ] xrdp_load_keyboard_layout: Keyboard information sent by the RDP client, keyboard_type:[0x04], keyboard_subtype:[0x00], keylayout:[0x00000407]
[20230522-20:28:36] [INFO ] xrdp_load_keyboard_layout: model [] variant [] layout [de] options []
[20230522-20:28:36] [INFO ] Non-TLS connection established from ::ffff:192.168.1.145 port 61916: encrypted with standard RDP security
[20230522-20:28:36] [INFO ] xrdp_caps_process_pointer: client supports new(color) cursor
[20230522-20:28:36] [INFO ] xrdp_process_offscreen_bmpcache: support level 1 cache size 10485760 MB cache entries 100
[20230522-20:28:36] [INFO ] xrdp_caps_process_codecs: nscodec, codec id 1, properties len 3
[20230522-20:28:36] [WARN ] xrdp_caps_process_codecs: unknown codec id 5
[20230522-20:28:36] [INFO ] xrdp_caps_process_codecs: RemoteFX, codec id 3, properties len 49
[20230522-20:28:36] [INFO ] Loading keymap file /etc/xrdp/km-00000407.ini
[20230522-20:28:36] [WARN ] local keymap file for 0x00000407 found and doesn't match built in keymap, using local keymap file
[20230522-20:31:14] [INFO ] connection problem, giving up
[20230522-20:31:14] [INFO ] some problem
[20230522-20:31:14] [ERROR] xrdp_sec_send_fastpath: xrdp_fastpath_send failed
[20230522-20:31:14] [ERROR] xrdp_rdp_send_fastpath: xrdp_sec_send_fastpath failed
[20230522-20:31:14] [ERROR] xrdp_orders_send: xrdp_rdp_send_fastpath failed
[20230522-20:31:14] [ERROR] libxrdp_set_pointer: xrdp_rdp_send_fastpath failed
[20230522-20:31:14] [ERROR] xrdp_iso_send: trans_write_copy_s failed
[20230522-20:31:14] [ERROR] xrdp_mcs_send: xrdp_iso_send failed
[20230522-20:31:14] [ERROR] xrdp_sec_send: xrdp_mcs_send failed
[20230522-20:31:14] [ERROR] xrdp_rdp_send_data: xrdp_sec_send failed
[20230522-20:31:14] [ERROR] Sending [MS-RDPBCGR] TS_SHUTDOWN_DENIED_PDU failed
[20230522-20:31:14] [ERROR] xrdp_sec_recv: xrdp_mcs_recv failed
[20230522-20:31:14] [ERROR] xrdp_rdp_recv: xrdp_sec_recv failed
[20230522-20:31:14] [ERROR] libxrdp_process_data: xrdp_rdp_recv failed
[20230522-20:31:14] [ERROR] xrdp_process_data_in: xrdp_process_loop failed
[20230522-20:31:14] [ERROR] Sending [ITU T.125] DisconnectProviderUltimatum failed
[20230522-20:36:52] [INFO ] connecting to sesman ip 127.0.0.1 port 3350
[20230522-20:36:53] [INFO ] xrdp_wm_log_msg: sesman connect ok
[20230522-20:36:53] [INFO ] sesman connect ok
[20230522-20:36:53] [INFO ] sending login info to session manager, please wait...
[20230522-20:36:53] [INFO ] xrdp_wm_log_msg: login successful for display 10
[20230522-20:36:53] [INFO ] login successful for display 10
[20230522-20:36:53] [INFO ] loaded module 'libxup.so' ok, interface size 10296, version 4
[20230522-20:36:53] [INFO ] started connecting
[20230522-20:36:53] [INFO ] lib_mod_connect: connecting via UNIX socket
[20230522-20:36:54] [INFO ] lib_mod_log_peer: xrdp_pid=2558 connected to X11rdp_pid=2662 X11rdp_uid=0 X11rdp_gid=0 client_ip=::ffff:192.168.1.145 client_port=61916
[20230522-20:36:54] [INFO ] connected ok
LOS SESMAN
[20230522-20:23:14] [INFO ] Socket 8: AF_INET6 connection received from ::1 port 36998
[20230522-20:23:14] [INFO ] Terminal Server Users group is disabled, allowing authentication
[20230522-20:23:14] [INFO ] ++ created session (access granted): username root, ip ::ffff:192.168.1.145:61418 - socket: 12
[20230522-20:23:14] [INFO ] starting Xorg session...
[20230522-20:23:14] [INFO ] Starting session: session_pid 2257, display :10.0, width 1920, height 1080, bpp 24, client ip ::ffff:192.168.1.145:61418 - socket: 12, user name root
[20230522-20:23:14] [INFO ] [session start] (display 10): calling auth_start_session from pid 2257
[20230522-20:23:14] [ERROR] sesman_data_in: scp_process_msg failed
[20230522-20:23:14] [ERROR] sesman_main_loop: trans_check_wait_objs failed, removing trans
[20230522-20:23:15] [INFO ] Starting X server on display 10: /usr/lib/xorg/Xorg :10 -auth .Xauthority -config xrdp/xorg.conf -noreset -nolisten tcp -logfile .xorgxrdp.%s.log
[20230522-20:23:15] [INFO ] Found X server running at /tmp/.X11-unix/X10
[20230522-20:23:15] [INFO ] Starting the default window manager on display 10: /etc/xrdp/startwm.sh
[20230522-20:23:15] [INFO ] Session started successfully for user root on display 10
[20230522-20:23:15] [INFO ] Starting the xrdp channel server for display 10
[20230522-20:23:15] [INFO ] Session in progress on display 10, waiting until the window manager (pid 2272) exits to end the session
[20230522-20:26:19] [INFO ] Calling auth_stop_session and auth_end from pid 2257
[20230522-20:26:19] [INFO ] Terminating X server (pid 2273) on display 10
[20230522-20:26:19] [INFO ] Terminating the xrdp channel server (pid 2275) on display 10
[20230522-20:26:19] [INFO ] X server on display 10 (pid 2273) returned exit code 0 and signal number 0
[20230522-20:26:19] [INFO ] xrdp channel server for display 10 (pid 2275) exit code 0 and signal number 0
[20230522-20:26:19] [INFO ] cleanup_sockets:
[20230522-20:26:19] [INFO ] ++ terminated session: username root, display :10.0, session_pid 2257, ip ::ffff:192.168.1.145:61418 - socket: 12
[20230522-20:26:51] [INFO ] shutting down sesman 1
[20230522-20:27:21] [INFO ] starting xrdp-sesman with pid 1086
[20230522-20:27:44] [INFO ] Socket 8: AF_INET6 connection received from ::1 port 55262
[20230522-20:27:44] [INFO ] Terminal Server Users group is disabled, allowing authentication
[20230522-20:27:44] [INFO ] ++ created session (access granted): username test2, ip ::ffff:192.168.1.145:61830 - socket: 12
[20230522-20:27:44] [INFO ] starting Xorg session...
[20230522-20:27:44] [INFO ] Starting session: session_pid 2080, display :10.0, width 1920, height 1080, bpp 24, client ip ::ffff:192.168.1.145:61830 - socket: 12, user name test2
[20230522-20:27:44] [INFO ] [session start] (display 10): calling auth_start_session from pid 2080
[20230522-20:27:44] [ERROR] sesman_data_in: scp_process_msg failed
[20230522-20:27:44] [ERROR] sesman_main_loop: trans_check_wait_objs failed, removing trans
[20230522-20:27:45] [INFO ] Starting X server on display 10: /usr/lib/xorg/Xorg :10 -auth .Xauthority -config xrdp/xorg.conf -noreset -nolisten tcp -logfile .xorgxrdp.%s.log
[20230522-20:27:55] [WARN ] Timed out waiting for X server on display 10 to startup
[20230522-20:27:55] [INFO ] Session started successfully for user test2 on display 10
[20230522-20:27:55] [INFO ] Session in progress on display 10, waiting until the window manager (pid 2094) exits to end the session
[20230522-20:27:55] [INFO ] Starting the xrdp channel server for display 10
[20230522-20:27:55] [ERROR] There is no X server active on display 10
[20230522-20:27:55] [ERROR] A fatal error has occured attempting to start the window manager on display 10, aborting connection
[20230522-20:27:55] [WARN ] Window manager (pid 2094, display 10) exited quickly (0 secs). This could indicate a window manager config problem
[20230522-20:27:55] [INFO ] Calling auth_stop_session and auth_end from pid 2080
[20230522-20:27:55] [INFO ] Terminating X server (pid 2095) on display 10
[20230522-20:27:55] [INFO ] Terminating the xrdp channel server (pid 2426) on display 10
[20230522-20:27:55] [INFO ] X server on display 10 (pid 2095) returned exit code 1 and signal number 0
[20230522-20:27:55] [INFO ] xrdp channel server for display 10 (pid 2426) exit code 0 and signal number 0
[20230522-20:27:55] [INFO ] cleanup_sockets:
[20230522-20:27:55] [INFO ] ++ terminated session: username test2, display :10.0, session_pid 2080, ip ::ffff:192.168.1.145:61830 - socket: 12
[20230522-20:36:52] [INFO ] Socket 8: AF_INET6 connection received from ::1 port 57054
[20230522-20:36:53] [INFO ] Terminal Server Users group is disabled, allowing authentication
[20230522-20:36:53] [INFO ] ++ created session (access granted): username root, ip ::ffff:192.168.1.145:61916 - socket: 12
[20230522-20:36:53] [INFO ] starting Xorg session...
[20230522-20:36:53] [INFO ] Starting session: session_pid 2645, display :10.0, width 1920, height 1080, bpp 24, client ip ::ffff:192.168.1.145:61916 - socket: 12, user name root
[20230522-20:36:53] [INFO ] [session start] (display 10): calling auth_start_session from pid 2645
[20230522-20:36:53] [ERROR] sesman_data_in: scp_process_msg failed
[20230522-20:36:53] [ERROR] sesman_main_loop: trans_check_wait_objs failed, removing trans
[20230522-20:36:53] [INFO ] Starting X server on display 10: /usr/lib/xorg/Xorg :10 -auth .Xauthority -config xrdp/xorg.conf -noreset -nolisten tcp -logfile .xorgxrdp.%s.log
[20230522-20:36:54] [INFO ] Found X server running at /tmp/.X11-unix/X10
[20230522-20:36:54] [INFO ] Starting the default window manager on display 10: /etc/xrdp/startwm.sh
[20230522-20:36:54] [INFO ] Session started successfully for user root on display 10
[20230522-20:36:54] [INFO ] Starting the xrdp channel server for display 10
[20230522-20:36:54] [INFO ] Session in progress on display 10, waiting until the window manager (pid 2661) exits to end the session
