Schon das zweite Mal Fehler beim Brennen. Woran liegst?
MichaelH.
Banned
Mai 2012
Hab mal das Log kopiert.
Kann jemand von euch erkennen, an was es den liegt?
Allow Unicode Labels: 0
Duplicate Meta Data: 1
MS Info File: 00000000
VMS Rollback File: 00000000
Create ISO bridge: 0
ECC Block Length: 32
Sparing Packet Length: 32
Allocation Unit Size: 32
Alignment Unit Size: 32
Make Writable: 0
Access Type: Read-only
15:41:56 #19 Text 0 File WriterStatus.cpp, Line 245
<H: HL-DT-ST BD-RE BH16NS40> start writing Lead-Out at LBA 11907840 (B5B300h), length 0 blocks
15:41:56 #20 Phase 29 File dlgbrnst.cpp, Line 1716
Speed measurement completed: 35.5x (159.788 KB/s)
15:41:56 #21 Phase 36 File dlgbrnst.cpp, Line 1767
Burn process started at 1x (4.495 KB/s)
15:41:58 #22 Text 0 File ThreadedTransferInterface.cpp, Line 2695
Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0
15:41:58 #23 Text 0 File Cdrdrv.cpp, Line 10168
---- Disc Structure (BD): Disc Information on BD (00h) ----
Media Type: 1, Layer: 0, Address: 0 (0 h), AGID: 0; Length: 4098
--- Header ---
Disc Information Identifier: <DI>
Disc Information Format: 01 h
Number of DI Units/Aux Frames in each DI block: 5
Number of (recording) layer to which this DI Unit applies: 0
DI unit Sequence Number in DI Block: 0
Continuation flag: Next DI Unit is the start of a new set of parameters (0)
Number of DI bytes in use in this DI unit: 98
--- Body ---
Disc Type Identifier: <BDR>
Disc Size/Class/Version: 1
DI Unit Format dependent contents:
BD Structure: 18 (12 h):
1 recording layer (SL), BD-R
Hybrid Disc identifier/Channel bit length: 1 (1 h):
no DVD layer present, no CD layer present
channel bit length of 74,5 nm (25.0 GB max. per layer)
Push-Pull polarity flag bits: 00 h
Recorded mark polarity flag bits: 00 h
BCA descriptor: BCA-code present (1)
15:42:12 #24 Text 0 File BD.cpp, Line 392
Format BD-R with Format Type 0h, sub-type 0, spare area size 0 -> return code 0
Allocated spare area size on disc 196608
BD: Start write address at LBA 0, Recording mode: unknown Recording Mode (0),
spare area allocation: default (no action) (0), Stream recording: NO (0); return code 0
15:42:12 #25 Text 0 File ThreadedTransfer.cpp, Line 273
Pipe memory size 83836800
16:13:58 #26 SPTI -1064 File SCSIPassThrough.cpp, Line 215
CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1064)
CDB Data: 0x2A 00 00 B4 74 00 00 00 20 00 00 00
Sense Key: 0x05 (KEY_ILLEGAL_REQUEST)
Sense Code: 0x21
Sense Qual: 0x00
Sense Area: 0x70 00 05 00 00 00 00 0A 00 00 00 00 21
Buffer x19ed38c0: Len x10000
0x8A EB A7 CC 75 5B 2A 8B C7 D7 38 F8 63 05 4B 08
0x5B 62 2C 1C C5 A2 DA 21 8D 4F 34 0B 04 DB E9 C3
0xE9 A2 DF 39 27 B4 57 CB BD 88 47 85 8F CD 5B A4
16:13:58 #27 CDR -1064 File Writer.cpp, Line 306
Invalid block address
16:14:15 #28 Text 0 File DVDPlusDualLayer.cpp, Line 1452
SetDriveCaps: Set LAST LBA of layer 1 to 0
16:14:15 #29 Phase 38 File dlgbrnst.cpp, Line 1767
Burn process failed at 1x (4.495 KB/s)
16:14:15 #30 Text 0 File SCSIPTICommands.cpp, Line 267
SPTIDismountVolume - completed successfully for FSCTL_DISMOUNT_VOLUME
16:14:20 #31 Text 0 File Cdrdrv.cpp, Line 11478
DriveLocker: UnLockVolume completed
16:14:20 #32 Text 0 File SCSIPTICommands.cpp, Line 430
UnLockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL
Existing drivers:
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon
ist die aktuelle Firmware auf dem Brenner eingespielt?
Mal andere Rohlinge probieren.
