Schwelesbare schrif nach config veränderung!
redbull320
Feb. 2008
Schwerlesbare schrift nach config änderung!
Hallo leute ls ich das letzte mal an meiner config ein paar sachen verstellt habe und das spiel (cs 1.6) wieder geöffnet habe sah die schrift ganz komisch aus könnt ihr mir helfen was ich da falsch gemacht habe?? :freak:
meine config:
// This file is overwritten whenever you change your user settings in the game.
// Add custom configurations to the file "userconfig.cfg".
unbindall
bind "TAB" "+showscores"
bind "ENTER" "+attack"
bind "ESCAPE" "cancelselect"
bind "SPACE" "+jump"
bind "'" "+moveup"
bind "+" "sizeup"
bind "," "buyammo1"
bind "-" "sizedown"
bind "." "buyammo2"
bind "/" "+movedown"
bind "1" "slot1"
bind "2" "slot2"
bind "3" "slot3"
bind "4" "slot4"
bind "5" "slot5"
bind "6" "slot6"
bind "7" "slot7"
bind "8" "slot8"
bind "9" "slot"
bind ";" "+mlook"
bind "=" "sizeup"
bind "[" "invprev"
bind "]" "invnext"
bind "`" "toggleconsole"
bind "a" "+moveleft"
bind "b" "buy"
bind "c" " primammo; hegren; sgren; flash; flash; defuser; vesthelm; "
bind "d" "+moveright"
bind "e" "+use"
bind "f" "impulse 100"
bind "g" "drop"
bind "h" "+commandmenu"
bind "i" "showbriefing"
bind "j" "cheer"
bind "k" "+voicerecord"
bind "m" "chooseteam"
bind "n" "nightvision"
bind "o" "buyequip"
bind "p" "adjust_crosshair"
bind "q" "stop_reload"
bind "r" "+reload"
bind "s" "+back"
bind "t" "spray logo"
bind "u" "messagemode2"
bind "w" "+forward"
bind "x" " deagle; secammo;"
bind "y" "messagemode"
bind "z" " ak47; m4a1; primammo; hegren; flash; flash; vesthelm; "
bind "~" "toggleconsole"
bind "UPARROW" "+forward"
bind "DOWNARROW" "+back"
bind "LEFTARROW" "+left"
bind "RIGHTARROW" "+right"
bind "CTRL" "+duck"
bind "SHIFT" "+speed"
bind "F5" "snapshot"
bind "F6" "save quick"
bind "F7" "load quick"
bind "INS" "+klook"
bind "PGDN" "+lookdown"
bind "PGUP" "+lookup"
bind "END" "centerview"
bind "MWHEELDOWN" "invnext"
bind "MWHEELUP" "invprev"
bind "MOUSE1" "+attack"
bind "MOUSE2" "+attack2"
bind "PAUSE" "stopsound"
_cl_autowepswitch "1"
_snd_mixahead "0.1"
ati_npatch "1.0"
ati_subdiv "2.0"
bgmvolume "1.000000"
bottomcolor "3.53"
brightness "3.000"
cl_allowdownload "1"
cl_allowupload "1"
cl_backspeed "420"
cl_career_difficulty "0"
cl_cmdbackup "0"
cl_cmdrate "100"
cl_corpsestay "600"
cl_dlmax "0"
cl_download_ingame "0"
cl_dynamiccrosshair "1"
cl_forwardspeed "400"
cl_himodels "0"
cl_idealpitchscale "0.8"
cl_lc "1"
cl_logocolor "orange"
cl_logofile "pldeca"
cl_lw "1"
cl_minmodels "0"
cl_righthand "1"
cl_shadows "0"
cl_timeout "9999"
cl_updaterate "101"
cl_vsmoothing "0.05"
cl_weather "0"
con_color "255 180 30"
console "1"
crosshair "1"
fastsprites "1"
fps_max "200.9"
fps_modem "120.1"
gamma "3"
gl_dither "1"
gl_flipmatrix "0"
gl_monolights "0"
gl_overbright "2"
gl_polyoffset "0.1"
hisound "1"
hpk_maxsize "0.2"
hud_capturemouse "1"
hud_centerid "1"
hud_draw "1"
hud_fastswitch "1"
hud_saytext_internal "1"
hud_takesshots "0"
joystick "0"
lookspring "0"
lookstrafe "0"
m_filter "0"
m_forward "1"
m_pitch "0.022"
m_side "0.8"
m_yaw "0.022"
model "gordon"
MP3FadeTime "2.0"
MP3Volume "0.500000"
mp_decals "300"
name "*~[K]iNq_[K]iLLaH~*"
net_graph "3"
net_graphpos "1"
net_scale "5"
r_bmodelhighfrac "5.0"
s_a3d "0"
s_automax_distance "800.0"
s_automin_distance "2.0"
s_bloat "2.0"
s_distance "75"
s_doppler "0.0"
s_eax "0"
s_leafnum "0"
s_max_distance "1000.0"
s_min_distance "50.0"
s_numpolys "200"
s_polykeep "1000000000"
s_polysize "1000000"
s_refdelay "4"
s_refgain "0.4"
s_rolloff "1.0"
s_verbwet "0.25"
sensitivity "2.000000"
skin ""
spec_autodirector_internal "1"
spec_drawcone_internal "1"
spec_drawnames_internal "1"
spec_drawstatus_internal "1"
spec_mode_internal "2"
spec_pip "0"
suitvolume "0.250000"
sv_aim "0"
sv_voiceenable "1"
team ""
topcolor "800"
tutor_enable "1"
viewsize "100"
voice_enable "1"
voice_forcemicrecord "1"
voice_modenable "1"
voice_scale "0.750000"
volume "0.800000"
setinfo "ghosts" "0"
setinfo "lefthand" "0"
setinfo "friends" "1"
setinfo "dm" "0"
setinfo "_ah" "0"
setinfo "_vgui_menus" "0"
+mlook
+jlook
exec userconfig.cfg
hoffe das ihr mir helfen könnt...
mfg
redbull
Wie wäre es, wenn du deine config einfach mal hier reinschreibst? ;)
Grüße
Sieht so aus als hättest Du die Auflösung im Spiel geändert, damit "übergehst" Du den Treiber des TFT's.
Jetzt ist CS kaput und Du kannst es nie wieder spielen weil Du es nicht sorgsam genug gepflegt hast.
"Ach mensch, wär ich mit meinem CS mal zum Doc gegangen."
:lol:
Mal den Grafikmodus geändert?
Also OpenGL bzw Direct3D.
Grüße
Na was haste denn alles verändert?
Mein Verdacht oben kann man ja auch mal ansprechen... der Rest ist Joke. :rolleyes:
Könnte es vielleicht sein, dass es an
ati_npatch "1.0"
ati_subdiv "2.0"
liegt?
Habe jetzt nochmal fix durchgeschaut...
Weil das ist ja für ATi-Karten... und er hat eine GeForce.
Grüße
danke erstmal das noch welche geantwortet haben... und nochmal an nightmare danke, denn es hat am D3D modus gelegen, als ich es dann zu openGL geändert habe war wieder alles gut...
was ist denn der unterschied zwischen den zwei einstellungen??
THX AN ALLE
mfg
redbull
Schön zu wissen :)
Naja den Unterschied kann ich dir grad nicht genau sagen, aber ich habe eine PDF-Datei gefunden:
http://www.mweissmann.de/downloads/Direct3D_vs._OpenGL.pdf
Das sollte deine Frage klären.
Bei CS war immer das komische, dass es scheinbar im OpenGL-Modus besser läuft...
(Bessere Performance).
Grüße
