T
tx_g
ich habe mir vor einiger Zeit eine Domain gekauft die per A und AAAA Records auf meinen Homeserver mit Debian 9 gelegt ist. Im Router (SpeedportW724V) habe ich die Ports 80 U 443 freigegeben.
Zur Installation der Zertifikat wollte ich eigentlich Certbot benutzen, da mir das ganze relativ einfach erschien. Allerdings habe ich ein Problem das Zertifikat zu bekommen da immer folgender Fehler auftritt:
Evtl könnt ihr mir dabei weiterhelfen.
Code:
root@CLOUD-1:/home/server# certbot certonly --rsa-key-size 4096 --webroot -w /var/www/html/ -d cloud-inc.eu -d www.cloud-inc.eu
Saving debug log to /var/log/letsencrypt/letsencrypt.log
Obtaining a new certificate
Performing the following challenges:
http-01 challenge for cloud-inc.eu
http-01 challenge for www.cloud-inc.eu
Using the webroot path /var/www/html for all unmatched domains.
Waiting for verification...
Cleaning up challenges
Failed authorization procedure. cloud-inc.eu (http-01): urn:acme:error:connection :
: The server could not connect to the client to verify the domain :: Fetching http:
//cloud-inc.eu/.well-known/acme-challenge/merkwürdigercode
-w: Timeout
IMPORTANT NOTES:
- The following errors were reported by the server:
Domain: cloud-inc.eu
Type: connection
Detail: Fetching
http://cloud-inc.eu/.well-known/acme-challenge/merkwürdigercode;
Timeout
To fix these errors, please make sure that your domain name was
entered correctly and the DNS A record(s) for that domain
contain(s) the right IP address. Additionally, please check that
your computer has a publicly routable IP address and that no
firewalls are preventing the server from communicating with the
client. If you're using the webroot plugin, you should also verify
that you are serving files from the webroot path you provided.
