Ständige Bluescreens. Kann jemand das Dumpfile analysieren?
Tippfehlre
Juli 2017
Hallo zusammen
Habe seit einiger Zeit ständig Bluescreens. Laut Bluescreen sind es immer andere Anwendungen die scheitern.
Habe bereits einen ganzen Wipe der Festplatte vorgenommen. Hat leider nichts geholfen.
Ich nehme an es liegt an der Hardware, fragt sich nur welche Komponente.
Hier ist ein Auszug des Dumps:
Code:
*                        Bugcheck Analysis                                    *
KMODE_EXCEPTION_NOT_HANDLED (1e)
This is a very common bugcheck.  Usually the exception address pinpoints
the driver/function that caused the problem.  Always note this address
as well as the link date of the driver/image that contains this address.
Arguments:
Arg1: ffffffffc0000005, The exception code that was not handled
Arg2: fffff80537bc85ef, The address that the exception occurred at
Arg3: 0000000000000000, Parameter 0 of the exception
Arg4: ffffffffffffffff, Parameter 1 of the exception
Debugging Details:
KEY_VALUES_STRING: 1
PROCESSES_ANALYSIS: 1
SERVICE_ANALYSIS: 1
STACKHASH_ANALYSIS: 1
TIMELINE_ANALYSIS: 1
DUMP_CLASS: 1
DUMP_QUALIFIER: 401
BUILD_VERSION_STRING:  18362.1.amd64fre.19h1_release.190318-1202
SYSTEM_MANUFACTURER:  System manufacturer
SYSTEM_PRODUCT_NAME:  System Product Name
SYSTEM_SKU:  SKU
SYSTEM_VERSION:  System Version
BIOS_VENDOR:  American Megatrends Inc.
BIOS_VERSION:  0613
BIOS_DATE:  05/15/2017
BASEBOARD_MANUFACTURER:  ASUSTeK COMPUTER INC.
BASEBOARD_PRODUCT:  PRIME B350-PLUS
BASEBOARD_VERSION:  Rev X.0x
DUMP_TYPE:  1
BUGCHECK_P1: ffffffffc0000005
BUGCHECK_P2: fffff80537bc85ef
BUGCHECK_P3: 0
BUGCHECK_P4: ffffffffffffffff
READ_ADDRESS:  ffffffffffffffff
EXCEPTION_CODE: (NTSTATUS) 0xc0000005 - The instruction at 0x%p referenced memory at 0x%p. The memory could not be %s.
FAULTING_IP:
nt!SwapContext+36f
fffff805`37bc85ef 0fc719          xrstors [rcx]
EXCEPTION_PARAMETER2:  ffffffffffffffff
BUGCHECK_STR:  0x1E_c0000005_R
CPU_COUNT: 8
CPU_MHZ: da5
CPU_VENDOR:  AuthenticAMD
CPU_FAMILY: 17
CPU_MODEL: 1
CPU_STEPPING: 1
BLACKBOXBSD: 1 (!blackboxbsd)
BLACKBOXNTFS: 1 (!blackboxntfs)
BLACKBOXPNP: 1 (!blackboxpnp)
BLACKBOXWINLOGON: 1
DEFAULT_BUCKET_ID:  WIN8_DRIVER_FAULT
PROCESS_NAME:  System
CURRENT_IRQL:  2
ANALYSIS_SESSION_HOST:  DESKTOP-JVTDR5G
ANALYSIS_SESSION_TIME:  10-13-2019 10:27:17.0582
ANALYSIS_VERSION: 10.0.18362.1 amd64fre
BAD_STACK_POINTER:  ffffad01f989f138
LAST_CONTROL_TRANSFER:  from fffff80537ca678e to fffff80537bc1220
STACK_TEXT:
ffffad01`f989f138 fffff805`37ca678e : 00000000`0000001e ffffffff`c0000005 fffff805`37bc85ef 00000000`00000000 : nt!KeBugCheckEx
ffffad01`f989f140 fffff805`37bca04f : fffff805`37f11000 fffff805`37a00000 0005e56c`00ab6000 00000000`0010001f : nt!KiFatalExceptionHandler+0x22
ffffad01`f989f180 fffff805`37ac3375 : 00000000`0000036f 00000000`00000000 ffffad01`f989f6f0 00007fff`ffff0000 : nt!RtlpExecuteHandlerForException+0xf
ffffad01`f989f1b0 fffff805`37ac790e : ffffe408`510299e8 ffffad01`f989fe30 ffffe408`510299e8 ffff998e`5e2d8580 : nt!RtlDispatchException+0x4a5
ffffad01`f989f900 fffff805`37bc20a2 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiDispatchException+0x16e
ffffad01`f989ffb0 fffff805`37bc2070 : fffff805`37bd3216 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KxExceptionDispatchOnExceptionStack+0x12
ffffe408`510298a8 fffff805`37bd3216 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`000000fd : nt!KiExceptionDispatchOnExceptionStackContinue
ffffe408`510298b0 fffff805`37bcefa2 : 00000000`00000000 ffffad01`f9840180 000000a9`0397d20a ffffad01`f9851240 : nt!KiExceptionDispatch+0x116
ffffe408`51029a90 fffff805`37bc85ef : ffffad01`f9840180 00000000`00000000 ffff998e`61aa0080 ffff998e`57674080 : nt!KiGeneralProtectionFault+0x322
ffffe408`51029c20 fffff805`37bc4e3e : ffffffff`00000000 ffffad01`f9840180 ffffad01`f9851240 ffff998e`5f707080 : nt!SwapContext+0x36f
ffffe408`51029c60 00000000`00000000 : ffffe408`5102a000 ffffe408`51024000 00000000`00000000 00000000`00000000 : nt!KiIdleLoop+0x15e
THREAD_SHA1_HASH_MOD_FUNC:  e920457fc283a1e42e04235d885379257ed993e7
THREAD_SHA1_HASH_MOD_FUNC_OFFSET:  9f8cd59f1b41bd41c780eef97b3242e17593504d
THREAD_SHA1_HASH_MOD:  b28610981796779b4ac02f58898fde25728a775c
FOLLOWUP_IP:
nt!SwapContext+36f
FAULT_INSTR_CODE:  eb19c70f
SYMBOL_STACK_INDEX:  9
SYMBOL_NAME:  nt!SwapContext+36f
FOLLOWUP_NAME:  MachineOwner
MODULE_NAME: nt
IMAGE_NAME:  ntkrnlmp.exe
DEBUG_FLR_IMAGE_TIMESTAMP:  0
STACK_COMMAND:  .thread ; .cxr ; kb
BUCKET_ID_FUNC_OFFSET:  36f
FAILURE_BUCKET_ID:  0x1E_c0000005_R_STACKPTR_ERROR_nt!SwapContext
PRIMARY_PROBLEM_CLASS:  0x1E_c0000005_R_STACKPTR_ERROR_nt!SwapContext
TARGET_TIME:  2019-10-13T07:54:05.000Z
OSBUILD:  18362
OSSERVICEPACK:  0
SERVICEPACK_NUMBER: 0
OS_REVISION: 0
SUITE_MASK:  272
PRODUCT_TYPE:  1
OSPLATFORM_TYPE:  x64
OSNAME:  Windows 10
OSEDITION:  Windows 10 WinNt TerminalServer SingleUserTS
OS_LOCALE:
USER_LCID:  0
OSBUILD_TIMESTAMP:  unknown_date
BUILDDATESTAMP_STR:  190318-1202
BUILDLAB_STR:  19h1_release
BUILDOSVER_STR:  10.0.18362.1.amd64fre.19h1_release.190318-1202
ANALYSIS_SESSION_ELAPSED_TIME:  f3c
ANALYSIS_SOURCE:  KM
FAILURE_ID_HASH_STRING:  km:0x1e_c0000005_r_stackptr_error_nt!swapcontext
FAILURE_ID_HASH:  {bd591bce-fa9d-a983-0398-0157fd169b8e}
Followup:     MachineOwner
Du nimmst an, es liegt an der Hardware. Wie wäre es, wenn du die uns auch mitteilst?
Reaktionen: Terrier
also was mir auf den ersten Blick so auffällt ist, dass es mindestens 20 neuere Bios Versionen für dein Mainboard gibt. Da würde ich zuerst mal ansetzen.
RAM richtig eingestellt?
Aber teile uns doch bitte mal deine komplette Hardware mit.
Gruß Dan
Reaktionen: Terrier
Welche Windows-Version kommt denn genau zum Einsatz (mit Build-Version) - zu finden unter System?
Reaktionen: Terrier
Build Version: 18362.1, ich würde zunächst mal alle aktuellen Updates installieren lassen. Denn nur das ist die Voraussetzung dafür, dass man es andere Ursachen geben kann.
Reaktionen: adius
Also Hardware sieht folgendermassen aus:
Mainboard: ASUS Prime B350-Plus (AM4, AMD B350, ATX)
GraKa: MSI GeForce GTX 1060 GAMING X (6GB, Midrange)
CPU: AMD Ryzen 5 1500X (4, AM4, 3.50GHz)
RAM: HyperX Fury (2x, 8GB, DDR4-2400, DIMM 288)
Netzteil: be quiet! Pure Power 10 CM (400W)
SSD: Crucial MX300 (525GB, 2.5")
BIOS Update mache ich gleich. Meine aktuelle Version ist tätsächlich noch von 2017.
Windows Updates sind laut 'Windows Update Settings' alle installiert. Auch bereits vor dem Bluescreen von heute. Übersehe ich etwas?
In das Suchfeld "winver" eingeben und davon einen Screenshot posten.
Dann wissen wir genau welche Windows 10 Version du installiert hast.
@Markchen Naja wenn jetzt nicht gerade Updates durchgeführt wurden ist nach dem Screenshot der Systeminformationen die Version 10.0.18362.387 installiert.
Gruß Dan
BIOS habe ich soeben aktualisiert. Meine aktuelle Version war noch von 2017.
Was meinst du mit 'RAM richtig eingestellt'?
Wurde der RAM übertaktet?
Spannung korrekt?
Aber vielleicht hat sich das Thema durch das Bios Update schon erledigt.
