Suche Lüftersteuerung für Xigmatek Gaia SD1283 vielleicht bis 25€.
Hier die wichtigsten details:
Product Number CAC-SXHH3-U06
Dimension 120(W) x 50(D) x 159(H) mm (w/o Fan)
Heat Sink Base Material H.D.T. (Heat-pipes Direct Touch)
Fin Material Aluminum Alloy
Heat-pipe SPEC Φ8mm
Q´ty 3 pcs.
Fan Dimension 120(W) x 120(H) x 25(D) mm
Voltage Rating 12V
Starting Voltage ≥9V
Speed 800~1500 R.P.M.
Bearing Type FCB Fluid Circulative Bearing
Air Flow 56.3CFM (Max.)
Air Pressure 1.57 mmH2O (Max.)
Life Expectance 40,000 hrs
Noise Level 16~24 dBA (Max.)
Connector 4 Pin with PWM
Weight 460g(Heat Sink Only)
Thermal Resistance 0.15 °C/W
Als MOTHERBOARD habe ich: Gigabyte GA-H77-D3H Intel H77 So.1155 Dual Channel DDR3 ATX Retail
Heat-pipe SPEC Φ8mm
Q´ty 3 pcs.
Voltage Rating 12V
