SyncMaster 245b Plus mit Ergotron
http://www.ergotron.com/Products/De.../mid/396/PRDID/11/language/de-DE/default.aspx
passt nicht:
Mounting Standards: VESA FDMI, MIS-D, 75/100, C (hole pattern = 100 x 100 mm & 75 x 75 mm)
Der passt z.B.:
http://www.ergotron.com/Products/De.../mid/396/PRDID/56/language/de-DE/default.aspx
wegen : Optional VESA Bracket Adaptor Kit (97-474) can be ordered separately for MIS-E and MIS-F interfaces (hole patterns = 200 x 100 mm, 200 x 200 mm and 400 x 200 mm)
EDIT:
Scheint universell zu passen:
http://www.ergotron.com/Products/Ac...mid/574/PRDID/253/language/de-DE/default.aspx
