Tastatur funktioniert direkt nach dem Startup komisch
LizNitra
Dez. 2022
Hey all!
After startup I have the following problems:
-Can't press Ctrl+a at the same time
-Can't press w+a at the same time
A few other combinations also don't work like:
-q+a, e+a
These problem resolve themselves after some time, like 1 or 1.5 hours after startup (happened while I wrote this).
After the problems resolve themselves they don't happen again and only come up again after a new startup.
I am no Computer Pro, but since this resolves itself after some time I would guess that it is probably software related.
Also I cannot test the keyboard on another device since I only have this one device here.
The Keyboard in question:
Sharkoon Sharkzone GK15-K
What I found in Eventviewer:
  • TPM Error:
    Trusted Platform Module (TPM) device drivers ecountered an error in the tpm hardware.
  • DistributedCOM Warning:
    The application-specific permission settings do not grant Local Activation permission for the COM Server application with
    CLSID...
    This pops up multiple times with different CLSIDs:
    {6B3B8D23-FA8D-40B9-8DBD-B950333E2C52}
    {2593F8B9-4EAF-457C-B68A-50F6B8EA6B54}
    Windows.SecurityCenter.WscBrokerManager
    Windows.SecurityCenter.SecurityAppBroker
    Windows.SecurityCenter.WscDataProtection
  • TPM Error:
  • DNS Client Events Warning:
    Name resolution for the name t-ring-fallbacks2.msedge.net timed out after none of the configured DNS servers responded.
I know most of this is probably irrelevant but I didn't wanna leave anything out.
Other PC Specs:
  • OS: Windows 10 Home
    Version: 21H2
  • GPU: NVIDIA GeForce RTX 2070
  • CPU: AMD Ryzen 5 2700X Six-Core Processor 3.60 GHz
  • BaseBoard: X470 GAMING PLUS MAX (MS-7B79)
  • RAM: 32 GB DDR4
  • BIOS Version: American Megatrends International, LLC. H.D3, 12/11/2021
    SMBIOS Version: 2.8
    BIOS Mode: Legacy
Thank you for any recommendations/solutions.
if you are not using a dedicated TPM module, check if TPM is set to AMD Firmware TPM
Thank you for the replies.
When trying to turn off fast startup, I noticed that Hibernation was off.
So I assume that with that Fast Startup was also turned off.
I now reenabled Hibernation and disabled Fast Startup.
Im going to set TPM to AMD Firmware TPM and then post the update.
Alright.
The TPM thing was already set correctly.
Seems like enabling Hibernation and disabling Fast Startup fixed the problem.
If the problem comes up again tomorrow, then I will update.
