Test einer SSD über USB?
FatManStanding
Aug. 2021
Ein- und Ausbau ist bei meinem Desktop immer etwas umständlich. Ist es möglich den Zustand einer SSD auch über ein 2,5''-Festplattengehäuse zu prüfen? Sie wird erkannt, SMART ist aktiv. Ein Longtest mit smartctl sollte eigentlich länger dauern, bringt aber sofort das hier:
Code:
sudo smartctl -t long -a /dev/sde
smartctl 7.2 2020-12-30 r5155 [x86_64-linux-6.8.0-52-generic] (local build)
Copyright (C) 2002-20, Bruce Allen, Christian Franke, www.smartmontools.org
=== START OF INFORMATION SECTION ===
Device Model:     SSD 4TB
Serial Number:    000313
LU WWN Device Id: 0 000000 000000000
Firmware Version: VA001CBY
User Capacity:    4.000.787.030.016 bytes [4,00 TB]
Sector Size:      512 bytes logical/physical
Rotation Rate:    Solid State Device
Form Factor:      2.5 inches
TRIM Command:     Available, deterministic
Device is:        Not in smartctl database [for details use: -P showall]
ATA Version is:   ACS-3, ATA8-ACS T13/1699-D revision 6
SATA Version is:  SATA 3.0, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is:    Mon Feb 24 11:09:11 2025 CET
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
=== START OF READ SMART DATA SECTION ===
SMART Status not supported: Incomplete response, ATA output registers missing
SMART overall-health self-assessment test result: PASSED
Warning: This result is based on an Attribute check.
General SMART Values:
Offline data collection status:  (0x00)    Offline data collection activity
                    was never started.
                    Auto Offline Data Collection: Disabled.
Self-test execution status:      (   0)    The previous self-test routine completed
                    without error or no self-test has ever
                    been run.
Total time to complete Offline
data collection:         (    1) seconds.
capabilities:              (0x59) SMART execute Offline immediate.
                    No Auto Offline data collection support.
                    Suspend Offline collection upon new
                    command.
                    Offline surface scan supported.
                    Self-test supported.
                    No Conveyance Self-test supported.
                    Selective Self-test supported.
SMART capabilities:            (0x0002)    Does not save SMART data before
                    entering power-saving mode.
                    Supports SMART auto save timer.
Error logging capability:        (0x01)    Error logging supported.
                    General Purpose Logging supported.
Short self-test routine
recommended polling time:      (   1) minutes.
Extended self-test routine
recommended polling time:      (   2) minutes.
SMART Attributes Data Structure revision number: 10
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME          FLAG     VALUE WORST THRESH TYPE      UPDATED  WHEN_FAILED RAW_VALUE
  1 Raw_Read_Error_Rate     0x002f   100   100   050    Pre-fail  Always       -       0
  5 Reallocated_Sector_Ct   0x0033   100   100   010    Pre-fail  Always       -       0
  9 Power_On_Hours          0x0032   100   100   000    Old_age   Always       -       0
 12 Power_Cycle_Count       0x0032   100   100   000    Old_age   Always       -       9
161 Unknown_Attribute       0x0032   100   100   050    Old_age   Always       -       19
162 Unknown_Attribute       0x0032   100   100   000    Old_age   Always       -       12
163 Unknown_Attribute       0x0032   100   100   000    Old_age   Always       -       3000
164 Unknown_Attribute       0x0032   100   100   000    Old_age   Always       -       0
166 Unknown_Attribute       0x0032   100   100   000    Old_age   Always       -       19
167 Unknown_Attribute       0x0032   100   100   000    Old_age   Always       -       0
168 Unknown_Attribute       0x0032   100   100   000    Old_age   Always       -       0
169 Unknown_Attribute       0x0032   100   100   000    Old_age   Always       -       100
171 Unknown_Attribute       0x0032   100   100   000    Old_age   Always       -       0
172 Unknown_Attribute       0x0032   100   100   000    Old_age   Always       -       0
174 Unknown_Attribute       0x0032   100   100   000    Old_age   Always       -       5
175 Program_Fail_Count_Chip 0x0032   100   100   000    Old_age   Always       -       0
181 Program_Fail_Cnt_Total  0x0022   100   100   000    Old_age   Always       -       162416
187 Reported_Uncorrect      0x0032   100   100   000    Old_age   Always       -       0
194 Temperature_Celsius     0x0022   100   100   000    Old_age   Always       -       40
195 Hardware_ECC_Recovered  0x003a   100   100   000    Old_age   Always       -       0
196 Reallocated_Event_Count 0x0032   100   100   000    Old_age   Always       -       0
199 UDMA_CRC_Error_Count    0x0032   100   100   000    Old_age   Always       -       0
206 Unknown_SSD_Attribute   0x0032   100   100   000    Old_age   Always       -       0
207 Unknown_SSD_Attribute   0x0032   100   100   000    Old_age   Always       -       0
232 Available_Reservd_Space 0x0032   100   100   000    Old_age   Always       -       0
233 Media_Wearout_Indicator 0x0032   100   100   000    Old_age   Always       -       124
241 Total_LBAs_Written      0x0032   100   100   000    Old_age   Always       -       33
242 Total_LBAs_Read         0x0032   100   100   000    Old_age   Always       -       27
249 Unknown_Attribute       0x0032   100   100   000    Old_age   Always       -       3
250 Read_Error_Retry_Rate   0x0032   100   100   000    Old_age   Always       -       38
SMART Error Log Version: 1
No Errors Logged
SMART Self-test log structure revision number 1
Num  Test_Description    Status                  Remaining  LifeTime(hours)  LBA_of_first_error
# 1  Short offline       Completed without error       00%         0         -
SMART Selective self-test log data structure revision number 0
Note: revision number not 1 implies that no selective self-test has ever been run
 SPAN  MIN_LBA  MAX_LBA  CURRENT_TEST_STATUS
    1        0        0  Not_testing
    2        0        0  Not_testing
    3        0        0  Not_testing
    4        0        0  Not_testing
    5        0        0  Not_testing
Selective self-test flags (0x0):
  After scanning selected spans, do NOT read-scan remainder of disk.
If Selective self-test is pending on power-up, resume after 0 minute delay.
=== START OF OFFLINE IMMEDIATE AND SELF-TEST SECTION ===
Sending command: "Execute SMART Extended self-test routine immediately in off-line mode".
Drive command "Execute SMART Extended self-test routine immediately in off-line mode" successful.
Testing has begun.
Please wait 2 minutes for test to complete.
Test will complete after Mon Feb 24 11:11:11 2025 CET
Use smartctl -X to abort test.
@Pnderosa die Werte stehen doch bereits da.. Denke nicht, dass CrystalDiskInfo da mehr anzeigt.
@TE
Ich mag das jetzt falsch verstehen. Aber dabei geht es ja um eine art "Selftest". Angegeben ist, dass der nach 11:11:11 eben endet (und nur 2Min dauern wird). Vermutlich solltest du nach dieser Zeit einfach nochmal die Smartwerte auslesen. Ein Shorttest wurde ja z.B. auch schon ohne Fehler geloggt.
Warum muss die SSD überhaupt so oft überprüft werden?
Glaube ich hatte da einen Denkfehler. Ich dachte der Selbsttest läuft dann im Terminal bis er fertig ist. Ist aber scheinbar so, dass er im Hintergrund läuft und man sich das ganze dann mit "sudo smartctl -l selftest /dev/sde" anzeigen lässt. Da kommt bei mir:
Code:
# 1  Extended offline    Completed without error       00%         0         -
# 2  Short offline       Completed without error       00%         0         -
was schon einmal nett aussieht. Ich hatte früher mal (unter Windows) eine Software die jeden Sector getestet hat. Gibt es so etwas heute noch und ist das sinnvoll? Oder macht die am Ende nichts anderes als SMART?
Verstehe die Frage nicht. Ich will sie jetzt überprüfen - einmalig, nicht ständig.
Reaktionen: madmax2010
Der erste Satz klingt so als würdest du dir ständig ein und ausbauen. Normalerweise ist es ja egal ob ein Massenspeicher gut oder schlecht zu erreichen ist, der bleibt dort für Jahre oder oft für immer drin.
Vermutlich nicht viel mehr. Wobei ich hier aus dem Satz :
It is also possible to perform an "offline" test. However, only of the standard self test (Short Test) is performed.
Nicht ganz schlau werde. Extended offline steht ja da?! Wenn ich das richtig deute sollte sie für die "ausgiebigeren" Tests "online" sein. Also vermutlich gemountet?
Scheint aber immer im Hintergrund zu laufen wenn eben nciht anders angegeben.
Würde da aber bei SSDs auch nicht zu viel Aufhebens machen. Die SMART-Werte sehen ja soweit gut aus. Bezweifle, dass du durch solche Tests irgendwelche versteckten Defekte bemerkst. In Der Regel klappen die Dinger halt die Füße hoch oder funktionieren. Aber das ist nur meine Wahrnehmung.
