Dez 10 11:56:42 machineXXX systemd[743]: p11-kit-server.socket: Succeeded.
Dez 10 11:56:42 machineXXX systemd[743]: Closed p11-kit server.
Dez 10 11:56:42 machineXXX systemd[743]: gpg-agent-browser.socket: Succeeded.
Dez 10 11:56:42 machineXXX systemd[743]: Closed GnuPG cryptographic agent and passphrase cache (access for web browsers).
Dez 10 11:56:42 machineXXX systemd[743]: gpg-agent.socket: Succeeded.
Dez 10 11:56:42 machineXXX systemd[743]: Closed GnuPG cryptographic agent and passphrase cache.
Dez 10 11:56:42 machineXXX systemd[743]: dirmngr.socket: Succeeded.
Dez 10 11:56:42 machineXXX systemd[743]: Closed GnuPG network certificate management daemon.
Dez 10 11:56:42 machineXXX systemd[743]: gpg-agent-extra.socket: Succeeded.
Dez 10 11:56:42 machineXXX systemd[743]: Closed GnuPG cryptographic agent and passphrase cache (restricted).
Dez 10 11:56:42 machineXXX systemd[743]: pulseaudio.socket: Succeeded.
Dez 10 11:56:42 machineXXX systemd[743]: Closed Sound System.
Dez 10 11:56:42 machineXXX systemd[743]: gpg-agent-ssh.socket: Succeeded.
Dez 10 11:56:42 machineXXX systemd[743]: Closed GnuPG cryptographic agent (ssh-agent emulation).
Dez 10 11:56:42 machineXXX systemd[743]: Stopped target Timers.
Dez 10 11:56:42 machineXXX systemd[743]: dbus.socket: Succeeded.
Dez 10 11:56:42 machineXXX systemd[743]: Closed D-Bus User Message Bus Socket.
Dez 10 11:56:42 machineXXX systemd[743]: Reached target Shutdown.
Dez 10 11:56:42 machineXXX systemd[743]: systemd-exit.service: Succeeded.
Dez 10 11:56:42 machineXXX systemd[743]: Started Exit the Session.
Dez 10 11:56:42 machineXXX systemd[743]: Reached target Exit the Session.
Dez 10 11:56:42 machineXXX systemd[751]: pam_unix(systemd-user:session): session closed for user lightdm
Dez 10 11:56:42 machineXXX systemd[1]:
user@972.service: Succeeded.
Dez 10 11:56:42 machineXXX systemd[1]: Stopped User Manager for UID 972.
Dez 10 11:56:42 machineXXX audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=user@972 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res>
Dez 10 11:56:42 machineXXX kernel: audit: type=1131 audit(1575975402.185:48): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=user@972 comm="systemd" exe="/usr/lib/systemd/systemd" host>
Dez 10 11:56:42 machineXXX systemd[1]: Stopping User Runtime Directory /run/user/972...
Dez 10 11:56:42 machineXXX systemd[933]: run-user-972.mount: Succeeded.
Dez 10 11:56:42 machineXXX systemd[1]: run-user-972.mount: Succeeded.
user-runtime-dir@972.service: Succeeded.
Dez 10 11:56:42 machineXXX systemd[1]: Stopped User Runtime Directory /run/user/972.
Dez 10 11:56:42 machineXXX audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=user-runtime-dir@972 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? te>
Dez 10 11:56:42 machineXXX kernel: audit: type=1131 audit(1575975402.232:49): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=user-runtime-dir@972 comm="systemd" exe="/usr/lib/systemd/s>
Dez 10 11:56:42 machineXXX systemd[1]: Removed slice User Slice of UID 972.
Dez 10 11:56:44 machineXXX systemd[1]: NetworkManager-dispatcher.service: Succeeded.
Dez 10 11:56:44 machineXXX audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr>
Dez 10 11:56:44 machineXXX kernel: audit: type=1131 audit(1575975404.262:50): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/syst>
Dez 10 11:57:04 machineXXX systemd[1]: systemd-hostnamed.service: Succeeded.
Dez 10 11:57:04 machineXXX audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? termi>
Dez 10 11:57:04 machineXXX kernel: audit: type=1131 audit(1575975424.245:51): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/syst>
Dez 10 11:57:07 machineXXX systemd[1]: blueman-mechanism.service: Succeeded.
Dez 10 11:57:07 machineXXX audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=blueman-mechanism comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? termi>
Dez 10 11:57:07 machineXXX kernel: audit: type=1131 audit(1575975427.739:52): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=blueman-mechanism comm="systemd" exe="/usr/lib/systemd/syst>
Dez 10 11:57:36 machineXXX msm_notifier[1100]: "poppler-data"
Dez 10 11:57:36 machineXXX msm_notifier[1100]: "qt5-translations"
Dez 10 11:58:01 machineXXX sudo[1302]: userXXX : TTY=pts/0 ; PWD=/home/userXXX ; USER=root ; COMMAND=/usr/bin/journalctl -e
Dez 10 11:58:01 machineXXX sudo[1302]: pam_unix(sudo:session): session opened for user root by (uid=0)
Dez 10 11:59:06 machineXXX sudo[1302]: pam_unix(sudo:session): session closed for user root
Dez 10 11:59:32 machineXXX sudo[1324]: userXXX : TTY=pts/0 ; PWD=/home/userXXX ; USER=root ; COMMAND=/usr/bin/journalctl -e
Dez 10 11:59:32 machineXXX sudo[1324]: pam_unix(sudo:session): session opened for user root by (uid=0)
