Unigine Superposition - issue with GSYNC
sew333
Juli 2017
Hello.I am using 2080 Ti Aorus Waterforce + Aorus AD27QD.
Testing unigine superposition i am getting random 1s stutter all over the place. Without gsync is fine.
Can test somebody with gsync and check?
Do you have this problem also in games or only in Superposition ?
and please, do me a favour and tell us your pc specs and graphics driver that you are using. thanks
In games all fine. Valley fine too. Only Superposition.
so ... why is this so important that you have to post it in 3 different communities ?
- computerbase, linustech und guru3D ...
which driver you are using ?
Maybe someone could help with more informations from your side.
and why you need g-sync in a benchmark ??
is this a joke ? for me it doesn't make any sense.
Just to be sure if all its fine. Somebody tested with GSYNC ON with 2070 and no stutter.
Where is the problem, when your games and other apps are running.
Leave it as it is
just reinstall and try again.
but don't worry when everything else is running fine.
hmmmm i know i can ignore but why i have that here, maybe monitor?
