unreadable (pending) sectors nach 40 Stunden Betriebszeit?
Skaro
Lt. Commander Pro
Jan. 2015
Hey,
ich hab mir vor 2 Tagen 3x die MX500 gekauft und damit ein RAIDZ1 (Raid5) gemacht. Alles läuft perfekt aber soeben hab ich folgende Benachrichtigung bekommen:
The following warning/error was logged by the smartd daemon:
Device: /dev/disk/by-id/ata-CT500MX500SSD1_1805E10XXXXX [SAT], 1 Currently unreadable (pending) sectors
Device info:
CT500MX500SSD1, S/N:1805E10XXXXX, WWN:5-00a075-1e10c6882, FW:M3CR010, 500 GB
Danach hatte ich gleich ein langen Smart Test gemacht dort kam erstmal nur "Completed without error" raus. ZFS Scrub hatte ich danach auch noch gemacht und da waren auch alle Files in Ordnung.
Hier das gesamte Ergebnis von smartctl:
Code:
smartctl 6.6 2016-05-31 r4324 [x86_64-linux-4.14.0-0.bpo.3-amd64] (local build)
Copyright (C) 2002-16, Bruce Allen, Christian Franke, [url]www.smartmontools.org[/url]
=== START OF INFORMATION SECTION ===
Device Model:     CT500MX500SSD1
Firmware Version: M3CR010
User Capacity:    500.107.862.016 bytes [500 GB]
Sector Sizes:     512 bytes logical, 4096 bytes physical
Rotation Rate:    Solid State Device
Form Factor:      2.5 inches
Device is:        Not in smartctl database [for details use: -P showall]
ATA Version is:   ACS-3 T13/2161-D revision 5
SATA Version is:  SATA >3.2 (0x1ff), 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is:    Thu Mar 15 09:46:25 2018 CET
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
=== START OF READ SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
General SMART Values:
Offline data collection status:  (0x82)	Offline data collection activity
					was completed without error.
					Auto Offline Data Collection: Enabled.
Self-test execution status:      (   0)	The previous self-test routine completed
					without error or no self-test has ever
					been run.
Total time to complete Offline
data collection: 		(    0) seconds.
capabilities: 			 (0x7b) SMART execute Offline immediate.
					Auto Offline data collection on/off support.
					Suspend Offline collection upon new
					command.
					Offline surface scan supported.
					Self-test supported.
					Conveyance Self-test supported.
					Selective Self-test supported.
SMART capabilities:            (0x0003)	Saves SMART data before entering
					power-saving mode.
					Supports SMART auto save timer.
Error logging capability:        (0x01)	Error logging supported.
					General Purpose Logging supported.
Short self-test routine
recommended polling time: 	 (   2) minutes.
Extended self-test routine
recommended polling time: 	 (  30) minutes.
Conveyance self-test routine
SCT capabilities: 	       (0x0031)	SCT Status supported.
					SCT Feature Control supported.
					SCT Data Table supported.
SMART Attributes Data Structure revision number: 16
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME          FLAG     VALUE WORST THRESH TYPE      UPDATED  WHEN_FAILED RAW_VALUE
  1 Raw_Read_Error_Rate     0x002f   100   100   000    Pre-fail  Always       -       0
  5 Reallocated_Sector_Ct   0x0032   100   100   010    Old_age   Always       -       0
  9 Power_On_Hours          0x0032   100   100   000    Old_age   Always       -       44
 12 Power_Cycle_Count       0x0032   100   100   000    Old_age   Always       -       2
171 Unknown_Attribute       0x0032   100   100   000    Old_age   Always       -       0
172 Unknown_Attribute       0x0032   100   100   000    Old_age   Always       -       0
173 Unknown_Attribute       0x0032   100   100   000    Old_age   Always       -       2
174 Unknown_Attribute       0x0032   100   100   000    Old_age   Always       -       0
180 Unused_Rsvd_Blk_Cnt_Tot 0x0033   000   000   000    Pre-fail  Always       -       32
183 Runtime_Bad_Block       0x0032   100   100   000    Old_age   Always       -       0
184 End-to-End_Error        0x0032   100   100   000    Old_age   Always       -       0
187 Reported_Uncorrect      0x0032   100   100   000    Old_age   Always       -       0
194 Temperature_Celsius     0x0022   067   049   000    Old_age   Always       -       33 (Min/Max 0/51)
196 Reallocated_Event_Count 0x0032   100   100   000    Old_age   Always       -       0
197 Current_Pending_Sector  0x0032   100   100   000    Old_age   Always       -       0
198 Offline_Uncorrectable   0x0030   100   100   000    Old_age   Offline      -       0
199 UDMA_CRC_Error_Count    0x0032   100   100   000    Old_age   Always       -       0
202 Unknown_SSD_Attribute   0x0030   100   100   001    Old_age   Offline      -       0
206 Unknown_SSD_Attribute   0x000e   100   100   000    Old_age   Always       -       0
210 Unknown_Attribute       0x0032   100   100   000    Old_age   Always       -       0
246 Unknown_Attribute       0x0032   100   100   000    Old_age   Always       -       720783611
247 Unknown_Attribute       0x0032   100   100   000    Old_age   Always       -       11918126
248 Unknown_Attribute       0x0032   100   100   000    Old_age   Always       -       10631724
SMART Error Log Version: 1
ATA Error Count: 0
	CR = Command Register [HEX]
	FR = Features Register [HEX]
	SC = Sector Count Register [HEX]
	SN = Sector Number Register [HEX]
	CL = Cylinder Low Register [HEX]
	CH = Cylinder High Register [HEX]
	DH = Device/Head Register [HEX]
	DC = Device Command Register [HEX]
	ER = Error register [HEX]
	ST = Status register [HEX]
Powered_Up_Time is measured from power on, and printed as
DDd+hh:mm:SS.sss where DD=days, hh=hours, mm=minutes,
SS=sec, and sss=millisec. It "wraps" after 49.710 days.
Error -4 occurred at disk power-on lifetime: 0 hours (0 days + 0 hours)
  When the command that caused the error occurred, the device was in an unknown state.
  After command completion occurred, registers were:
  ER ST SC SN CL CH DH
  00 ec 00 00 00 00 00
  Commands leading to the command that caused the error were:
  CR FR SC SN CL CH DH DC   Powered_Up_Time  Command/Feature_Name
  ec 00 00 00 00 00 00 00      00:00:00.000  IDENTIFY DEVICE
  c8 00 00 00 00 00 00 00      00:00:00.000  READ DMA
SMART Self-test log structure revision number 1
Num  Test_Description    Status                  Remaining  LifeTime(hours)  LBA_of_first_error
# 1  Extended offline    Completed without error       00%        43         -
# 2  Short offline       Completed without error       00%        41         -
# 3  Short offline       Completed without error       00%        22         -
# 4  Short offline       Completed without error       00%         6         -
# 5  Short offline       Completed without error       00%         5         -
SMART Selective self-test log data structure revision number 1
 SPAN  MIN_LBA  MAX_LBA  CURRENT_TEST_STATUS
    1        0        0  Not_testing
    2        0        0  Not_testing
    3        0        0  Not_testing
    4        0        0  Not_testing
    5        0        0  Not_testing
Selective self-test flags (0x0):
  After scanning selected spans, do NOT read-scan remainder of disk.
If Selective self-test is pending on power-up, resume after 0 minute delay.
Was mich wundert wenn ich nun in den SMART Werten reinschaue finde ich absolut nichts zu den Fehler? Reallocated_Event_Count ist auf 0, Current_Pending_Sector auch und Reallocated_Sector_Ct ist auch auf 0. Sollte ich mir sorgen machen? Find es nur komisch, dass ich nichts dazu in den Smart Werte finde.
"Pending" Sector bedeutet ja, dass er einen Lesefehler hatte, aber seither noch nicht darauf geschrieben wurde (erst wenn das nicht mehr geht, gilt er als fehlerhaft und würde "reallocated"). Da aber offenbar beim nächsten Schreibversuch auf den Sector alles in Ordnung war, wurde er aus den Pending-Sectors gestrichen und es war auch kein Reallocation-Event nötig.
Weiter beobachten, sowas kann auch gerne mal an anderen Faktoren liegen - Overclocking, Software-Fehler... aber natürlich ist man dann immer etwas beunruhigt.
Das sind SSDs sind keine HDDs, da läuft es etwas anders, aber wieso scheinbar die Crucial SSDs immer wieder mal Pending Sectors anzeigen und andere nicht, kann ich auch nicht sagen. Nach einer C300 und einigen m4 bin ich auf Samsung bzw. Intel (750er und Optane) umgestiegen.
