Hello, so I am new to the whole dock situation. I own a Legion Y740 and recently decided to use it as my primary computer up till now it was used mostly for travel and when I got home I would switch to a desktop. Now that is no longer an option so bought a dock so I could replicate that feeling. I bought a Totu TT-DC001A. I hooked it up and all the ports but the video output ports (HDMIx2 and display port) functioned as expected. I then went online to find drivers figuring that was the issue. I found downloads for display link manager but it still will not detect the plugged-in, monitor. What am I missing?
USB C DOCK
- Ersteller tttthhhh
UNDERESTIMATED
Banned
- März 2012
Hi there, welcome to the forum.
Could you please provide more information about the used Docking-Solution in fact? A product link or a datasheet about it would be very helpful.
Google is not very helpful around here, for my side it's mainly showing alternatives than a specific manufacturers manual or Product Sheet.
I would suppose it could be an issue with the handling and not assuming that you want to duplicate or expand another screen with that single USB-C connection but for that we need more information how that display you missing is trying to be connected to the Laptop you own.
BFF
¯\_(ツ)_/¯
- Okt. 2017
There is only one docking station from Totu at the moment.
https://www.mytotu.com/collections/docking-stations
This dock is a convenient USB-C Dock that requires Thunderbolt/USB-C wirh DisplayPort Alternate mode.
https://www.mytotu.com/products/totu-docking-station
https://geizhals.de/lenovo-legion-y740-17irhg-81uj0093ge-a2244946.html#specs
Your notebook seems ro habe Thunderbolt 3 so that should work, at least with one monitor.
Did you connect the bottom USB-C Port with the notebook? Which cable do you use?
I believe so I ordered a new cable. I am currently using my wife's USB-C cable that came with her MAC PRO 2018. Though I just tried to connect her laptop to the dock and it is having the same issue. Thank you for the support I hope that is all it is. I will follow up once I have another cable to test it with.
Still not working this is the cable I bought and I still can not get the display to work.
Amazon
https://www.amazon.de/-/en/Thunderb...ub+docking+and+much+more,industrial,72&sr=1-2
Amazon
If two devices don't work with the Hub, i would send it back. Even the cheapest usb-c hub should give a picture plug and play.
Maybe go for a refurbished Thunderbolt Dock from the big OEMs. Dell TB16 for example, Lenovo and HP have some too.
The cable is suspiciously named charging cable, maybe it is not a regular TB3 one - couldn't filter the comments.
This one works with video, but due to its length not with full data transmission speed
https://www.amazon.de/dp/B07JK4F95B/
