aktuell bootet mir nur die desinfect, Gruß von einem Ahnungslosen:
desinfect@desinfect:~$ tail -f -n 0 /var/log/syslog
Nov 18 18:30:54 desinfect kernel: [ 451.544105] usb 3-6: USB disconnect, device number 4
Nov 18 18:30:54 desinfect kernel: [ 451.560049] sd 6:0:0:0: [sdc] tag#0 FAILED Result: hostbyte=DID_NO_CONNECT driverbyte=DRIVER_OK
Nov 18 18:30:54 desinfect kernel: [ 451.560051] sd 6:0:0:0: [sdc] tag#0 CDB: Read(10) 28 00 00 00 00 00 00 00 08 00
Nov 18 18:30:54 desinfect kernel: [ 451.560053] blk_update_request: I/O error, dev sdc, sector 0
Nov 18 18:30:54 desinfect kernel: [ 451.560056] Buffer I/O error on dev sdc, logical block 0, async page read
Nov 18 18:30:54 desinfect kernel: [ 451.560100] ldm_validate_partition_table(): Disk read failed.
Nov 18 18:30:54 desinfect kernel: [ 451.560108] Dev sdc: unable to read RDB block 0
Nov 18 18:30:54 desinfect kernel: [ 451.560123] sdc: unable to read partition table
Nov 18 18:30:54 desinfect kernel: [ 451.560213] sd 6:0:0:0: [sdc] Read Capacity(10) failed: Result: hostbyte=DID_NO_CONNECT driverbyte=DRIVER_OK
Nov 18 18:30:54 desinfect kernel: [ 451.560214] sd 6:0:0:0: [sdc] Sense not available.
Nov 18 18:30:54 desinfect kernel: [ 451.560224] sd 6:0:0:0: [sdc] Write Protect is on
Nov 18 18:30:54 desinfect kernel: [ 451.560225] sd 6:0:0:0: [sdc] Mode Sense: ff ff ff ff
Nov 18 18:30:54 desinfect kernel: [ 451.560229] sd 6:0:0:0: [sdc] Attached SCSI removable disk
Nov 18 18:30:32 desinfect gnome-session[3288]: message repeated 6 times: [ ls: Zugriff auf '/opt/sophos-av/update/cache/Primary/*.upd' nicht möglich: Keine Berechtigung]
Nov 18 18:30:54 desinfect systemd-udevd[4322]: inotify_add_watch(9, /dev/sdc, 10) failed: No such file or directory
Nov 18 18:30:56 desinfect kernel: [ 453.547913] usb 3-6: new high-speed USB device number 5 using xhci_hcd
Nov 18 18:30:56 desinfect systemd-udevd[4340]: failed to execute '/lib/udev/mtp-probe' 'mtp-probe /sys/devices/pci0000:00/0000:00:14.0/usb3/3-6 3 5': No such file or directory
Nov 18 18:30:56 desinfect kernel: [ 453.697624] usb 3-6: New USB device found, idVendor=054c, idProduct=0439
Nov 18 18:30:56 desinfect kernel: [ 453.697625] usb 3-6: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Nov 18 18:30:56 desinfect kernel: [ 453.697626] usb 3-6: Product: Storage Media
Nov 18 18:30:56 desinfect kernel: [ 453.697627] usb 3-6: Manufacturer: Sony
Nov 18 18:30:56 desinfect kernel: [ 453.697628] usb 3-6: SerialNumber: 7B4211105281002819
Nov 18 18:30:56 desinfect kernel: [ 453.698064] usb-storage 3-6:1.0: USB Mass Storage device detected
Nov 18 18:30:56 desinfect kernel: [ 453.698633] scsi host6: usb-storage 3-6:1.0
Nov 18 18:31:02 desinfect gnome-session[3288]: ls: Zugriff auf '/opt/sophos-av/update/cache/Primary/*.upd' nicht möglich: Keine Berechtigung
Nov 18 18:31:03 desinfect kernel: [ 461.344329] scsi 6:0:0:0: Direct-Access Sony Storage Media 0100 PQ: 0 ANSI: 0 CCS
Nov 18 18:31:03 desinfect kernel: [ 461.344843] sd 6:0:0:0: Attached scsi generic sg3 type 0
Nov 18 18:31:03 desinfect kernel: [ 461.348050] sd 6:0:0:0: [sdc] 31703040 512-byte logical blocks: (16.2 GB/15.1 GiB)
Nov 18 18:31:03 desinfect kernel: [ 461.348307] sd 6:0:0:0: [sdc] Test WP failed, assume Write Enabled
Nov 18 18:31:03 desinfect kernel: [ 461.348552] sd 6:0:0:0: [sdc] Asking for cache data failed
Nov 18 18:31:03 desinfect kernel: [ 461.348555] sd 6:0:0:0: [sdc] Assuming drive cache: write through
Nov 18 18:31:35 desinfect kernel: [ 492.569030] usb 3-6: reset high-speed USB device number 5 using xhci_hcd
