Fun-Racer V Rally 4 stürtzt auf Steam immer ab
oneblord
Okt. 2020
Hallo
das spiel V Rally 4 auf steam stürtzt immer wiede
steam und grafikarte sind aktuell
Meine Hardware Daten
HWiNFO64 Version 7.06-4500
DESKTOP-23QVBVH -----------------------------------------------------------
[Current Computer]
Computer Name: DESKTOP-23QVBVH
[Operating System]
Operating System: Microsoft Windows 10 Professional (x64) Build 19043.1165 (21H1)
UEFI Boot: Present
Secure Boot: Not Present
Central Processor(s) ------------------------------------------------------
[CPU Unit Count]
Number Of Processor Packages (Physical): 1
Number Of Processor Cores: 4
Number Of Logical Processors: 8
Intel Core i7-3770 --------------------------------------------------------
[General Information]
Processor Name: Intel Core i7-3770
Original Processor Frequency: 3400.0 MHz
Original Processor Frequency [MHz]: 3400
Motherboard ---------------------------------------------------------------
[Computer]
[Motherboard]
Motherboard Model: FUJITSU D3161-A1
[PCH Features]
[BIOS]
Intel ME ------------------------------------------------------------------
[ME Host Status]
[Intel Manageability Engine Features]
[ME Firmware Capabilities]
[ME Firmware Feature State]
[ME Firmware Platform Type]
Memory --------------------------------------------------------------------
[General information]
[Current Performance Settings]
Drives --------------------------------------------------------------------
(S)ATA/ATAPI Drives -------------------------------------------------------
JAJS600M512C --------------------------------------------------------------
Drive Controller: Serial ATA 6Gb/s @ 6Gb/s
Host Controller: Intel Panther Point PCH - SATA AHCI Controller [C1]
Drive Model: JAJS600M512C
Drive Firmware Revision: S0222A0
Drive Serial Number: AA201907000000002081
Drive Capacity: 488,386 MBytes (512 GB)
Drive Capacity [MB]: 488386
Media Rotation Rate: SSD Drive (Non-rotating)
Nominal Form Factor: 2.5"
ATA Major Version Supported: ATA/ATAPI-5, ATA/ATAPI-6, ATA/ATAPI-7, ATA8-ACS, ACS-2
ATA Minor Version Supported: ACS-2 Revision 3
ATA Transport Version Supported: SATA 3.2
[Drive Geometry]
Number of Cylinders: 16383
Number of Heads: 16
Sectors Per Track: 63
Number of Sectors: 16514064
Total 32-bit LBA Sectors: 268435455
Total 48-bit LBA Sectors: 1000215216
Logical Sector Size: 512 Bytes
Cache Buffer Size: N/A
[Transfer Modes]
Sectors Per Interrupt: Total: 1, Active: 1
Max. PIO Transfer Mode: 4
Multiword DMA Mode: Total: 2, Active: -
Singleword DMA Mode: Total: -, Active: -
Ultra-DMA Mode: Total: 6 (ATA-133), Active: 5 (ATA-100)
Max. Multiword DMA Transfer Rate: 16.7 MBytes/s
Max. PIO with IORDY Transfer Rate: 16.7 MBytes/s
Max. PIO w/o IORDY Transfer Rate: 16.7 MBytes/s
Native Command Queuing: Supported, Max. Depth: 32
TRIM Command: Supported (Deterministic Read After TRIM, Words = 0)
[Device flags]
Fixed Drive: Present
Removable Drive: Not Present
Magnetic Storage: Present
LBA Mode: Supported
DMA Mode: Supported
IORDY: Supported
IORDY Disableable: Supported
[Features]
Write Cache: Present, Active
S.M.A.R.T. Feature: Present, Active
Security Feature: Present, Inactive
Removable Media Feature: Not Present, Disabled
Power Management: Present, Active
Advanced Power Management: Present, Active
Packet Interface: Not Present, Disabled
Look-Ahead Buffer: Present, Active
Host Protected Area: Present, Enabled
Power-Up In Standby: Not Suppported, Inactive
Automatic Acoustic Management: Not Suppported, Inactive
48-bit LBA: Supported, Active
Host-Initiated Link Power Management: Not Supported
Device-Initiated Link Power Management: Not Supported
In-Order Data Delivery: Not Supported
Hardware Feature Control: Not Supported
Software Settings Preservation: Supported, Enabled
NCQ Autosense: Not Supported
Link Power State Device Sleep: Not Supported
Hybrid Information Feature: Not Supported
Rebuild Assist: Not Supported
Power Disable: Not Supported
All Write Cache Non-Volatile: Not Supported
Extended Number of User Addressable Sectors: Not Supported
CFast Specification: Not Supported
NCQ Priority Information: Not Supported
Host Automatic Partial to Slumber Transitions: Not Supported
Device Automatic Partial to Slumber Transitions: Not Supported
NCQ Streaming: Not Supported
NCQ Queue Management Command: Not Supported
DevSleep to Reduced Power State: Not Supported
Out Of Band Management Interface: Not Supported
Extended Power Conditions Feature: Not Supported
Sense Data Reporting Feature: Not Supported
Free-Fall Control Feature: Not Supported
Write-Read-Verify Feature: Not Supported
[Security]
Security Feature: Supported
Security Status: Disabled
Security Locked: Disabled
Security Frozen: Enabled
Enhanced Security Erase: Supported
Sanitize Feature: Supported
Sanitize Device - Crypto Scramble: Not Supported
Sanitize Device - Overwrite: Not Supported
Sanitize Device - Block Erase: Supported
Sanitize Device - Antifreeze Lock: Not Supported
Device Encrypts All User Data: Not Supported
Trusted Computing: Not Supported
[Self-Monitoring, Analysis and Reporting Technology (S.M.A.R.T.)]
[01] Raw Read Error Rate: 100/50, Worst: 100
[05] Reallocated Sector Count: 100/50, Worst: 100
[09] Power-On Hours/Cycle Count: 100/50, Worst: 100 (2264 hours / 94.3 days)
[0C] Power Cycle Count: 100/50, Worst: 100 (Data = 729,0)
[A0] Initial Bad Block Count: 100/50, Worst: 100
[A1] Current Bad Block Count: 100/50, Worst: 100 (Data = 100,0)
[A3] Max PE Cycle: 100/50, Worst: 100 (Data = 18,0)
[A4] Average Erase Count: 100/50, Worst: 100 (Data = 75879,0)
[A5] Initial Bad Block Count: 100/50, Worst: 100 (Data = 247,0)
[A6] Min W/E Cycle: 100/50, Worst: 100 (Data = 65,0)
[A7] SSD Protect Mode: 100/50, Worst: 100 (Data = 156,0)
[A8] SATA PHY Error Count: 100/50, Worst: 100 (Data = 7000,0)
[A9] Total Bad Block Count: 100/50, Worst: 100 (Data = 98,0)
[AF] Program/ECC Fail Count: 100/50, Worst: 100
[B0] Erase Fail Count: 100/50, Worst: 100
[B1] Wear Leveling Count: 100/50, Worst: 100
[B2] Used Reserved Block Count (Chip): 100/50, Worst: 100
[B5] Program Fail Count (Total): 100/50, Worst: 100
[B6] Erase Fail Count (Total): 100/50, Worst: 100
[C0] Unsafe Shutdown Count: 100/50, Worst: 100 (Data = 98,0)
[C2] Temperature 100/50, Worst: 100 (36.0 °C)
[C3] ECC Error Rate: 100/50, Worst: 100 (Data = 5292,0)
[C4] Reallocation Event Count: 100/50, Worst: 100
[C5] Current Pending Sector Count: 100/50, Worst: 100
[C6] Off-Line Uncorrectable Sector Count: 100/50, Worst: 100
[C7] SATA CRC Error Count: 100/50, Worst: 100
[E8] Available Reserved Space: 100/50, Worst: 100 (Data = 100,0)
[F1] Total Host Writes: 100/50, Worst: 100 (Data = 516345,0)
[F2] Total Host Reads: 100/50, Worst: 100 (Data = 995041,0)
[F5] Cumulative Program NAND Pages: 100/50, Worst: 100 (Data = 840312,0)
Drive Remaining Life 98%
[Device Statistics]
Lifetime Power-On Resets: 729
Power-on Hours: 2264
Logical Sectors Written: 3774448742
Logical Sectors Read: 786502981
Number of Write Commands: 66475
Number of Read Commands: 318801
Used Endurance Indicator: 2%
ASUS DRW-24D5MT -----------------------------------------------------------
Drive Model: ASUS DRW-24D5MT
Drive Firmware Revision: 2.00
Firmware Date: 2019-06-17 10:49:
Serial Number: KM4JASB5027
Device Type: DVD+R DL
[Device Capabilities]
Drive can read: CD-R, CD-RW, DVD-R, DVD-RW, DVD+R, DVD+RW, DVD+R DL
Drive can write: CD-RW, DVD-R, DVD-RW, DVD+R, DVD+RW, DVD+R DL
Network -------------------------------------------------------------------
Intel 82579V (Lewisville) Gigabit Network Connection ----------------------
Network Card: Intel 82579V (Lewisville) Gigabit Network Connection
Vendor Description: Intel(R) 82579V Gigabit Network Connection
MAC Address: 90-1B-0E-40-14-49
[Capabilities]
Maximum Link Speed: 100 Mbps
Transmit Buffer Size: 775168 Bytes
Receive Buffer Size: 389632 Bytes
Hardware ID: PCI\VEN_8086&DEV_1503&SUBSYS_11D91734&REV_04
[Driver Information]
Driver Manufacturer: Intel Corporation
Driver Description: Intel(R) 82579V Gigabit Network Connection
Driver Provider: Microsoft
Driver Version: 12.17.10.8
Driver Date: 12-Jun-2018
DeviceInstanceId PCI\VEN_8086&DEV_1503&SUBSYS_11D91734&REV_04\3&11583659&0&C8
Location Paths PCIROOT(0)#PCI(1900)
Realtek RTL8188EU Wireless LAN 802.11n USB 2.0 Network Adapter ------------
Network Card: Realtek RTL8188EU Wireless LAN 802.11n USB 2.0 Network Adapter
Vendor Description: Microsoft
MAC Address: 20-0D-B0-1E-61-76
[Capabilities]
Maximum Link Speed: 54 Mbps
Transmit Buffer Size: 9 Bytes
Receive Buffer Size: 9 Bytes
Schon verschiedene Kompatibilitätsmodi ausprobiert?
Welches Windows ist das? Und ist das das einzige Spiel das abschmiert?
ich hab windows 10 pro 22h2 und ja es ist das einzige spiel das abschmiert
