I am conducting a survey of 5600x users (or anything 5600 non-x, 5700x, 5800x) whole system at the wall wattage under "light load" (defined as 10% CPU usage ~20 tabs already open + youtube video playing 1080p)
I want to build the following system, but I am Concerned about wattage during idle and "light load" situations
5600x,
3060ti,
MSI B550M PRO VDH low wattage motherboard
(https://www.amazon.com/MSI-B550M-PRO-VDH-ProSeries-Motherboard/dp/B089D1YG11/
2 sticks RAM totaling either 16gb or 32gb 3200 MT/s ram (depends on how much more wattage 32gb would take
2tb M.2 NVME SSD (some WD brand SSD that supposedly only uses 1 watt normally )
platinum PSU (might buy titanium in the future)
My plan is to underclock/undervolt the GPU for lower idle + set a power limit to lower max consumption during gaming
Ram, I want XMP on (because I don't want to keep going back to the bios) but I want to lower the voltage and clock as much as possible without hampering the CPU
What I am not sure about is the 5600x CPU wattage and the resulting power usage on the motherboard+I/O die (or whatever it is that takes the most wattage in that part of the computer) .
I'm not worried about power usage when gaming, since Ryzen is really good in that situation.
But most of the time the computer will be doing a "light load" just browsing the internet (with like 20-30 tabs open and a 1080p video Youtube, Twitch, etc.)
I am asking for people with similar builds (especially 5600x builds) WHAT IS THE POWER DRAW WITH A WATT METER "AT THE WALL" during "light load" (defined as 20-30 browser tabs already open + 1080p video playing in browser)
So if a few people can help me by measuring at the wall in that situation, it will help me decide whether to buy the parts from Newegg (where I can return them if it doesn't work) to do testing of my own. Feel free to use whatever power settings you want, eco mode, undervolt, etc. Just please say what your settings are, and if you are doing something that MASSIVELY slows it down or that cannot be switched off quickly to go back to normal power.
If there doesn't exist a combination of settings that allows the wattage to be like 50-65 ish watts at the wall in that situation, I will have to buy an Intel CPU and quit using Win 7 (Intel no longer support Win 7 without custom drivers which are a security risk) because Intel offers a much lower idle and responsible power (and not having excess heat!) is really important in my situation right now. Win 7 is also important to me for comfort reasons and it's easier to stop the spying and bullshit than win 10.
Thank you for reading! Any help is appreciated!
P.S. If you all help me with this and I end up buying the parts, I will make a second post with my results with that motherboard and Win 7 since it should be lower CPU usage than Win 10, and thus lower wattage. Hopefully that sounds interesting because power saving seems pretty important to many people on this forum. Thank you again!)
5600x,
3060ti,
