Microsoft (R) Windows Debugger Version 6.12.0002.633 AMD64
Copyright (c) Microsoft Corporation. All rights reserved.
Loading Dump File [C:\Windows\MEMORY.DMP]
Kernel Summary Dump File: Only kernel address space is available
Symbol search path is: SRV*C:\symbols*http://msdl.microsoft.com/download/symbols
Executable search path is:
Windows 7 Kernel Version 7600 MP (6 procs) Free x64
Product: WinNt, suite: TerminalServer SingleUserTS
Built by: 7600.16617.amd64fre.win7_gdr.100618-1621
Machine Name:
Kernel base = 0xfffff800`03013000 PsLoadedModuleList = 0xfffff800`03250e50
Debug session time: Sat Jan 8 14:59:59.307 2011 (UTC + 1:00)
System Uptime: 0 days 1:12:50.289
Loading Kernel Symbols
Loading User Symbols
PEB is paged out (Peb.Ldr = 000007ff`fffd5018). Type ".hh dbgerr001" for details
Loading unloaded module list
* Bugcheck Analysis *
Use !analyze -v to get detailed debugging information.
BugCheck 3B, {c0000005, fffff8800498d817, fffff88007bca900, 0}
*** ERROR: Module load completed but symbols could not be loaded for atikmdag.sys
*** ERROR: Module load completed but symbols could not be loaded for atikmpag.sys
Page 10a15f not present in the dump file. Type ".hh dbgerr004" for details
Probably caused by : atikmdag.sys ( atikmdag+90817 )
Followup: MachineOwner
4: kd> !analyze –v
4: kd> !analyze -v
SYSTEM_SERVICE_EXCEPTION (3b)
An exception happened while executing a system service routine.
Arguments:
Arg1: 00000000c0000005, Exception code that caused the bugcheck
Arg2: fffff8800498d817, Address of the instruction which caused the bugcheck
Arg3: fffff88007bca900, Address of the context record for the exception that caused the bugcheck
Arg4: 0000000000000000, zero.
Debugging Details:
EXCEPTION_CODE: (NTSTATUS) 0xc0000005 - Die Anweisung in 0x%08lx verweist auf Speicher 0x%08lx. Der Vorgang %s konnte nicht im Speicher durchgef hrt werden.
FAULTING_IP:
atikmdag+90817
fffff880`0498d817 8b4820 mov ecx,dword ptr [rax+20h]
CONTEXT: fffff88007bca900 -- (.cxr 0xfffff88007bca900)
rax=0000000000000000 rbx=fffffa8004da4100 rcx=fffffa8007234d90
rdx=0000000000000000 rsi=0000000000000015 rdi=fffffa8007234010
rip=fffff8800498d817 rsp=fffff88007bcb2d0 rbp=fffffa8007234d90
r8=0000000000000015 r9=fffff88004d4f970 r10=0000000000000000
r11=fffff88007bcb420 r12=0000000000000000 r13=fffffa8007ac1900
r14=0000000000000001 r15=0000000000000000
iopl=0 nv up ei pl zr na po nc
cs=0010 ss=0018 ds=002b es=002b fs=0053 gs=002b efl=00010246
atikmdag+0x90817:
fffff880`0498d817 8b4820 mov ecx,dword ptr [rax+20h] ds:002b:00000000`00000020=????????
Resetting default scope
DEFAULT_BUCKET_ID: VISTA_DRIVER_FAULT
BUGCHECK_STR: 0x3B
PROCESS_NAME: dwm.exe
CURRENT_IRQL: 0
LAST_CONTROL_TRANSFER: from fffff88004c8621f to fffff8800498d817
STACK_TEXT:
fffff880`07bcb2d0 fffff880`04c8621f : fffffa80`04da4100 fffff880`07bcb420 fffffa80`0723a000 00000000`00000000 : atikmdag+0x90817
fffff880`07bcb300 fffff880`04c864a0 : 00000000`00000001 0000000f`00500000 fffffa80`0723a000 00000000`00000000 : atikmdag+0x38921f
fffff880`07bcb390 fffff880`0429f5b2 : fffff8a0`0865cf00 00000000`00000000 00000000`c0000001 fffff8a0`01828360 : atikmdag+0x3894a0
fffff880`07bcb3d0 fffff880`048013fd : fffffa80`04b6f000 00000000`00000001 fffff880`07bcb6e0 fffff8a0`01bdbdf0 : atikmpag+0x75b2
fffff880`07bcb670 fffff880`0482bb71 : fffffa80`04b6f000 fffffa80`04b6f000 00000000`00000001 fffff800`030881fa : dxgkrnl!DXGADAPTER::DdiSetVidPnSourceAddress+0x79
fffff880`07bcb6b0 fffff880`04857c9c : 00000000`00000001 fffff8a0`01963000 00000000`00000000 fffff8a0`01963000 : dxgkrnl!DXGADAPTER::UpdateModeWithPrimary+0x12d
fffff880`07bcb930 fffff880`04856fd0 : fffff8a0`01963000 fffff8a0`01963000 fffff880`00000001 00000000`00000001 : dxgkrnl!DXGDEVICE::SetDisplayMode+0x4ec
fffff880`07bcbad0 fffff960`001abb74 : 00000000`0243f2c8 fffffa80`ffffeee6 00000000`00000000 00000000`00000001 : dxgkrnl!DxgkSetDisplayMode+0xad4
fffff880`07bcbbf0 fffff800`03082993 : fffffa80`07abd060 fffff880`07bcbca0 00000000`00000000 00000000`00000020 : win32k!NtGdiDdDDISetDisplayMode+0x14
fffff880`07bcbc20 000007fe`fd69849a : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiSystemServiceCopyEnd+0x13
00000000`0243f298 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : 0x7fe`fd69849a
FOLLOWUP_IP:
atikmdag+90817
SYMBOL_STACK_INDEX: 0
SYMBOL_NAME: atikmdag+90817
FOLLOWUP_NAME: MachineOwner
MODULE_NAME: atikmdag
IMAGE_NAME: atikmdag.sys
DEBUG_FLR_IMAGE_TIMESTAMP: 4cef1f94
STACK_COMMAND: .cxr 0xfffff88007bca900 ; kb
FAILURE_BUCKET_ID: X64_0x3B_atikmdag+90817
