ich habe nun knapp seit 2 Jahren das Problem,das mein Pc einfach anfängt zu laggen,sobald die Lags anfangen, stottert der Sound und alles Hängt.Dieser Vorgang kann von 2Sec bis 5 Min andauern.Ich war in viele Forums unterwegs und habe jede Lösung probiert,die ich gefunden habe,leider ohne Erfolg.
Your system appears to be having trouble handling real-time audio and other tasks. You are likely to experience buffer underruns appearing as drop outs, clicks or pops. One problem may be related to power management, disable CPU throttling settings in Control Panel and BIOS setup. Check for BIOS updates.
LatencyMon has been analyzing your system for 0:09:51 (h:mm:ss) on all processors.
_________________________________________________________________________________________________________
SYSTEM INFORMATION
Computer name: DESKTOP-TUE3BB1
OS version: Windows 10 , 10.0, build: 16299 (x64)
Hardware: X370GT5, BIOSTAR Group
CPU: AuthenticAMD AMD Ryzen 3 1200 Quad-Core Processor
Logical processors: 4
Processor groups: 1
RAM: 8145 MB total
CPU SPEED
Reported CPU speed: 3094 MHz
Note: reported execution times may be calculated based on a fixed reported CPU speed. Disable variable speed settings like Intel Speed Step and AMD Cool N Quiet in the BIOS setup for more accurate results.
WARNING: the CPU speed that was measured is only a fraction of the CPU speed reported. Your CPUs may be throttled back due to variable speed settings and thermal issues. It is suggested that you run a utility which reports your actual CPU frequency and temperature.
MEASURED INTERRUPT TO USER PROCESS LATENCIES
The interrupt to process latency reflects the measured interval that a usermode process needed to respond to a hardware request from the moment the interrupt service routine started execution. This includes the scheduling and execution of a DPC routine, the signaling of an event and the waking up of a usermode thread from an idle wait state in response to that event.
Highest measured interrupt to process latency (µs): 2001,022476
Average measured interrupt to process latency (µs): 8,519360
Highest measured interrupt to DPC latency (µs): 493,079428
Average measured interrupt to DPC latency (µs): 3,246329
REPORTED ISRs
Interrupt service routines are routines installed by the OS and device drivers that execute in response to a hardware interrupt signal.
Highest ISR routine execution time (µs): 242,799935
Driver with highest ISR routine execution time: Wdf01000.sys - Kernelmodustreiber-Frameworklaufzeit, Microsoft Corporation
Highest reported total ISR routine time (%): 0,017789
Driver with highest ISR total time: HDAudBus.sys - High Definition Audio Bus Driver, Microsoft Corporation
Total time spent in ISRs (%) 0,023449
ISR count (execution time <250 µs): 121359
ISR count (execution time 250-500 µs): 0
ISR count (execution time 500-999 µs): 0
ISR count (execution time 1000-1999 µs): 0
ISR count (execution time 2000-3999 µs): 0
ISR count (execution time >=4000 µs): 0
REPORTED DPCs
DPC routines are part of the interrupt servicing dispatch mechanism and disable the possibility for a process to utilize the CPU while it is interrupted until the DPC has finished execution.
Highest DPC routine execution time (µs): 496,390756
Driver with highest DPC routine execution time: dxgkrnl.sys - DirectX Graphics Kernel, Microsoft Corporation
Highest reported total DPC routine time (%): 0,161770
Driver with highest DPC total execution time: dxgkrnl.sys - DirectX Graphics Kernel, Microsoft Corporation
Total time spent in DPCs (%) 0,457477
DPC count (execution time <250 µs): 1945166
DPC count (execution time 250-500 µs): 0
DPC count (execution time 500-999 µs): 19
DPC count (execution time 1000-1999 µs): 0
DPC count (execution time 2000-3999 µs): 0
DPC count (execution time >=4000 µs): 0
REPORTED HARD PAGEFAULTS
Hard pagefaults are events that get triggered by making use of virtual memory that is not resident in RAM but backed by a memory mapped file on disk. The process of resolving the hard pagefault requires reading in the memory from disk while the process is interrupted and blocked from execution.
NOTE: some processes were hit by hard pagefaults. If these were programs producing audio, they are likely to interrupt the audio stream resulting in dropouts, clicks and pops. Check the Processes tab to see which programs were hit.
Process with highest pagefault count: chrome.exe
Total number of hard pagefaults 553
Hard pagefault count of hardest hit process: 244
Number of processes hit: 20
PER CPU DATA
CPU 0 Interrupt cycle time (s): 36,072942
CPU 0 ISR highest execution time (µs): 241,677763
CPU 0 ISR total execution time (s): 0,517588
CPU 0 ISR count: 102979
CPU 0 DPC highest execution time (µs): 496,390756
CPU 0 DPC total execution time (s): 10,436242
CPU 0 DPC count: 1906845
CPU 1 Interrupt cycle time (s): 7,468693
CPU 1 ISR highest execution time (µs): 242,799935
CPU 1 ISR total execution time (s): 0,019744
CPU 1 ISR count: 8048
CPU 1 DPC highest execution time (µs): 246,457014
CPU 1 DPC total execution time (s): 0,223388
CPU 1 DPC count: 21097
CPU 2 Interrupt cycle time (s): 4,568661
CPU 2 ISR highest execution time (µs): 54,976406
CPU 2 ISR total execution time (s): 0,010169
CPU 2 ISR count: 5963
CPU 2 DPC highest execution time (µs): 196,861021
CPU 2 DPC total execution time (s): 0,079652
CPU 2 DPC count: 8861
CPU 3 Interrupt cycle time (s): 5,159310
CPU 3 ISR highest execution time (µs): 10,059470
CPU 3 ISR total execution time (s): 0,006861
Bei den mit Info-Icon markierten Links handelt es sich um Affiliate-Links. Im Fall einer Bestellung über einen solchen Link wird ComputerBase am Verkaufserlös beteiligt, ohne dass der Preis für den Kunden steigt.
