ich hoffe ihr erlaubt mir, mein Anliegen auf Englisch zu beschreiben. Ich habe dieses nämlich gerade so einem englischsprachigem Freund geschildert. Gerne könnt ihr natürlich auf Deutsch antworten.
Ganz herzlichen Dank schonmal.
I am trying to send a WinRS command from clientX to server1, which inlcudes a UNC path reference to a shared folder on server2. I understood that therefore I need to perform credential delegation from clientX to server1 ("double-hop"). Both clientX and server1 actually have access to that shared folder on server2.
clientX -> server1 -> server2
I followed all available instructions regarding WinRM and CredSSP configurations, like this: [Multi-Hop Support in WinRM - Win32 apps and it appears to me that everything was set up as intended.
on clientX, I can aswell successfully run the command:
on clientX, I can successfully run the command:
on clientX, I fail to run the command:
as I receive the error message "access is denied". And that is the problem.
on clientX, the power shell command
returns:
The machine is configured to allow delegating fresh credentials to the following target(s): wsman/SERVER1
This computer is not configured to receive credentials from a remote client computer.
on clientX, the cmd command
returns:
on server1, the power shell command "Get-WSManCredSSP" returns:
The machine is not configured to allow delegating fresh credentials.
This computer is configured to receive credentials from a remote client computer.
on server1, the cmd command
returns:
returns:
Any ideas?
- hostname of clientX is 'clientX' (acquired from cmd command 'hostname')
- full computer name of clientX is 'clientX' (acquired from control panel > system)
- user domain of clientX is 'CLIENTX' (acquired from cmd command 'echo %userdomain%')
- hostname of server1 is 'server1' (acquired from cmd command 'hostname')
- full computer name of server1 is 'server1' (acquired from control panel > system)
- user domain of server1 is 'SERVER1' (acquired from cmd command 'echo %userdomain%')
- the unc path on server2 is \SERVER2\sharedF\test
dir \\SERVER2\sharedF\test
winrs.exe -r:http://SERVER1:5985 -u:adminOnserver1 -pass4server1 "dir c:"
winrs.exe -r:http://SERVER1:5985 -u:adminOnserver1 -pass4server1 "dir \\SERVER2\sharedF\test"
Get-WSManCredSSP
returns:
winrm get winrm/config
returns:
Config
MaxEnvelopeSizekb = 500
MaxTimeoutms = 60000
MaxBatchItems = 32000
MaxProviderRequests = 4294967295
Client
NetworkDelayms = 5000
URLPrefix = wsman
AllowUnencrypted = true
Auth
Basic = true
Digest = true
Kerberos = true
Negotiate = true
Certificate = true
CredSSP = true
DefaultPorts
HTTP = 5985
HTTPS = 5986
TrustedHosts = 200.0.0.145,CLIENTX,200.0.0.159,SERVER1
Service
RootSDDL = O:NSG:BAD(A;;GA;;;BA)(A;;GR;;;IU)S
(AU;FA;GA;;;WD)(AU;SA;GXGW;;;WD)
MaxConcurrentOperations = 4294967295
MaxConcurrentOperationsPerUser = 1500
EnumerationTimeoutms = 240000
MaxConnections = 300
MaxPacketRetrievalTimeSeconds = 120
AllowUnencrypted = false
Auth
Basic = false
Kerberos = true
Negotiate = true
Certificate = false
CredSSP = false
CbtHardeningLevel = Relaxed
DefaultPorts
HTTP = 5985
HTTPS = 5986
IPv4Filter = *
IPv6Filter = *
EnableCompatibilityHttpListener = false
EnableCompatibilityHttpsListener = false
CertificateThumbprint
AllowRemoteAccess = true
Winrs
AllowRemoteShellAccess = true
IdleTimeout = 7200000
MaxConcurrentUsers = 2147483647
MaxShellRunTime = 2147483647
MaxProcessesPerShell = 2147483647
MaxMemoryPerShellMB = 2147483647
MaxShellsPerUser = 2147483647
returns:
Config
Client
URLPrefix = wsman
Auth
Basic = true
Digest = true
Kerberos = true
Negotiate = true
Certificate = true
CredSSP = true
DefaultPorts
HTTP = 5985
HTTPS = 5986
Service
Auth
Basic = false
Kerberos = true
Negotiate = true
Certificate = false
CredSSP = true
DefaultPorts
HTTP = 5985
HTTPS = 5986
IPv4Filter = *
IPv6Filter = *
Winrs
winrm e winrm/config/listener
returns:
Listener
Address = *
Transport = HTTP
Port = 5985
Hostname
Enabled = true
URLPrefix = wsman
ListeningOn = 127.0.0.1, 169.254.229.41, 200.0.0.159, ::1, fe80::5465:9195:eabb:b7e7%11, fe80::c056:f6db:8f7f:e529%9
Any ideas?
